  1. esse é meu XF86Config
    achei as fontes!
    # File generated by xf86config.
    # Copyright (c) 1999 by The XFree86 Project, Inc.
    # Permission is hereby granted, free of charge, to any person obtaining a
    # copy of this software and associated documentation files (the "Software&quot<IMG SRC="images/forum/icons/icon_wink.gif">,
    # to deal in the Software without restriction, including without limitation
    # the rights to use, copy, modify, merge, publish, distribute, sublicense,
    # and/or sell copies of the Software, and to permit persons to whom the
    # Software is furnished to do so, subject to the following conditions:
    # The above copyright notice and this permission notice shall be included in
    # all copies or substantial portions of the Software.
    # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
    # THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
    # WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
    # OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
    # SOFTWARE.
    # Except as contained in this notice, the name of the XFree86 Project shall
    # not be used in advertising or otherwise to promote the sale, use or other
    # dealings in this Software without prior written authorization from the
    # XFree86 Project.
    # Refer to the XF86Config(4/5) man page for details about the format of
    # this file.
    # Module section -- this section is used to specify
    # which dynamically loadable modules to load.
    Section "Module"
    # This loads the DBE extension module.
    Load "dbe" # Double buffer extension
    # This loads the miscellaneous extensions module, and disables
    # initialisation of the XFree86-DGA extension within that module.
    SubSection "extmod"
    Option "omit xfree86-dga" # don&acute;t initialise the DGA extension
    EndSubSection
    # This loads the Type1 and FreeType font modules
    Load "type1"
    Load "freetype"
    # This loads the GLX module
    # Load "glx"
    EndSection
    # Files section. This allows default font and rgb paths to be set
    Section "Files"
    # The location of the RGB database. Note, this is the name of the
    # file minus the extension (like ".txt" or ".db&quot<IMG SRC="images/forum/icons/icon_wink.gif">. There is normally
    # no need to change the default.
    RgbPath "/usr/X11R6/lib/X11/rgb"
    # Multiple FontPath entries are allowed (which are concatenated together),
    # as well as specifying multiple comma-separated entries in one FontPath
    # command (or a combination of both methods)
    # If you don&acute;t have a floating point coprocessor and emacs, Mosaic or other
    # programs take long to start up, try moving the Type1 and Speedo directory
    # to the end of this list (or comment them out).
    #:unscaled
    FontPath "/usr/X11R6/lib/X11/fonts/local/"
    FontPath "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
    # The module search path. The default path is shown here.
    # ModulePath "/usr/X11R6/lib/modules"
    EndSection
    # Server flags section.
    Section "ServerFlags"
