  1. Citação Postado originalmente por starsat Ver Post
    alguem sabe como fazer web proxy na versao 4.3 .. eu estava com a versao 3.30 e notei essa noite q o HIT no proxy esta 0 sem numeros ..nao esta fufando
    CACHE
    Chain=output ,protocol=tcp ,Scr pot=3128 content=x-cache:hit ,Action=mark connection,new connection mark=Cache-connection
    passthrougt =yes
    Chain=output ,Connection mark=Cache-connection Action=mark packet,new packet mark=Cache-packet
    passthough=yes
    Chain=forward Action=mark connection, new connectionmark=connection-bytes=1000000-0
    web proxy sentings
    Src address: 192.168.0.1
    port :3128
    cache Administrador:webmaster
    max:cache size 200800kib hd ativo
    queue CACHE FULL
    parent>global-out
    packet marks:cache-packe
    queue type:ethernet-default
    priority=8
    max limit= 130M
    alguem sabe aonde muda na versao 4.3 ??
    JA DESCOBRI COMO FAZ NO 4.3 FUNFA ..
    NA OPPÇAO ADVANCE VAI EM DSCP (TOS) AKI EU COLOQUEI 48
    passthrougt =yes
    web proxy sentings
    port :3128
    CACHE HIT DSCP(TOS) (IGUAL O NUMERO DO ADVANCE) 48
    AI FUNCIONOU AKI OS HITS estao andando
    Olá amigo
    Voce usa o proxy no MK mesmo? ou usa squid?
    Se for no MK tenta colocar TOS = 4
    uma dica valew t+
  2. /ip proxy
    set always-from-cache=no cache-administrator=CentralNet cache-hit-dscp=4 cache-on-disk=yes enabled=yes max-cache-size=30720000KiB max-client-connections=5000 \
    max-fresh-time=12h max-server-connections=5000 parent-proxy=0.0.0.0 parent-proxy-port=0 port=9090 serialize-connections=no src-address=0.0.0.0
    /ip proxy access
    add action=deny comment=public-MSN disabled=no path=*ADSAdClient31.dll* redirect-to=10.10.50.100/dev/index.htm
    add action=deny comment=www.google.com.br disabled=no path=*/pt-BR_br/images/logo.gif* redirect-to=10.10.50.100/dev/index-google.jpg
    add action=deny comment="" disabled=no path=*watch_header.jpg* redirect-to=10.10.50.100/dev/index-google.jpg
    add action=deny comment=www.eco4planet.com/pt/ disabled=no path=*/all/eco.gif* redirect-to=10.10.50.100/dev/index-googlen.jpg
    add action=allow comment="Allow access da rede 10.10.50.0/24" disabled=no src-address=10.10.50.0/24
    add action=deny comment="Deny other" disabled=no
    /ip proxy cache
    add action=deny comment="" disabled=no path=*cgi-bin*
    add action=deny comment="" disabled=no dst-host=*caixa.gov.br*
    essas sao regras que tenho um cliente que esta com a versao 4.3 funcionando perfeitamente!!!
    contato: leo_h3@hotmail.com ou leonardo@leonardocosta.com.br
Nome:	         imagem.JPG
Visualizações:	236
Tamanho: 	168,9 KB
  3. isso ai perfeito
  4. Citação Postado originalmente por vie190 Ver Post
    =amigo eu e varios amigos provedores que conheço esta com mesmo problema .,,.
    =apos mudar para versao 4.3 não consigo fazer rodar web-proxy .,,.ja tentei varias vezes ,e varias fórum e site e ajuda de amigos que tambem são provedores ,, não rodooo .,,.
    =e para resolver aqui eu voltei o servidor com versão antiga ate que um amigo de verdade que queira ajudar poste aqui.
    =pois com certeza tem amigos aqui que sabe ,,
    =mais percebemos que eles aparecem para criticar e passar regras pela metade quando alguem ( iniciante como nos) tenta ajudar .,.,
    =quem sabe e quer ajudar passa ai onde estamos errando pois tem muitos aqui com este mesmo problema .,
    ====estamos aguardando ansiosamente pesquisando,errando,perdendo tempo,deixando clientes loucos com a net caindo .,.,.,mais sem perder a esperança que este é um lugar (under-linux) onde os companheiros de profissão querem ajudar um aos outros e compartilhar problemas e solução ate que alguem que sabe como resolver poste aqui a solução,,.,.,.
    denovooajudaaeoo0!!
    fiz os teste aqui e ta rodando,.
    usei a configuração acima que e semelhante a versao 2.9,so mudei o seguinte
    ip-webproxy-cache hit dscp(tos)4
    e tambem no ip-firewall-mangle-advanced-dscp(tos)4
    ta funfando perfeito,..,
    so tenho uma duvida no webproxy o requests ta muito alto e sempre subindo,., é normal na versao 4.4 ??????????????
  5. Citação Postado originalmente por leo_h3 Ver Post
    Cara, você gasta um tempo do caramba criando regras, filtros, arrumando uma máquina "boa" (HD, RAM, MoBo, etc) para depois enfiar uma porcaria de script para limpar o cache?
    O maior patrimônio de um web-proxy é o seu cache, e assim que ele cresce um pouquinho e começa a representar um benefício real para a rede você vai lá e apaga?
    Idéia de girico isso, né não?
    Agora se quiser apenas fazer filtros http e ftp, a história é outra e não precisaria das configurações apresentadas.
  1. Como se monta web proxy na versao 3.13
    Por mpsnet no fórum Redes
    Último Post: 05-12-2009, 15:07
  2. web-proxy na versao 3.11
    Por nandop1240 no fórum Redes
    Respostas: 30
    Último Post: 14-08-2008, 22:58
  3. Para o Web-Proxy na RP problema
    Por EdilsonLSouza no fórum Redes
    Último Post: 19-03-2008, 23:43
  4. Web proxy na versao 3.1
    Por betosjp no fórum Redes
    Último Post: 30-01-2008, 00:40
  5. Ativar Web Proxy Na Versao 2.8
    Por socrateschalkidis no fórum Redes
    Último Post: 29-03-2007, 00:29
