    Padrão Re: Fazer Roteamento como se fosse um cisco tem como?
    ultima tentativa vai no mikrotik entra em new treminal e digita, export file=arq depois vai em files e pega o arq e posta aqui o unico jeito de nao funcionar e ter alguma regra no mikrotik e nos vamos descobrir com este processo.
    Opa segue ai o texto...
    Olha analizando aqui sera que nao deveria colocar a porta em ip>services?
    # jan/22/1970 16:06:05 by RouterOS 4.10
    # software id = 31A5-M93F
    /interface bridge
    add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    comment="" disabled=no forward-delay=15s l2mtu=1524 max-message-age=20s \
    mtu=1500 name=bridge1 priority=0x8000 protocol-mode=none \
    transmit-hold-count=6
    /interface ethernet
    set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:72:35:23 \
    master-port=none mtu=1500 name="ether1 internet" speed=1Gbps
    set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:72:35:24 \
    master-port=none mtu=1500 name="ether2 server1" speed=1Gbps
    set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:72:35:25 \
    master-port=none mtu=1500 name="ether3 supercache" speed=1Gbps
    set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:72:35:26 \
    master-port=none mtu=1500 name=ether4 speed=1Gbps
    set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:72:35:27 \
    master-port=none mtu=1500 name=ether5 speed=100Mbps
    /interface ethernet switch
    set switch1 mirror-source=none mirror-target=none name=switch1
    /ip hotspot profile
    set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
    http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
    name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
    /ip hotspot user profile
    set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
    1 status-autorefresh=1m transparent-proxy=no
    /ip ipsec proposal
    set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
    /ppp profile
    set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
    set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
    only-one=default use-compression=default use-encryption=yes \
    /queue type
    set default kind=pfifo name=default pfifo-limit=50
    set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
    set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
    set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
    set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
    set default-small kind=pfifo name=default-small pfifo-limit=10
    /routing bgp instance
    set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
    /routing ospf instance
    set default comment="" disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
    auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
    /routing ospf area
    set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=\
    backbone type=default
    /snmp
    set contact="" enabled=no engine-boots=0 engine-id="" location="" \
    time-window=15 trap-sink=0.0.0.0 trap-version=1
    /snmp community
    set public address=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
    /system logging action
    set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
    set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
    set echo name=echo remember=yes target=echo
    set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
    /system routerboard settings
    set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    680MHz force-backup-booter=no silent-boot=no
    /user group
    add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
    word,web,sniff,sensitive,!ftp,!write,!policy"
    add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
    ox,password,web,sniff,sensitive,!ftp,!policy"
    add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
    ,test,winbox,password,web,sniff,sensitive"
    /interface bridge port
    add bridge=bridge1 comment="" disabled=no edge=auto external-fdb=auto \
    horizon=none interface="ether1 internet" path-cost=10 point-to-point=auto \
    priority=0x80
    horizon=none interface="ether2 server1" path-cost=10 point-to-point=auto \
    priority=0x80
    horizon=none interface="ether3 supercache" path-cost=10 point-to-point=\
    auto priority=0x80
    horizon=none interface=ether4 path-cost=10 point-to-point=auto priority=\
    0x80
    /interface bridge settings
    set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
    /interface ethernet switch port
    set (unknown) vlan-header=leave-as-is vlan-mode=fallback
    /interface l2tp-server server
    set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
    /interface ovpn-server server
    set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:2F:23:62:71:8D \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
    /interface pptp-server server
    set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
    /ip accounting
    set account-local-traffic=no enabled=no threshold=256
    /ip accounting web-access
    set accessible-via-web=no address=0.0.0.0/0
    /ip address
    add address=187.17.143.xxx/30 broadcast=187.17.143.xxx comment="" disabled=no \
    interface="ether1 internet" network=187.17.143.xxx
    add address=187.17.130.xxx/25 broadcast=187.17.130.255 comment="" disabled=no \
    interface=bridge1 network=187.17.130.xxx
    /ip dhcp-server config
    set store-leases-disk=5m
    /ip dns
    set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512
    /ip dns static
    add address=189.36.129.1 comment="" disabled=yes name=1 ttl=1d
    /ip firewall connection tracking
    set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall nat
    add action=dst-nat chain=dstnat comment="" disabled=yes dst-port=0-65535 \
    protocol=tcp to-addresses=187.17.130.129 to-ports=0-65535
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=1,63333
    set pptp disabled=no
    /ip hotspot service-port
    /ip neighbor discovery
    set "ether1 internet" discover=yes
    set "ether2 server1" discover=yes
    set "ether3 supercache" discover=yes
    set ether4 discover=yes
    set ether5 discover=yes
    set bridge1 discover=yes
    /ip proxy
    set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
    /ip route
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    187.17.143.xxx scope=30 target-scope=10
    /ip service
    set telnet address=0.0.0.0/0 disabled=no port=23
    set ftp address=0.0.0.0/0 disabled=no port=21
    set www address=0.0.0.0/0 disabled=no port=80
    set ssh address=0.0.0.0/0 disabled=no port=541
    set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
    set api address=0.0.0.0/0 disabled=yes port=8728
    set winbox address=0.0.0.0/0 disabled=no port=8180
    Última edição por hardboot; 28-10-2010 às 09:10.
