  1. Formtar para ext3 é uma opção, mas existem muitos gigas de arquivos lá e se o problema não for esse?
    Vejam o arquivo do samba
    A pasta teste funciona normalmente e está no hd com linux, ja as pastas Musicas, HD1Tera estão nos outros hds.
    A pasta Media, ele acessa, mostra as pastas Musicas e Servidor, mas ao acessá-los da erro!
    Código :
    global]
        workgroup = TUDO_LOKO
        passdb backend = tdbsam
        printing = cups
        printcap name = cups
        printcap cache time = 750
        cups options = raw
        map to guest = Bad User
        include = /etc/samba/dhcp.conf
        logon path = \\%L\profiles\.msprofile
        logon home = \\%L\%U\.9xprofile
        logon drive = P:
        usershare allow guests = Yes
        usershare max shares = 100
        wins support = Yes
        security = domain
    [homes]
        comment = Home Directories
        valid users = %S, %D%w%S
        browseable = No
        read only = No
        inherit acls = Yes
    [profiles]
        comment = Network Profiles Service
        path = %H
        read only = No
        store dos attributes = Yes
        create mask = 0600
        directory mask = 0700
    [users]
        comment = All users
        path = /home
        read only = No
        inherit acls = Yes
        veto files = /aquota.user/groups/shares/
    [groups]
        comment = All groups
        path = /home/groups
        read only = No
        inherit acls = Yes
    [printers]
        comment = All Printers
        path = /var/tmp
        printable = Yes
        create mask = 0600
        browseable = No
    [print$]
        comment = Printer Drivers
        path = /var/lib/samba/drivers
        write list = @ntadmin root
        force group = ntadmin
        create mask = 0664
        directory mask = 0775
    [Publico]
        comment = Diretorio Publico
        patch = /home/server/Documentos/Publico
        security = share
        public = yes
        writable = yes
        read only = no
        security = server
        available = yes
        browseable = yes
        guest only = no
        only user = no
    [Teste]
        inherit acls = Yes
        path = /home/server/Documentos/Publico
        read only = No
        guest only = Yes
    [HD1Tera]
        guest ok = Yes
        guest only = Yes
        inherit acls = Yes
        path = /run/media/server/Servidor
        read only = No
    [Musicas]
        guest ok = Yes
        inherit acls = Yes
        path = /run/media/server/Musicas
        read only = No
        security = share
        guest only = Yes
    [blablabla]
        inherit acls = Yes
        path = /dev/sdc6
        read only = No
        guest only = Yes
    [Media]
        guest only = Yes
        inherit acls = Yes
        path = /run/media
        read only = No
        create mask = 777
        directory mask = 777
        force create mode = 777
        force directory mode = 777
  2. Formatei um dos HDs para ext4 e acontece o mesmo erro!
    Não acessa =\
    Então presumo que o problema não seja o NTFS e sem que eles estão em HDs separados.
    Alguém já passou por isso?
    De inicio o acesso ao servidor é publico, todas as pastas liberadas, o bloqueio por usuários será feito mais pra frente!
  3. até agora não consegui resolver este problema. Alguém ai já passou por algo parecido?
  4. [global] workgroup = TUDO_LOKO
    printing = cups
    cups options = raw
    logon drive = P:
    wins support = Yes
    security = share
    [homes]
    comment = Home
    Directories valid users = %S, %D%w%S
    browseable = No
    read only = No
    inherit acls = Yes
    [profiles]
    path = %H
    read only = No
    create mask = 0600
    [users]
    comment = All users
    path = /home
    read only = No
    inherit acls = Yes
    [groups]
    path = /home/groups
    read only = No
    inherit acls = Yes
    [printers]
    comment = All
    Printers path = /var/tmp
    printable = Yes
    create mask = 0600
    browseable = No
    [print$]
    root force group = ntadmin
    create mask = 0664
    [Publico] comment = Diretorio
    Publico patch = /home/server/Documentos/Publico
    ## security = share (duplicado)
    public = yes
    writable = yes
    read only = no
    ## security = server (vc já definiu o security no global)
    available = yes browseable = yes
    # guest only = no# only user = no
    [Teste]
    inherit acls = Yes
    read only = No
    guest only = Yes
    [HD1Tera]
    guest ok = Yes
    guest only = Yes
    inherit acls = Yes
    read only = No
    [Musicas]
    guest ok = Yes
    inherit acls = Yes
    read only = No
    guest only = Yes
    [blablabla]
    inherit acls = Yes
    path = /dev/sdc6 (vc esta usando o dispositivo direto sem montar o hd pro sistema ? monte esse hd num diretorio tipo /media/hd1 com o comando mount )
    read only = No
    guest only = Yes
    [Media]
    guest only = Yes
    inherit acls = Yes
    path = /run/media
    read only = No create
    mask = 777
    use o comando testparm para ver se tem algum erro de sintaxe no smb.conf e cola a saida dele pra mim
    Deixa eu te perguntar qual dos compartilhamentos estão nos hds em ntfs ? fiz algumas alterações rapidas no seu smb.conf se não funcionar vou montar outro para que vc analise com mais calma.
  5. outra opção é montar os hds NTFS com a opção cifs ex.:
    mount -t cifs /dev/HD /pasta_a_se_montar
    assim como o nosso amigo "Noir" ... também estou esperando a saída do testparm,
    que erro que da quando você tenta entrar no diretório através do cliente ?
    - - - Updated - - -
    Citação Postado originalmente por Lincoln Ver Post
    isso ai realmente vai ser um PDC ? ou esse vai agir em grupo de trabalho mesmo ?
  1. Cache em hd separado
    Por FernandodeDeus no fórum Redes
    Respostas: 17
    Último Post: 05-03-2009, 17:21
  2. erro após intalação em hd sata
    Por flipeexpl no fórum Sistemas Operacionais
    Último Post: 13-03-2007, 09:42
  3. 2 rh9 em hds diferentes na mesma maquina
    Por jhonatanw no fórum Servidores de Rede
    Último Post: 27-12-2005, 10:51
  4. Erro na Utilização do GTKMM - ProGramação em C++
    Por esales no fórum Linguagens de Programação
    Último Post: 04-04-2005, 09:52
  5. erro na instalacao. prob no HD?!?
    Por fuchsroter no fórum Sistemas Operacionais
    Último Post: 07-03-2005, 11:59
