    Post Ookla speedtest.net duvidá!!
    Bom Dia pessoal me surgiu um problema com o pessoal do speedtest, eles desativaram meu servidor informando baixo desempenho.... não entendi muito bem, por isso vou deixar a mensagem que recebi deles aqui, se alguém tiver como ajudar ou dar uma mão !
    Hello Jefferson,
    Unfortunately, we've had to disable your server in Assis dueto poor performance compared to other servers in the region. Your 95thpercentile (top 5%) of test results compared to regional averages are below:
    Assis ServerPerformance:
    Upload: 20412
    RegionalPerformance:
    Region Upload: 68350
    If you are able to resolve this issue we would behappy to test your server again and enable it if you are meeting regionalrequirements.
    Thank you,
    Depois fiz alguns questionamento e eles me reportaram a seguinte mensagem!
    Hello Jefferson,
    Test method: we take an aggregate of all the tests being run on your server (by end users) and look at the 95th percentile (top 5%) to get an idea of how well the serve is performing from an end user perspective then we compare with servers in the region and determine if the server needs to be deactivated. The reason it is the top 5% is to see what the server is capable of on the higher end of tests. Also we do not do max upload/download because server managers could take a test on network and get 1g up/down but that is no where near what users would get/ are getting from the server.
    Does it interfere with anything, does it create a problem for someone?- Since many different users in your region connect to your server when taking a test on speedtest.net we need to ensure that all servers in a given area are performing well so end users have a consistent and accurate experience when visiting our site.
    I would recommend tuning the system/network settings. We don't have a performance optimization guide yet but we're working on it and for now its up to the server owner to optimize their system settings. Note that OoklaServer itself has no way to be tuned for testing so its all third party settings. Changing TCP send/receive buffer sizes and TCP congestion control algorithm can improve performance (some server owners have reported this)
    Thanks,
    James
    Padrão Re: Ookla speedtest.net duvidá!!
    eu tbm estou tendo problemas com eles, detalhe tenho 10gb para iX RS e 3gb para IXSP vendo planos a partir de 35mb a 100mb, plano em média 160 pila por 100mb, porem outros provedores como a oi oferta media 4 a 10mb e tbm provedores radio que oferta 2 a 3mb, e acreditem desativaram meu Speed baseado nesta politica de avalicao deles por causa dos testes realizados no meu servidor, outro detalhe a velocidade media de minha regiao e de 512 a 10mb colocaram 96/40mb download/upload
    Aqui para min mesmo motivo, vendemos planos de 100 80 60 40 20... e sim temos outros provedores aqui na região que vende esse mesmo planos, mas essa avaliação deles acho que esta errado, em informar que, avaliação feita por teste realizado e deu em media 45 / 20, maioria dos meus clientes tem plano de 20 60 mega, todos teste que for realizado por eles vão da em média isso ... Questionei isso com eles mas não deu em nada... realmente não sei o que tem que ser feito para melhorar sendo que temos 5Gb de sobra para qualquer teste realizado por fora ...
    Hi,
    I apologize for writing in English, However, I wonder whether you guys were able to put the server back up ?
    Thanks
    Citação Postado originalmente por JeffersonSato Ver Post
    Hi,
    Thanks
    Hi,
    Thanks
    Hi,
    I apologize for writing in English, However, I wonder whether you guys were able to put the server back up ? How if possible
    Thanks
    ola bom dia a todos venho hoje pedi ajuda aos amigos tenho uma duvida de como coloca o dominio teste no servidor dns eu sei que o dominio tem que ta apontado pra um ip a minha duvida ta ai qual ip e pra ser a pontado o ip do meu link dedicado ou o ip do meu servidor speed teste
Nome:	         00002.png
Visualizações:	121
Tamanho: 	15,7 KB