    /ip socks
    set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
    /ip traffic-flow
    set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
    /ip upnp
    set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
    /mpls
    set dynamic-label-range=16-1048575 propagate-ttl=yes
    /mpls interface
    add comment="" disabled=no interface=all mpls-mtu=1508
    /mpls ldp
    set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
    /ppp aaa
    set accounting=yes interim-update=0s use-radius=no
    /queue interface
    set "ether1 internet" queue=ethernet-default
    set "ether2 server1" queue=ethernet-default
    set "ether3 supercache" queue=ethernet-default
    set ether4 queue=ethernet-default
    set ether5 queue=ethernet-default
    set bridge1 queue=default
    /radius incoming
    set accept=no port=3799
    /routing bfd interface
    set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec \
    multiplier=5
    /routing mme
    set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
    /routing rip
    set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
    /store
    add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
    /system clock
    set time-zone-name=manual
    /system clock manual
    set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
    /system console
    add disabled=no term=vt102
    /system health
    set
    /system identity
    set name=MikroTik
    /system logging
    add action=memory disabled=no prefix="" topics=info
    add action=memory disabled=no prefix="" topics=error
    add action=memory disabled=no prefix="" topics=warning
    add action=echo disabled=no prefix="" topics=critical
    /system note
    set note="" show-at-login=yes
    /system ntp client
    set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
    /system upgrade mirror
    set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
    /system watchdog
    set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
    /tool bandwidth-server
    set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
    /tool e-mail
    set from=<> password="" server=0.0.0.0:25 username=""
    /tool graphing
    set page-refresh=300 store-every=5min
    /tool mac-server
    add disabled=no interface=all
    /tool mac-server ping
    set enabled=yes
    /tool sms
    set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
    /tool sniffer
    set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
    yes interface=all memory-limit=10 memory-scroll=no only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
    /user aaa
    set accounting=yes default-group=read interim-update=0s use-radius=no
    Tira a porta ether1 da bridge!
    foi tirada... e continua na mesma, acho que deve ser problema do meu link com a operadora pq nao tem explicação....
    Padrão Re: Fazer roteamento como se fosse um cisco tem como?
    Camarada, vc ja resolveu este problema???
    kra nao consegui mais nada e deixei queto.....
    Olha a meu entender a posição do seu servidor de cache é que ta errada, ele deveria estar diretamente ligado ao seu server hostpost, via uma 3º interface.
    Ai sim esse IP final 129 ficaria somente no servidor hostpost e portanto mais facil de vc trabalhar.
    Brito
    Bem o esquema de meu Cache é diferente ele precisa estar, atrás do server hostpost, e so funciona com uma placa de rede...
    Sendo assim depois de bater um pouco a cabeça e nao ter suporte do mesmo, resovi abandonalo e aumentar meu link.
    Agora toda vez, que precisar eu aumento o link ao inves de ficar picaretiando essas coisas.