    # Uncomment this to cause a core dump at the spot where a signal is
    # received. This may leave the console in an unusable state, but may
    # provide a better stack trace in the core dump to aid in debugging
    # Option "NoTrapSignals"
    # Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
    # This allows clients to receive this key event.
    # Option "DontZap"
    # Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
    # sequences. This allows clients to receive these key events.
    # Option "Dont Zoom"
    # Uncomment this to disable tuning with the xvidtune client. With
    # it the client can still run and fetch card and monitor attributes,
    # but it will not be allowed to change them. If it tries it will
    # receive a protocol error.
    # Option "DisableVidModeExtension"
    # Uncomment this to enable the use of a non-local xvidtune client.
    # Option "AllowNonLocalXvidtune"
    # Uncomment this to disable dynamically modifying the input device
    # (mouse and keyboard) settings.
    # Option "DisableModInDev"
    # Uncomment this to enable the use of a non-local client to
    # change the keyboard or mouse settings (currently only xset).
    # Option "AllowNonLocalModInDev"
    EndSection
    # Input devices
    # Core keyboard&acute;s InputDevice section
    Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
    # For most OSs the protocol can be omitted (it defaults to "Standard&quot<IMG SRC="images/forum/icons/icon_wink.gif">.
    # When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
    # uncomment the following line.
    # Option "Protocol" "Xqueue"
    Option "AutoRepeat" "500 30"
    # Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
    # Option "Xleds" "1 2 3"
    # Option "LeftAlt" "Meta"
    # Option "RightAlt" "ModeShift"
    # To customise the XKB settings to suit your keyboard, modify the
    # lines below (which are the defaults). For example, for a non-U.S.
    # keyboard, you will probably want to use:
    # Option "XkbModel" "pc102"
    # If you have a US Microsoft Natural keyboard, you can use:
    # Option "XkbModel" "microsoft"
    # Then to change the language, change the Layout setting.
    # For example, a german layout can be obtained with:
    # Option "XkbLayout" "de"
    # or:
    # Option "XkbVariant" "nodeadkeys"
    # If you&acute;d like to switch the positions of your capslock and
    # control keys, use:
    # Option "XkbOptions" "ctrl:swapcaps"
    # These are the default XKB settings for XFree86
    # Option "XkbRules" "xfree86"
    # Option "XkbModel" "pc101"
    # Option "XkbLayout" "us"
    # Option "XkbVariant" ""
    # Option "XkbOptions" ""
    # Option "XkbDisable"
    Option "XkbModel" "abnt2"
    Option "XkbLayout" "br"
    EndSection
    # Core Pointer&acute;s InputDevice section
    # Identifier and driver
    Identifier "Mouse0"
    Driver "mouse"
    Option "Protocol" "PS/2"
    Option "Device" "/dev/psaux"
    # When using XQUEUE, comment out the above two lines, and uncomment
    # the following line.
    # Option "Protocol" "PS/2"
    # Baudrate and SampleRate are only for some Logitech mice. In
    # almost every case these lines should be omitted.
    # Option "BaudRate" "9600"
    # Option "SampleRate" "150"
    # Emulate3Buttons is an option for 2-button Microsoft mice
    # Emulate3Timeout is the timeout in milliseconds (default is 50ms)
    Option "Emulate3Buttons"
    # Option "Emulate3Timeout" "50"
    # ChordMiddle is an option for some 3-button Logitech mice
    # Option "ChordMiddle"
    EndSection
    # Other input device sections
    # this is optional and is required only if you
    # are using extended input devices. This is for example only. Refer
    # to the XF86Config man page for a description of the options.
    # Section "InputDevice"
    # Identifier "Mouse0"
    # Driver "mouse"
    # Option "Protocol" "MouseMan"
    # Option "Device" "/dev/psaux"
    # EndSection
    # Identifier "spaceball"
    # Driver "magellan"
    # Option "Device" "/dev/cua0"
    # EndSection
    # Identifier "spaceball2"
    # Driver "spaceorb"
    # EndSection
    # Identifier "touchscreen0"
    # Driver "microtouch"
    # Option "Device" "/dev/ttyS0"
    # Option "MinX" "1412"
    # Option "MaxX" "15184"
    # Option "MinY" "15372"
    # Option "MaxY" "1230"
    # Option "ScreenNumber" "0"
    # Option "ReportingMode" "Scaled"
    # Option "ButtonNumber" "1"
    # Option "SendCoreEvents"
    # EndSection
    # Identifier "touchscreen1"
    # Driver "elo2300"
    # Option "MinX" "231"
    # Option "MaxX" "3868"
    # Option "MinY" "3858"
    # Option "MaxY" "272"
    # Option "ButtonThreshold" "17"
    # EndSection
    # Monitor section
    # Any number of monitor sections may be present
    Section "Monitor"
    Identifier "My Monitor"
