  1. Perceba que o controle de banda funciona identificando a origem e destino do pacote, quando se usa proxy quem faz a solicitação para a internet é o proxy logo o trafego fica controlado entre o cliente e o proxy porem do proxy para a internet não.
    O que eu uso bem é <internet>-------------<proxy+nat> ------ <htb> --- <clientes>
    Dessa forma acabo preservando o pacote do cliente até o proxy e faço o controle de banda dos clientes, no proxy eu crio regras locais para que o link não seja totalmente utilizado troco o pfifo por sfq.
    Abraço
  2. Blz. Mas voce usa proxy transparente?
  3. rpz...do nada começou a trafegar na no htb:
    proxy:/home/novaf# tc -s -d class show dev eth1
    class htb 1:1 root rate 100000Kbit ceil 100000Kbit burst 51587b/8 mpu 0b overhead 0b cburst 51587b/8 mpu 0b overhead 0b level 7
    Sent 253792134 bytes 239826 pkt (dropped 0, overlimits 0 requeues 0)
    rate 510816bit 55pps backlog 0b 0p requeues 0
    lended: 148586 borrowed: 0 giants: 0
    tokens: 3981 ctokens: 3981
    class htb 1:10 parent 1:1 leaf 10: prio 1 quantum 6400 rate 512000bit ceil 512000bit burst 1855b/8 mpu 0b overhead 0b cburst 1855b/8 mpu 0b overhead 0b level 0
    Sent 3901 bytes 7 pkt (dropped 0, overlimits 0 requeues 0)
    rate 0bit 0pps backlog 0b 0p requeues 0
    lended: 7 borrowed: 0 giants: 0
    tokens: -6784 ctokens: -6784
    class htb 1:20 parent 1:1 leaf 20: prio 2 quantum 1250 rate 100000bit ceil 200000bit burst 1649b/8 mpu 0b overhead 0b cburst 1699b/8 mpu 0b overhead 0b level 0
    Sent 89368 bytes 395 pkt (dropped 0, overlimits 0 requeues 0)
    rate 40bit 0pps backlog 0b 0p requeues 0
    lended: 395 borrowed: 0 giants: 0
    tokens: 104367 ctokens: 54232
    class htb 1:30 parent 1:1 leaf 30: prio 3 quantum 3125 rate 250000bit ceil 512000bit burst 1724b/8 mpu 0b overhead 0b cburst 1855b/8 mpu 0b overhead 0b level 0
    Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
    lended: 0 borrowed: 0 giants: 0
    tokens: 56524 ctokens: 29696
    class htb 1:40 parent 1:1 leaf 40: prio 4 quantum 1600 rate 128000bit ceil 300000bit burst 1663b/8 mpu 0b overhead 0b cburst 1749b/8 mpu 0b overhead 0b level 0
    Sent 20046924 bytes 16666 pkt (dropped 0, overlimits 0 requeues 0)
    rate 126088bit 12pps backlog 0b 2p requeues 0
    lended: 10743 borrowed: 5921 giants: 0
    tokens: -123904 ctokens: -81859
    class htb 1:50 parent 1:1 leaf 50: prio 5 quantum 1600 rate 128000bit ceil 400000bit burst 1663b/8 mpu 0b overhead 0b cburst 1799b/8 mpu 0b overhead 0b level 0
    Sent 233699875 bytes 222769 pkt (dropped 156, overlimits 0 requeues 0)
    rate 386656bit 42pps backlog 0b 9p requeues 0
    lended: 80095 borrowed: 142665 giants: 0
    tokens: -134144 ctokens: -61105
    class htb 1:60 parent 1:1 leaf 60: prio 1 quantum 12500 rate 1000Kbit ceil 1000Kbit burst 2099b/8 mpu 0b overhead 0b cburst 2099b/8 mpu 0b overhead 0b level 0
    tokens: 17203 ctokens: 17203
    não precisei marcar nada no iptables..agora algué conhece algum QoS mais eficiente para voip porque as vezes ainda as ligações picotam....pode ser uma rera diferente de htb + iptables ou etc...
    agora noto que a latencia na placa de rede sobe para se ter uma ideia antes de começar trafegar(quando reininio o servidor) ele pinga 1ms nas maquinas internamente mas agora mesmo está pingando com media de 20ms o que pode ser? porque o htb está subindo a latencia assim?
    outra dúvida tenho proxy autenticado no meu caso ao invés da porta 80 eu deveria colocar a porta 3128 do squid no htb+tc?
    Última edição por lfernandosg; 11-09-2009 às 14:44.
  4. Olá, eu identifico cada telefone, amarro o mac e o ip no dhcp e crio uma classe no htb para cada um com prioridade 1.
    Dessa forma tenho um excelente resultado na voz.
    Temos vários servidores usando esse modelo e funcionam muito bem.
    []'s
  5. cara pode colocar um script de exemplo aqui? nosso servidor está ligado a atas, gateway e uma central telefonica que estamos substituindo por um audiocodes mp-124 24 portas fxs então me se puder me passar um script de exemplo agradeço.
  1. Respostas: 12
    Último Post: 09-03-2015, 14:24
  2. Controle de banda não funciona completamente Htb+tc
    Por lfernandosg no fórum Servidores de Rede
    Último Post: 07-10-2010, 07:45
  3. Versção 3.28 Não Está controlando Banda
    Por LulaVipNET no fórum Redes
    Último Post: 17-03-2010, 14:58
  4. um cliente nao esta controlando o up
    Por wesleymyau no fórum Redes
    Último Post: 19-12-2008, 07:23
  5. HTB não está funcionando limtação para a maquina
    Por slacklex no fórum Servidores de Rede
    Último Post: 21-04-2006, 12:47
