    Padrão Iptables não libera conexão p/ WEB
    Pessoal não consigo navegar de jeito maneira com as seguintes regras no meu firewall, vcs poderiam verificar onde eu estou errando, pq eu não acho nada errado vlw !!!
    #Ativando Nat
    modprobe iptable_nat
    modprobe ip_nat_ftp
    modprobe ip_conntrack_ftp
    iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    #Rota redes
    ip route add 192.168.2.0/24 via 192.168.1.251
    ip route add 192.168.3.0/24 via 192.168.1.49
    #Setup default policy
    for i in INPUT FORWARD OUTPUT; do iptables -P $i DROP; done
    #loopback
    iptables -A INPUT -i lo -j ACCEPT
    iptables -A OUTPUT -o lo -j ACCEPT
    #Ports INPUT Free
    #SSH
    iptables -A INPUT -p tcp --dport 2222 -j ACCEPT
    #WEB
    for i in 1 2 3; do iptables -A INPUT -p tcp -s 192.168.$i.0/24 --dport 80 -j ACCEPT; done
    iptables -A OUTPUT -p tcp -m multiport --dports 80,443 -j ACCEPT
    #FTP
    iptables -A INPUT -p tcp --dport 20:21 -j ACCEPT
    iptables -A INPUT -p tcp --dport 60000:61000 -j ACCEPT
    #DNS
    for i in tcp udp; do iptables -A INPUT -p $i --dport 53 -j ACCEPT; done
    for i in tcp udp; do iptables -A OUTPUT -p $i --dport 53 -j ACCEPT; done
    #for i in tcp udp; do iptables -A FORWARD -p $i --dport 53 -j ACCEPT; done
    #SAMBA
    for i in 1 2 3; do iptables -A INPUT -p udp -s 192.168.$i.0/24 --dport 137 -j ACCEPT; done
    for i in 1 2 3; do iptables -A INPUT -p udp -s 192.168.$i.0/24 --dport 138 -j ACCEPT; done
    for i in 1 2 3; do iptables -A INPUT -p tcp -s 192.168.$i.0/24 --dport 139 -j ACCEPT; done
    for i in 1 2 3; do iptables -A INPUT -p tcp -s 192.168.$i.0/24 --dport 445 -j ACCEPT; done
    #NFS
    for i in tcp udp; do iptables -A INPUT -p $i -s 192.168.1.252 --dport 2049 -j ACCEPT; done
    #LAN FREE
    #iptables -A OUTPUT -p tcp -s 192.168.1.0/24 -j ACCEPT
    #iptables -A OUTPUT -p udp -s 192.168.1.0/24 -j ACCEPT
    #ICMP
    iptables -A INPUT -p icmp -j ACCEPT
    iptables -A OUTPUT -p icmp -j ACCEPT
    #STATE RETURN
    for i in INPUT FORWARD OUTPUT; do iptables -A $i -m state --state ESTABLISHED,RELATED -j ACCEPT; done
    Citação Postado originalmente por GuE Ver Post
    Cara eu acho que estas regras estao erradas eu tenho aqui assim:
    iptables -t nat -A POSTROUTING -o $ETH -s $REDE_INTERNA -j MASQUERADE
    for i in INPUT FORWARD OUTPUT; do iptables -P $i ACCEPT; done
    Mais ae minha politica default fica tudo accept, preciso de drop default, vlw !!!
    Não cara.. só deixa ACCEPT a política OUTPUT
    Não posso liberar todas as portas free se não povo vai começar a usar torrent, msn essas coisas, so quero descobrir pq não navega na web sendo que output na 80 e 443 ta accept, vlw !!!
    Padrão DICA
    Caro colega...
    Vou lhe dar a dica do ano..
    Ao vez de você sair por aii dando um monte de ACCEPT, DROP ou REJECT
    Faz o seguinte...
    Dê os ACCEPT que você tem q dar....
    e depois utilize essa regra
    iptables -A INPUT -p tcp --syn -j DROP
    Essa regra rejeita tudo que você não "Liberou" ou seja... vc nao deu ACCEPT na porta 22... ninguem vai conseguir fazer um SSH.. .OK
    Apenas essa regrinha resolve seu problema...
    Abraços espero ter ajudado.
    By: Jonas Maciel
    MSN: [email protected]
    Quero minha politica drop so queria uma resposta pq não navega só isso com a regra accept
    Dropa tudo
    /sbin/iptables -P INPUT DROP
    /sbin/iptables -P FORWARD DROP
    /sbin/iptables -P OUTPUT DROP
    masquerade
    /sbin/iptables -A FORWARD -s $REDEINTERNA -j ACCEPT
    /sbin/iptables -A FORWARD -d $REDEINTERNA -j ACCEPT
    /sbin/iptables -t nat -A POSTROUTING -o $ETHEXTERNO -s $REDEINTERNA -j MASQUERADE
    para que complicar o que é simples, o que o lovenique falou é o que uso mais simples que isso não tem.
    uma maneira bem simples é como o magnusrk8 comentou...
    eu apenas uso 1 coisinha diferente, a policy de OUTPUT está em ACCEPT....
    iptables -t nat -A POSTROUTING -s REDE_INTERNA -o eth0 -j MASQUERADE
    essas 2 regras são o mínimo que permite vc acessar, o resto vc vai incrementando....
    abçs
    Se eu deixa output accept pessoal vai bombar torrent p2p msn, ae fica osso, mais ate agora ninguem me explico pq eu dando accpet no output na porta 80 nçao navega falta algo ?
    O teu MASQUERADE esta errado..
    Bloqueia os protocolos, listas de servidores.. portas.. dessas aplicações.. e libera as saida..
