  1. Boa Tarde Amigo!
    Estou tentando instalar o sistema porem o mesmo me reporta esse erro;
    [root@localhost ~]# ./install.sh root_mysql gpx1405net_mysql
    Parando o httpd: [ OK ]
    Iniciando o httpd: httpd: Could not reliably determine the server's fully qualified domain name, using localhost.localdomain for ServerName
    [ OK ]
    ----------- Install Magnus Billing Server: ----------
    Gerado cópia de trabalho para revisão 182.
    chown: usuário inválido: "asterisk:asterisk"
    ln: criando ligação simbólica "/etc/asterisk/sip_magnus_register.conf": Arquivo existe
    ln: criando ligação simbólica "/etc/asterisk/sip_magnus.conf": Arquivo existe
    ln: criando ligação simbólica "/etc/asterisk/sip_magnus_user.conf": Arquivo existe
    ln: criando ligação simbólica "/var/lib/asterisk/agi-bin/magnus": Arquivo existe
    ln: criando ligação simbólica "/var/www/html/billing/protected/commands/cron": Arquivo existe
    magnus.php
    ERROR 1045 (28000): Access denied for user 'root_mysql'@'localhost' (using password: YES)
    Pulou 'https://subversion.assembla.com/svn/billing_svn'
    Na revisão 182.
    Summary of conflicts:
    Skipped paths: 1
    exception 'CDbException' with message 'CDbConnection failed to open the DB connection: SQLSTATE[28000] [1045] Access denied for user '$1'@'localhost' (using password: YES)' in /var/www/html/billing/lib/yii/db/CDbConnection.php:364
    Stack trace:
    #0 /var/www/html/billing/lib/yii/db/CDbConnection.php(313): CDbConnection->open()
    #1 /var/www/html/billing/lib/yii/db/CDbConnection.php(291): CDbConnection->setActive(true)
    #2 /var/www/html/billing/lib/yii/base/CModule.php(372): CDbConnection->init()
    #3 /var/www/html/billing/lib/yii/base/CApplication.php(429): CModule->getComponent('db')
    #4 /var/www/html/billing/lib/yii/db/ar/CActiveRecord.php(609): CApplication->getDb()
    #5 /var/www/html/billing/lib/yii/db/ar/CActiveRecord.php(2275): CActiveRecord->getDbConnection()
    #6 /var/www/html/billing/lib/yii/db/ar/CActiveRecord.php(372): CActiveRecordMetaData->__construct(Object(Configuration))
    #7 /var/www/html/billing/protected/models/Configuration.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(6): CActiveRecord::model('Configuration')
    #8 /var/www/html/billing/protected/components/LoadConfig.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(6): Configuration::model()
    #9 /var/www/html/billing/protected/commands/UpdateMysqlCommand.php(9): Loadconfig->getConfig()
    #1 0 /var/www/html/billing/lib/yii/console/CConsoleCommandRunner.php(63): UpdateMysqlCommand->run(Array)
    #1 1 /var/www/html/billing/lib/yii/console/CConsoleApplication.php(88): CConsoleCommandRunner->run(Array)
    #1 2 /var/www/html/billing/lib/yii/base/CApplication.php(158): CConsoleApplication->processRequest()
    #1 3 /var/www/html/billing/cron.php(19): CApplication->run()
    #1 4 {main}Você tem mensagem nova de correio em /var/spool/mail/root
    Sendo que o usuario e senha root esta correto.. pois acesso o mysql normalmente ..
    Obrigado...
  2. Citação Postado originalmente por Acronimo Ver Post
    como podemos colocar troncos para saida, no caso precisarei de fxo ou posso contratar alguma minutagem de outra operadora, o que vc indica?
    ola, vc pode usar placas, gateways ou provedores voip, para cadastrar um tronco SIP, va ao menu troncos.
    - - - Atualizado - - -
    Citação Postado originalmente por rfm Ver Post
    É compatível com o elastix ???
    mesmo nunca tendo instalado em Elastix, acredito que funcione sem problema. Teste instalar e coloque suas duvidas no site www.magnussolution.com
  3. Citação Postado originalmente por MarceloGOIAS Ver Post
    Bom dia Magnus,
    Testou o sistema no Debian?
    ola, eu nunca usei Debian, sempre usei centos, mas pode instalar que vai funcionar sem duvidas, pois o Billing não faz nenhuma alteração no asterisk, nem no sistema. É praticamente portable.
    Só o script de instalação que seguro não vai funcionar.
    Se alguém quiser disponibilizar um server com Debian, posso ver de fazer um script para o Debian
    Att. Adilson Magnus
    Projeto Billing Livre
  4. Citação Postado originalmente por goplex Ver Post
    Boa Tarde Amigo!
    [ OK ]
    magnus.php
    Na revisão 182.
    Skipped paths: 1
    Stack trace:
    Obrigado...
    a 1º erro é sobre o usuario que vc instalou o asterisk, precisa ser user asterisk
    o 2º erro, mostra erro na conexao com o mysql, veja se o usuario root_mysql tem permiçao para criar tabelas
    3ª "exception 'CDbException' with message 'CDbConnection failed to open the DB connection: SQLSTATE[28000] [1045] Access denied for user '$1'@'localhost' (using password: YES)' in /var/www/html/billing/lib/yii/db/CDbConnection.php:364"
    Verifique que no arquivo /etc/asterisk/res_mysql.confeste configurado o acesso ao mysql corretamente.
  5. Citação Postado originalmente por magnus81 Ver Post
    Att. Adilson Magnus
    Posso liberar um de testes em 32 bits, me indique o que necessita e te ajudo a portar o script
    EDIT: se precisar de um em 64 bits ai só via VM, mas damos um jeito.
  1. Projeto para provedor de acesso via radio
    Por bluis no fórum Redes
    Respostas: 7
    Último Post: 04-06-2009, 21:34
  2. Servidor DNS para provedor de internet?
    Por alanvictorjp no fórum Servidores de Rede
    Último Post: 15-11-2007, 14:14
  3. Respostas: 1
    Último Post: 19-04-2007, 19:32
  4. MOVIDO: Assessoria para Implementação de VOIP!!!
    Por WhiteTiger no fórum Servidores de Rede
    Último Post: 09-08-2006, 14:51
  5. firewall para provedor de internet
    Por jrctec no fórum Servidores de Rede
    Respostas: 8
    Último Post: 03-06-2005, 18:28