    # HorizSync is in kHz unless units are specified.
    # HorizSync may be a comma separated list of discrete values, or a
    # comma separated list of ranges of values.
    # NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR&acute;S
    # USER MANUAL FOR THE CORRECT NUMBERS.
    HorizSync 31.5, 35.15, 35.5
    # HorizSync 30-64 # multisync
    # HorizSync 31.5, 35.2 # multiple fixed sync frequencies
    # HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
    # VertRefresh is in Hz unless units are specified.
    # VertRefresh may be a comma separated list of discrete values, or a
    VertRefresh 50-70
    EndSection
    # Graphics device section
    # Any number of graphics device sections may be present
    # Standard VGA Device:
    Section "Device"
    Identifier "Standard VGA"
    VendorName "Unknown"
    BoardName "Unknown"
    # The chipset line is optional in most cases. It can be used to override
    # the driver&acute;s chipset detection, and should not normally be specified.
    # Chipset "generic"
    # The Driver line must be present. When using run-time loadable driver
    # modules, this line instructs the server to load the specified driver
    # module. Even when not using loadable driver modules, this line
    # indicates which driver should interpret the information in this section.
    Driver "vga"
    # The BusID line is used to specify which of possibly multiple devices
    # this section is intended for. When this line isn&acute;t present, a device
    # section can only match up with the primary video device. For PCI
    # devices a line like the following could be used. This line should not
    # normally be included unless there is more than one video device
    # intalled.
    # BusID "PCI:0:10:0"
    # VideoRam 256
    # Clocks 25.2 28.3
    EndSection
    # Device configured by xf86config:
    Section "Device"
    Identifier "Voodoo3 (generic)"
    Driver "tdfx"
    #VideoRam 16000
    # Insert Clocks lines here if appropriate
    EndSection
    # Screen sections
    # Any number of screen sections may be present. Each describes
    # the configuration of a single screen. A single specific screen section
    # may be specified from the X server command line with the "-screen"
    # option.
    Section "Screen"
    Identifier "Screen 1"
    Device "Voodoo3 (generic)"
    Monitor "My Monitor"
    DefaultDepth 24
    Subsection "Display"
    Depth 8
    Modes "640x480" "800x600" "1024x768" "1280x1024"
    ViewPort 0 0
    EndSubsection
    Depth 16
    ViewPort 0 0
    EndSubsection
    Depth 24
    ViewPort 0 0
    EndSubsection
    EndSection
    # ServerLayout sections.
    # Any number of ServerLayout sections may be present. Each describes
    # the way multiple screens are organised. A specific ServerLayout
    # section may be specified from the X server command line with the
    # "-layout" option. In the absence of this, the first section is used.
    # When now ServerLayout section is present, the first Screen section
    # is used alone.
    Section "ServerLayout"
    # The Identifier line must be present
    Identifier "Simple Layout"
    # Each Screen line specifies a Screen section name, and optionally
    # the relative position of other screens. The four names after
    # primary screen name are the screens to the top, bottom, left and right
    # of the primary screen. In this example, screen 2 is located to the
    # right of screen 1.
    Screen "Screen 1"
    # Each InputDevice line specifies an InputDevice section name and
    # optionally some options to specify the way the device is to be
    # used. Those options include "CorePointer", "CoreKeyboard" and
    # "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
    EndSection
  2. meu directorio
    /usr/X11R6/lib/X11/fonts contem isso
    100dpi
    75dpi
    CID
    encodings
    local
    misc
    PEX
    Speedo
    Type1
    util
  3. pq as fontes 75 e 100 dpi estao unscaled ????
  4. Pq eu num sei mas tem o seguinte cara!!! pelo erro q deu anteriormente provavelmente vc ta e mostrando um XF86Config e ele está usando outro!!!
    de ai um
    find / -name XF86Config e coloque aki todos q ele achar
  5. /etc/X11/XF86Config
    /usr/X11R6/lib/X11/XF86Config
    /home/user/XF86Config
    sera que ele ta usando o /etc/X11/XF86Config ????
  1. Continua o problema com rota
    Por redoctober no fórum Servidores de Rede
    Respostas: 13
    Último Post: 08-11-2002, 13:04
  2. Problema com os log do Apache
    Por Good_speed no fórum Servidores de Rede
    Último Post: 28-10-2002, 08:51
  3. Problemas com Perl
    Por adcorp no fórum Servidores de Rede
    Último Post: 17-08-2002, 11:52
  4. Problema com o ssh pelo windows !!!
    Por embbr no fórum Servidores de Rede
    Último Post: 01-07-2002, 18:10
  5. problemas com o IMP
    Por marlonfuchs no fórum Servidores de Rede
    Último Post: 27-06-2002, 08:13
