  1. Como nao tenho acesso total ao meu roteador q nao é meu e sim alugado, apenas um show das interfaces, para o povo entender oq é soma... isso é aqui no meu e com certeza na ponta da operadora a mesma coisa.
    FastEthernet0/0 is up, line protocol is up
    Hardware is Gt96k FE, address is 001d.70eb.c51e (bia 001d.70eb.c51e)
    Description: *** CONEXAO COM LAN ***
    Internet address is 200.xxx.xxx.xxx/xx
    MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
    reliability 255/255, txload 4/255, rxload 1/255
    Encapsulation ARPA, loopback not set
    Keepalive set (10 sec)
    Full-duplex, 100Mb/s, 100BaseTX/FX
    ARP type: ARPA, ARP Timeout 04:00:00
    Last input 00:00:00, output 00:00:00, output hang never
    Last clearing of "show interface" counters never
    Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
    Queueing strategy: fifo
    Output queue: 0/40 (size/max)
    30 second input rate 614000 bits/sec, 328 packets/sec
    30 second output rate 1905000 bits/sec, 263 packets/sec
    250682852 packets input, 1560743282 bytes
    Received 113453 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 watchdog
    0 input packets with dribble condition detected
    290050403 packets output, 3286867795 bytes, 0 underruns
    0 output errors, 0 collisions, 2 interface resets
    0 babbles, 0 late collision, 0 deferred
    0 lost carrier, 0 no carrier
    0 output buffer failures, 0 output buffers swapped out
    Serial0/1/0 is up, line protocol is up
    Hardware is GT96K Serial
    Description: xxxx | 2048K | xxxxx | xxxx
    MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
    reliability 255/255, txload 36/255, rxload 112/255
    Encapsulation PPP, LCP Open, multilink Open
    Link is a member of Multilink bundle Multilink1, loopback not set
    CRC checking enabled
    Last input 00:00:00, output 00:00:06, output hang never
    Last clearing of "show interface" counters 2w2d
    30 second input rate 902000 bits/sec, 125 packets/sec
    30 second output rate 292000 bits/sec, 160 packets/sec
    143926683 packets input, 726035789 bytes, 0 no buffer
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    2626 input errors, 2626 CRC, 349 frame, 138 overrun, 0 ignored, 591 abort
    124952908 packets output, 4245578659 bytes, 0 underruns
    0 carrier transitions
    DCD=up DSR=up DTR=up RTS=up CTS=up
    Serial0/1/1 is up, line protocol is up
    Description: xxxxx | 2048K | xxxxxx |
    Last input 00:00:00, output 00:00:07, output hang never
    30 second input rate 902000 bits/sec, 124 packets/sec
    30 second output rate 293000 bits/sec, 160 packets/sec
    143903451 packets input, 735675197 bytes, 0 no buffer
    2651 input errors, 2651 CRC, 351 frame, 125 overrun, 0 ignored, 617 abort
    124904011 packets output, 4245601105 bytes, 0 underruns
    Serial0/2/0 is down, line protocol is up
    reliability 255/255, txload 1/255, rxload 1/255
    Encapsulation PPP, LCP Closed, multilink Closed, loopback not set
    Last input 2w2d, output 1w6d, output hang never
    30 second input rate 0 bits/sec, 0 packets/sec
    30 second output rate 0 bits/sec, 0 packets/sec
    697351 packets input, 497227582 bytes, 0 no buffer
    10687 input errors, 10687 CRC, 4766 frame, 2725 overrun, 0 ignored, 8017 abort
    680118 packets output, 131932149 bytes, 0 underruns
    0 output errors, 0 collisions, 49827 interface resets
    3 carrier transitions
    DCD=down DSR=down DTR=up RTS=up CTS=down
    Serial0/2/1 is down, line protocol is up
    Description: XXXXX | 2048K | XXXXXXX |
    reliability 215/255, txload 1/255, rxload 1/255
    Last input never, output 1w6d, output hang never
    0 packets input, 0 bytes, 0 no buffer
    8211 input errors, 8211 CRC, 3507 frame, 2013 overrun, 0 ignored, 6255 abort
    39844 packets output, 1035944 bytes, 0 underruns
    0 output errors, 0 collisions, 50571 interface resets
    Multilink1 is up, line protocol is up
    Hardware is multilink group interface
    Description: "conexao com a EMBRATEL"
    Internet address is xxx.xxx.xxx.xx/30
    MTU 1500 bytes, BW 8192 Kbit, DLY 100000 usec,
    reliability 255/255, txload 17/255, rxload 63/255
    Listen: CDPCP
    Open: IPCP, loopback not set
    DTR is pulsed for 2 seconds on reset
    Last input 00:00:51, output never, output hang never
    Input queue: 0/75/8/0 (size/max/drops/flushes); Total output drops: 278
    5 minute input rate 2032000 bits/sec, 268 packets/sec
    5 minute output rate 565000 bits/sec, 309 packets/sec
    287973064 packets input, 222810741 bytes, 0 no buffer
    118 input errors, 0 CRC, 1 frame, 0 overrun, 1 ignored, 0 abort
    248672389 packets output, 23530838 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
  2. Bwqeom,
    É até legal ouvir uns besteirol de vez em quando, o problema é que o kara que fez a junção de balanceamento apenas confundiu a palavra BALANCEAMENTO com a a palavra JUNÇÃO. Até poss compreender o motivo final, que seria a soma total, isso da pra fazer sim, mas precisa usar um sistema de roteamento realmente balanceado, seja por bonding nas duas interfaces, ou por roteamento balanceado, na primeira opcao o link realmente junta e soma-se a velocidade, ficando 2+2=4. Ja na segunda opcao, é possivel sim balancear as requisições, então, o jpg vem de uma origem, o texto de outra, o flash de outra, e assim, na ponta do cliente, não há diferença de origem, dando a impressão final que a velocidade dobrou, que na realidade dobrou mesmo. O problema esta em dobrar de velocidade em um download unico, ai quero ver o pai de santo que faz isso e pedir a bencao dele, uahahahahhahaa
  3. Aooo Narguileee na veia do povo rss.... kd o "UNO"....
  4. AMIGOS PIOR QUE TEM EMPRESAS POR AI VENDEDNO ROTEADORES COM ESTAS PROMESSAS DE SOMA DE LINK ISSO E O FIM .....(QT PICARETAGEM) O ROTEADOR DEVE VIM COM 2 FIBRAS PRA VC IR BUSCAR OS LINK RSRSRRS
  5. Amigo flavioleonel acho q vc esta enganado, é atravez das operadoras q é possivel a soma, se vc ver no meu post anterior e de outro colega, foi tirado de um roteador da operadora, no meu caso da Embratel...
  1. Respostas: 79
    Último Post: 30-03-2012, 15:52
  2. Respostas: 10
    Último Post: 05-07-2008, 13:31
  3. Respostas: 10
    Último Post: 05-04-2006, 07:07
  4. socorro perda da senha do root
    Por cyberniro no fórum Servidores de Rede
    Último Post: 25-04-2003, 13:42
  5. Agora eh pelo amor da perpetua socorro!!!
    Último Post: 15-01-2003, 00:44
