    Padrão Bgp com 3 link da mesma operadora
    Boa tarde,
    Pessoal a GVT não quer mais Fazer upgrade aqui na região mais está vendendo links de 100mb ai me patrão comprou 300mb 3x100mb. Como posso fazer para subir meu bgp pelos 3?
    Padrão Re: Bgp com 3 link da mesma operadora
    Configuração
    No Router A:
    # loopback interface
    /interface bridge add name=lobridge
    # addresses
    /ip address add address=1.1.1.1/24 interface=ether1
    /ip address add address=2.2.2.1/24 interface=ether2
    /ip address add address=3.3.3.1/24 interface=ether3
    /ip address add address=9.9.9.1/32 interface=lobridge
    # ECMP route to peer's loopback
    /ip route add dst-address=9.9.9.2/32 gateway=1.1.1.2,2.2.2.2,3.3.3.2
    # BGP
    /routing bgp instance set default as=65000
    /routing bgp add name=peer1 remote-address=9.9.9.2 remote-as=65000 update-source=lobridge
    No Router B:
    # addresses
    /ip address add address=1.1.1.2/24 interface=ether1
    /ip address add address=2.2.2.2/24 interface=ether2
    /ip address add address=3.3.3.2/24 interface=ether3
    /ip address add address=9.9.9.2/32 interface=lobridge
    /ip route add dst-address=9.9.9.1/32 gateway=1.1.1.1,2.2.2.1,3.3.3.1
    # BGP
    /routing bgp add name=peer1 remote-address=9.9.9.1 remote-as=65000 update-source=lobridge
    # a route to advertise
    /routing bgp network add network=4.4.4.0/24
    Resultados
    Checke esta BGP connection se esta estabelicida:
    [[email protected]] > /routing bgp peer print status
    Flags: X - disabled
    0 name="peer1" instance=default remote-address=9.9.9.1 remote-as=65000
    tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m
    ttl=255 in-filter="" out-filter="" address-families=ip
    update-source=lobridge default-originate=no remote-id=1.1.1.1
    local-address=9.9.9.2 uptime=28s prefix-count=0 updates-sent=1
    updates-received=0 withdrawn-sent=0 withdrawn-received=0 remote-hold-time=3m
    used-hold-time=3m used-keepalive-time=1m refresh-capability=yes
    as4-capability=yes state=established
    Route table no Router A:
    [[email protected]] > /ip route print
    Flags: X - disabled, A - active, D - dynamic,
    C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
    B - blackhole, U - unreachable, P - prohibit
    # DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTER...
    0 ADC 1.1.1.0/24 1.1.1.1 0 ether1
    1 ADC 2.2.2.0/24 2.2.2.1 0 ether2
    2 ADC 3.3.3.0/24 3.3.3.1 0 ether3
    3 ADb 4.4.4.0/24 r 9.9.9.2 200 ether1
    ether2
    4 ADC 9.9.9.1/32 9.9.9.1 0 lobridge
    5 A S 9.9.9.2/32 r 1.1.1.2 1 ether1
    r 2.2.2.2 ether2
    r 3.3.3.2 ether3
    [[email protected]] > /ip route print detail
    0 ADC dst-address=1.1.1.0/24 pref-src=1.1.1.1 interface=ether1 distance=0 scope=10
    1 ADC dst-address=2.2.2.0/24 pref-src=2.2.2.1 interface=ether2 distance=0 scope=10
    2 ADC dst-address=3.3.3.0/24 pref-src=3.3.3.1 interface=ether3 distance=0 scope=10
    3 ADb dst-address=4.4.4.0/24 gateway=9.9.9.2 interface=ether1,ether2,ether3
    gateway-state=recursive distance=200 scope=40 target-scope=30
    bgp-local-pref=100 bgp-origin=igp received-from=9.9.9.2
    4 ADC dst-address=9.9.9.1/32 pref-src=9.9.9.1 interface=lobridge distance=0 scope=10
    5 A S dst-address=9.9.9.2/32 gateway=1.1.1.2,2.2.2.2,3.3.3.2 interface=ether1,ether2,ether3
    gateway-state=reachable,reachable distance=1 scope=30 target-scope=10
    a routa 4.4.4.0./24 esta instalada em Linux kernel agora com tres nexthops: 1.1.1.2 (on ether1) ,
    2.2.2.2 (on ether2) and 3.3.3.2 (on ether3).
