    Padrão Novo Firmware 5.2.1 para Nanostation 5M.
    bom galera saiu o novo firmware do air Os para nano5M atualizei e o ganho foi significativo testado e aprovado.
    Version 5.2.1 - Service Release (September 13, 2010)
    - New: Rocket M365 support
    - New: Rocket M900 support
    - New: NanoStation M365 support
    - New: NanoStation Loco M900 support
    Improvements/Change requests:
    - Improvement: DFS functionality enhancements
    - Improvement: Improve 10/5MHz channel width stability
    - Improvement: IGMP proxy
    - Improvement: Multicast traffic
    - CCR: Increase maximum allowed DHCP server lease time to 48h
    - CCR: Allow more than 128 associations with security off
    - CCR: Add GUI option to disable reset button. Prevents from accidental configuration reset to factory defaults
    Fixes:
    - Fix: AirMax: Packet loss just after client association to the AirMax AP
    - Fix: AirMax: STA Transmission Queue stuck, need a reset
    - Fix: AP wireless stops operating
    - Fix: Station stays connected to AP, but no wireless traffic is available
    - Fix: Multicast enhancement does not handle VLAN tagged traffic
    - Fix: AutoACK calculation issue specific for NanoBridge M5/AirGrid M5/NanoStation Loco M5 devices
    - Fix: AutoACK on AP calculates incorrect values to 802.11 b-only stations
    - Fix: Ipod iTouch freezes Internet connection for laptops, which have Intel wireless radios
    - Fix: AP is using the lowest TX rate (6Mbps), when communicating with 802.11 a/b/g Stations and using WEP/WPA-TKIP/WPA2-TKIP security
    - Fix: AP scans only upper or lower channels in 40 MHz channel width
    - Fix: AP(WDS) in 40 MHz channel width can connect AP(WDS) in 20 MHz channel width
    - Fix: MAC Address change in Station-Router mode results WPA failure
    - Fix: Devices behind STA-WDS in PtMP network, sometimes becomes unreachable
    - Fix: PowerAP N WLAN LED is not shining when RSSI level is less than 30
    - Fix: MAX EIRP 36dBm for 2.4GHz band in Australia
    - Fix: SNMP: Report correct IF-MIB interface speed OID values
    - Fix: AirView: Application does not return scan results on NanoBridge M2/NanoStation Loco M2
    - AirControl Agent: Restore console reporting after wireless association is restored
    - AirControl Agent: Report association time
    - AirControl Agent: Odd behavior with discovery response
    - AirControl Agent: Ping is not restoring connection when AirControl server is unreachable on startup
    - GUI fix: Status and Site survey pages fails to render if SSID has escape character(s)
    - GUI fix: Speed Test fails if using special symbols in password
    - GUI fix: Speed tests doesn't work if HTTPS port has been changed
    - GUI fix: When disabling scan list, previously selected channels are unchecked
    - GUI fix: new Chrome-BETA conflicts with Web UI validation framework
    - GUI fix: Fixed rates uses SGI(400 ns) rate table
    - GUI fix: Read only user can access device configuration file
    - GUI fix: Sometimes Station list is empty
    - GUI fix: Show static routes in Main page, when operating in Bridge mode
    - GUI fix: Special Char escaping required for SNMP settings
    - GUI fix: Destination IP field validation is missing
    Known issues:
    - Sometimes Station disassociates during WPA/WPA2 group key exchange
    http://www.ubnt.com/downloads/XM-v5.2.1.build6359.bin
    Downloads | Ubiquiti Networks, Inc.
    Padrão Re: Novo Firmware 5.2.1 para Nanostation 5M.
    É isso aí Grego, também gostei do novo Firmware.
    O tempo de ping ficou mais estável na maioria dos casos. Antigamente flutuava muito e dava a impressão errada de instabilidade do enlace.
    Abraço,
    ZéAlves
    fala ai meu amigo,outra coisa que notei foi q no modo airmax melhorou no desempenho nos tráficos altos ficou mais estável.
    Citação Postado originalmente por sostenes Ver Post
    Caramba, quanta coisa foi corrigida!!!
    Granlabor, lembra daquelas encrencas que eu estava enfrentando com os BulletM2? Acabei não retornando para você, um ip para entrar na rede e ver de perto.
    A coisa estava tão corrida que tiramos os bulletM2 e colocamos Nano2 até uma oportunidade melhor.
    Mas agora com este novo firmware parece que aquela leitura maluca de ACK foi corrigida.
    Vou atualizar e testar novamente semana que vem.
    Faça isso. Se persistir o problema e você quiser ajuda, é só chamar
    Abraço,
    ZéAlves
    Thumbs up Re: Novo Firmware 5.2.1 para Nanostation 5M.
    Com ctz a melhora é absolutamente indiscutível!
    Tive a prova disso hoje!
    Por azar do destino ao fechar um ptp de 14km com um par de nanobridge m5 esqueci de atualizar o firmware da ponta receptora!
    Tava eu aqui APANHANDO do enlace porque a visada não é SHOW sabe, essa distância acaba botando medo da gente fechar com nanobridge...Mas, enfim percebi a "cagada" que havia feito:
    Olhando no Ubiquiti Discovery Tool notei a diferença dos firmwares das duas pontas, ai saquei a burrada!
    Com muito esforço consegui entrar na ponta B e subir a atualização!
    Parece que troquei de antena...hahahaha
    Ping: 1ms
    Troughput: 13,45mbps
    AirMax: 50%
    Resumindo: Postarei os prints do enlace no tópico que abri sobre esse enlace...
    Mas quanta mudança de uma versão pra outra não?
    Troquei de antena é ótima
    Realmente o firmware estavel atual ajuda a solucionar muitos "problemas" do equipamento.
    Adorei esta versão...
