    Padrão Problema com X
    provavelmente!!!!!
    renomeie os outros e tente entrar no X pra ver oq da
    nao ...
    aqui no /etc/X11 tem um XF86Config-4
    e é diferente do XF86Config
    vou postar ele pra vc ve.
    # XFree86 4.0 configuration generated by Xconfigurator
    Section "ServerLayout"
    Identifier "XFree86 Configured"
    Screen 0 "Screen0" 0 0
    InputDevice "Mouse0" "CorePointer"
    InputDevice "Keyboard0" "CoreKeyboard"
    EndSection
    # By default, Red Hat Linux 6.0 and later use xfs
    Section "Files"
    FontPath "unix/:7100"
    EndSection
    # Module loading section
    Section "Module"
    Load "dbe" # Double-buffering
    Load "GLcore" # OpenGL support
    Load "dri" # Direct rendering infrastructure
    Load "glx" # OpenGL X protocol interface
    Load "extmod" # Misc. required extensions
    Load "v4l" # Video4Linux
    # Load "pex5" # PHIGS for X 3D environment (obsolete)
    # Load "record" # X event recorder
    # Load "xie" # X Image Extension (obsolete)
    # You only need the following two modules if you do not use xfs.
    # Load "freetype" # TrueType font handler
    # Load "type1" # Adobe Type 1 font handler
    EndSection
    Section "InputDevice"
    Identifier "Keyboard0"
    Driver "keyboard"
    Option "XkbLayout" "us"
    EndSection
    Identifier "Mouse0"
    # Modified by mouseconfig
    Driver "mouse"
    Option "Device" "/dev/psaux"
    Option "Protocol" "PS/2"
    Option "Emulate3Buttons" "no"
    Option "ZAxisMapping" "4 5"
    EndSection
    Section "Monitor"
    Identifier "My Monitor"
    VendorName "Unknown"
    ModelName "Unknown"
    HorizSync 31.5, 35.15, 35.5
    VertRefresh 50-70
    Option "dpms"
    EndSection
    Section "Device"
    Identifier "Voodoo3 (generic)"
    Driver "tdfx"
    BoardName "Unknown"
    EndSection
    Section "Device"
    Identifier "Linux Frame Buffer"
    Driver "fbdev"
    BoardName "Unknown"
    EndSection
    Section "Screen"
    Identifier "Screen0"
    Device "Voodoo3 (generic)"
    Monitor "My Monitor"
    DefaultDepth 24
    Subsection "Display"
    Depth 24
    Modes "800x600"
    EndSubSection
    EndSection
    Section "DRI"
    Mode 0666
    EndSection
    exatamente... ele ta usando esse ai!!!!!
    faz o seguinte renomei todos os XF86Config* que tiver e configure o video novamente
    entao 1c3
    quando eu dou um Xconfigurator
    faco o teste de video , funciona , vejo tudo , ( tudo certo)
    , ele cria esses 2 arquivos XF86Config e o XF86Config-4
    +ai
    X ou startx
    e nao inicia.
    da aquele velho erro...
    ok entaum faz o seguinte edita o XF86Config-4 e altera a variavel FontPath pra ficar igual ao q tem no XF86Config
    + ja estao iguais....
    FontPath unix/:7100
    <IMG SRC="images/forum/icons/icon_confused.gif">
    mas eh justamente essa linha q ta dando pau!!!!!! <IMG SRC="images/forum/icons/icon_razz.gif">
    deixe ela como o outro q vc tinha passado
    FontPath "/usr/X11R6/lib/X11/fonts/local/"
    FontPath "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
    Certo...
    percebi tambem que quando dou um boot no pinguim ele da um erro no
    xfs
    ai resolvi desligar o servico e reiniciar na mao...
    quando dou um xfs start ele da um sinal de ok
    + qaundo dou um xfs reload ele falha e
    quando executo xfs status
    ele me passa uma msg assim:
    xfs morto mas o ficheiro com o pid existe
    <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif">
    funfo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif">
    q show manowwwwwwwwwwwwww
    valewwwwwwwwwwwwwwwwwww
    thanks 1c3!!!
    valeu mesmo!!!
    []os
    MAJOR
    porra nem sei oq falar...
    muito obrigado!
    hehehe soh pra variar um poko isso jah aconteceu comigo tb!!!!
    cara eu to surpreso, aki eh o unico lugar que eu tenho paciencia pra dar suporte pra alguem hehehe <IMG SRC="images/forum/icons/icon_wink.gif">
    Acho q eh pq num tem nenhum ignorante hahahaha
  13. #33
    Jul 2001
    Campinas Area
    Fale por si proprio uhehueuhehueuhe
  14. #34
    A cara nda se compara a ignorância do usuarios de nossa empresa!!!
    hj fiquei mto puto, a menina me chamou falando q a impressora num imprimia... cheguei lah a porra do micro tava desligado!!!!!!!!!!!
    sem contar as outras comicas heheheh
