  1. fiz as modificações, e ainda da o erro: (tentando acessar pelo pgadmin3 num micro da rede)
    "Server doesn´t listen
    The server doesn't accept connections: the connection library reports
    could not connect to server: Connection refused (0x0000274D/10061) Is the server running on host "192.168.10.1" and accepting TCP/IP connections on port 5432?
    já tentei de tudo, modifiquei umas 200 vezes os config.
    criei uma maquina virtual aqui, e testei nela, a mesma porcaria.
    Parece que ele fica escutando só no "localhost".
    To desesperado já
  2. vo te mandar o meu pg_hba.conf que foi apenas o que eu mudei deixa ele assim e desfaz alguma alteração que tu tenhas feito, e deixe com essa config, pq aqui funciona tranquilamente.
    # PostgreSQL Client Authentication Configuration File
    # Refer to the "Client Authentication" section in the
    # PostgreSQL documentation for a complete description
    # of this file. A short synopsis follows.
    # This file controls: which hosts are allowed to connect, how clients
    # are authenticated, which PostgreSQL user names they can use, which
    # databases they can access. Records take one of these forms:
    # local DATABASE USER METHOD [OPTION]
    # host DATABASE USER CIDR-ADDRESS METHOD [OPTION]
    # hostssl DATABASE USER CIDR-ADDRESS METHOD [OPTION]
    # hostnossl DATABASE USER CIDR-ADDRESS METHOD [OPTION]
    # (The uppercase items must be replaced by actual values.)
    # The first field is the connection type: "local" is a Unix-domain socket,
    # "host" is either a plain or SSL-encrypted TCP/IP socket, "hostssl" is an
    # SSL-encrypted TCP/IP socket, and "hostnossl" is a plain TCP/IP socket.
    # DATABASE can be "all", "sameuser", "samerole", a database name, or
    # a comma-separated list thereof.
    # USER can be "all", a user name, a group name prefixed with "+", or
    # a comma-separated list thereof. In both the DATABASE and USER fields
    # you can also write a file name prefixed with "@" to include names from
    # a separate file.
    # CIDR-ADDRESS specifies the set of hosts the record matches.
    # It is made up of an IP address and a CIDR mask that is an integer
    # (between 0 and 32 (IPv4) or 128 (IPv6) inclusive) that specifies
    # the number of significant bits in the mask. Alternatively, you can write
    # an IP address and netmask in separate columns to specify the set of hosts.
    # METHOD can be "trust", "reject", "md5", "crypt", "password",
    # "krb5", "ident", "pam" or "ldap". Note that "password" sends passwords
    # in clear text; "md5" is preferred since it sends encrypted passwords.
    # OPTION is the ident map or the name of the PAM service, depending on METHOD.
    # Database and user names containing spaces, commas, quotes and other special
    # characters must be quoted. Quoting one of the keywords "all", "sameuser" or
    # "samerole" makes the name lose its special character, and just match a
    # database or username with that name.
    # This file is read on server startup and when the postmaster receives
    # a SIGHUP signal. If you edit the file on a running system, you have
    # to SIGHUP the postmaster for the changes to take effect. You can use
    # "pg_ctl reload" to do that.
    # Put your actual configuration here
    # If you want to allow non-local connections, you need to add more
    # "host" records. In that case you will also need to make PostgreSQL listen
    # on a non-local interface via the listen_addresses configuration parameter,
    # or via the -i or -h command line switches.
    # TYPE DATABASE USER CIDR-ADDRESS METHOD
    # IPv4 local connections:
    host all all 127.0.0.1/32 md5
    host all all 192.168.0.0/24 md5
    # IPv6 local connections:
    #host all all ::1/128 md5
  3. Valeu fogaça.
    Não funcionou ainda, he he.
    Será que tu poderia me passar o postgresql.conf e a regra do iptables para liberar a porta?? porque realmente eu nao entendo o que estou fazendo errado.
    Obs. do teu arquivo original pg_hba.conf só mudei a o endereço 192.168.0.0 de acordo com minha rede.
    Mais ainda recebo a mesma mens de erro, quando tento acessar de um micro da rede.
    Muito Obrigado pela ajuda até agora
  4. me passa seu email que lhe mando meu arquivo postgresql.conf
  5. Consegui solucionar Paulo!
    O problema era que eu tava criando um backup da pasta "/etc/postgresql/8.3/main" como "/etc/postgresql/8.3/main.default" com os arquivos padrão.
    E ao reiniciar o serviço, ele carregava tb esse main.default!!!!. disgraça....
    Fica a dica ai, se alguem fizer a mesma burrice
    Muito Obrigado pela ajuda Paulo!, as tuas dicas me ajudaram um monte tb!
    Valeu!
  1. Problemas com firewall/proxy Debian Lenny!
    Por kzeninmafia no fórum Servidores de Rede
    Último Post: 22-03-2009, 22:04
  2. Respostas: 0
    Último Post: 10-09-2008, 08:40
  3. problemas com postgreSql
    Por perdiga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 10-11-2005, 12:47
  4. problemas com placa de rede rtl8139 no debian
    Por nathan_levy no fórum Sistemas Operacionais
    Último Post: 12-04-2004, 08:04
  5. Problemas com o make instalando Postgresql 7.3.2
    Por LenTu no fórum Linguagens de Programação
    Último Post: 13-11-2003, 13:22