    Exemplo com eBGP
    Configuracao
    O exemplo dado acima é desenvolvido para o caso eBGP. Por padrão, os pares eBGP são obrigatórios
    para ser acessado diretamente. Se estamos usando interfaces loopback, que tecnicamente não são, por
    isso, multihop=yes configuração deve ser especificada.
    No Router A:
    /routing bgp set peer1 remote-address=9.9.9.2 remote-as=65001 update-source=lobridge multihop=yes
    No Router B:
    /routing bgp instance set default as=65001
    /routing bgp set peer1 remote-address=9.9.9.1 remote-as=65000 update-source=lobridge multihop=yes
    Resultados
    Se agora imprimir a tabela de roteamento no router A, vemos que a rota de Router B está lá, mas é
    não ativo:
    2 Db dst-address=4.4.4.0/24 gateway=9.9.9.2 interface="" gateway-state=unreachable
    distance=20 scope=40 target-scope=10 bgp-as-path="65001" bgp-origin=igp
    Isso ocorre porque as rotas eBGP são instalados com menor target-scope por padrão. Para resolver
    isso, a configuração
    filtro que define de maior escopo de destino de roteamento:
    /routing filter add chain=bgp-in set-target-scope=30
    /routing bgp set peer1 in-filter=bgp-in
    Ou então, modificar atributo âmbito da rota estática:
    /ip route set [find dst-address=9.9.9.2/32] scope=10
    de qualquer a maenira a routa para 4.4.4.0/24 deveria estar ativo agora:
    2 ADb dst-address=4.4.4.0/24 gateway=9.9.9.2 interface=ether1,ether2,ether3
    gateway-state=recursive distance=20 scope=40 target-scope=10
    bgp-as-path="65001" bgp-origin=igp received-from=9.9.9.2
    Mais nesse caso vou ter que usar 3 roteador de borda né? quero usar somente de um pois tenho uma coldcore a 36
    Citação Postado originalmente por parreira13 Ver Post
    Configuração
    No Router A:
    # addresses
    # BGP
    No Router B:
    # addresses
    # BGP
    Resultados
    Flags: X - disabled
    ether2
    r 2.2.2.2 ether2
    r 3.3.3.2 ether3
    Exemplo com eBGP
    Configuracao
    No Router A:
    No Router B:
    Resultados
    não ativo:
    voce coloca as configuracoes na mikrotik ccr36 depois voce vai sair com o link para onde?
    Tenho sairá para minha rede
    amigo creio lhe entendi errado, entendi que voce queria fazer uma load balance com 3 links subir em uma bgp me diga o que voce tem ai agora, e quais mudancas voce quer fazer, para que eu possa tentar lhe ajudar obrigado....
    Mas a Operadora vai fazer pra voce as 3 seções?
    Até o momento solicitaram os dados e pronto. não ativamos ainda.
    vai ficar 3 link de 100mb entrando no meu router uma ccr1036. Tenho um de 300mb já ta tranquilo mais esse de 300 vai ser cancelado.
    Citação Postado originalmente por Mephisto Ver Post
    Citação Postado originalmente por kbca12 Ver Post
    Tente fazer por loopback.
    Diga para operadora fazer 1 sessão BGP com os 3 links, ai tanto vc como a operadora utilizarão loopback para levantar o link.
    Como seria tecnicamente falando.
    Citação Postado originalmente por alissonx Ver Post
    Voce levanta uma loopback em seu servidor bgp e a operadora tambem.
    apenas 1 sessão bgp é levantada entre voce e a operadora.
    os 3 links serão balanceados na sua entrada..
    e voce tera que balancear sua saida.
    Vou deixar eles ativarem o link para fazer os teste. Vamos ver como vai ficar.
    Porque desses 300mb vendo 100mb para um cliente e 200mb dividido em meus concentradores.
    certo, aproveite que voce tem bgp com a operadora e entregue os 100 mb via transito para o cliente fechar bgp contigo
    Já fechei alguns BGP, mais esse tipo de BGP ainda não fiz. Como ficaria as configuração para fazer dessa maneira que vocês falou.
    seu cliente tem BGP?
    A as Dele ja ta para sair
    entao faça transito pra ele.
