  1. então para ficar mais fácil instalai de volta o server 10.04
    bom meu fstab está assim:
    novaf@ubuntu:~$ cat /etc/fstab
    # /etc/fstab: static file system information.
    # Use 'blkid -o value -s UUID' to print the universally unique identifier
    # for a device; this may be used with UUID= as a more robust way to name
    # devices that works even if disks are added and removed. See fstab(5).
    # <file system> <mount point> <type> <options> <dump> <pass>
    proc /proc proc nodev,noexec,nosuid 0 0
    /dev/mapper/sil_bgahdiccejcc1 / ext4 errors=remount-ro 0 1
    /dev/mapper/sil_bgahdiccejcc2 none swap sw 0 0
    meu grub.cfg está assim:
    menuentry 'Ubuntu, with Linux 2.6.32-21-server' --class ubuntu --class gnu-linux --class gnu --class os {
    recordfail
    insmod ext2
    set root='(hd2,1)'
    search --no-floppy --fs-uuid --set cd223f81-3eeb-43f9-a70a-d5239e6f1c4e
    linux /boot/vmlinuz-2.6.32-21-server root=UUID=cd223f81-3eeb-43f9-a70a-d5239e6f1c4e ro quiet
    initrd /boot/initrd.img-2.6.32-21-server
    menuentry 'Ubuntu, with Linux 2.6.32-21-server (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
    recordfail
    insmod ext2
    set root='(hd2,1)'
    echo 'Loading Linux 2.6.32-21-server ...'
    linux /boot/vmlinuz-2.6.32-21-server root=UUID=cd223f81-3eeb-43f9-a70a-d5239e6f1c4e ro single
    echo 'Loading initial ramdisk ...'
    meu /dev/mapper está assim:
    novaf@ubuntu:/boot/grub$ ls -l /dev/mapper/
    total 0
    crw-rw---- 1 root root 10, 59 2010-07-26 16:01 control
    brw-rw---- 1 root disk 251, 0 2010-07-26 16:01 sil_bgahdiccejcc
    brw-rw---- 1 root disk 251, 1 2010-07-26 16:01 sil_bgahdiccejcc1
    brw-rw---- 1 root disk 251, 2 2010-07-26 16:01 sil_bgahdiccejcc2
    eu preciso alterar algo?lembrando que no grub2 não posso alterar o grub.cfg e sim o arquivo: /etc/default/grub
    que tem dentro:
    GRUB_DEFAULT=0
    GRUB_HIDDEN_TIMEOUT=0
    GRUB_HIDDEN_TIMEOUT_QUIET=true
    GRUB_TIMEOUT=10
    GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
    GRUB_CMDLINE_LINUX_DEFAULT="quiet"
    GRUB_CMDLINE_LINUX=""
    # Uncomment to disable graphical terminal (grub-pc only)
    #GRUB_TERMINAL=console
    # The resolution used on graphical terminal
    # note that you can use only modes which your graphic card supports via VBE
    # you can see them in real GRUB with the command `vbeinfo'
    #GRUB_GFXMODE=640x480
    # Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
    #GRUB_DISABLE_LINUX_UUID=true
    # Uncomment to disable generation of recovery mode menu entries
    #GRUB_DISABLE_LINUX_RECOVERY="true"
    # Uncomment to get a beep at grub start
    #GRUB_INIT_TUNE="480 440 1"
    Última edição por lfernandosg; 26-07-2010 às 15:20.
  1. raid Via Hardware nivel 1
    Por amsyss no fórum Servidores de Rede
    Último Post: 21-06-2006, 07:55
  2. raid Via Hardware nivel 1
    Último Post: 25-05-2006, 17:32
  3. RAID via Software ou Via HARDWARE ??
    Por H_Franzin no fórum Servidores de Rede
    Respostas: 5
    Último Post: 25-05-2006, 14:50
  4. raid via hardware
    Último Post: 23-05-2006, 15:26
  5. Raid via Hardware
    Por Edson Tadeu no fórum Sistemas Operacionais
    Último Post: 21-03-2005, 13:05
