Guys, I installed the viewer for .xml files downloaded from the IRS (the file is Viewer-7.6.6-Linux-x86_64-Install for 64bit Ubuntu) and the installation went well. Only when I'm running it gives an error and tells me to check the log file. I could not understand where the error is. It seems that the problem is with the eclipse.
!SESSION 2021-03-17 21:26:16.598 -----------------------------------------------
eclipse.buildId=unknown
java.version=14.0.2
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=pt_BR
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.equinox.common 4 0 2021-03-17 21:26:17.197
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.common_3.6.0.v20110523 [14]" could not be resolved.
Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1327)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:13
11)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
