- SHELL CPAN
SHELL CPAN
Galera,
Eu estou com um problema dificil de resolver, já coloquei este assunto no forum 3 vezes hoje.
Eu já instalei o Uvscan, e agora estou instalando o AMAVIS C/ POSTFIX.
é o seguinte assim que eu descompacto o AMAVIS, eu executo o comando
./configure --enable-smtp --enable-postfix --with-amavis-user=vscan
Ai ele me diz que está faltando alguns modulos perl.
MENSAGEM:
loading cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for mawk... mawk
checking whether make sets ${MAKE}... yes
checking whether make sets ${MAKE}... (cached) yes
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking dependency style of gcc... none
checking for perl... /usr/bin/perl
checking for perl modules...
Module not found in path: ´Unix/Syslog´
Module not found in path: ´Convert/UUlib´
Module not found in path: ´Convert/TNEF´
Module not found in path: ´Compress/Zlib´
Module not found in path: ´Archive/Tar´
Module not found in path: ´Archive/Zip´
Configure: error: You are missing some perl modules.
Então eu entro no Shel CPAN da seguinte maneira
perl -MCPAN -e shell
Tento instalar os modulos e ele me informa da seguinte maneira:
install Unix::Syslog
There seems to be running another CPAN process (1724). Contacting...
Other job not responding. Shall I overwrite the lockfile? (Y/N) [y]
cpan shell -- CPAN exploration and modules installation (v1.59_54)
ReadLine support enabled
CPAN: Storable loaded ok
Going to read /root/.cpan/Metadata
Database was generated on
Warning: Cannot install Unix::Syslog, don´t know what it is.
Try the command
i /Unix::Syslog/
to find objects with matching identifiers.
Depois eu executo a instalação dessa maneira e ele mostra as seguintes informações:
install Unix/Syslog
[B]Running make for U/U//U/Un/Unix/Syslog
CPAN: LWP::UserAgent loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/id/U/U//U/Un/Unix/Syslog
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/id/U/U//U/Un/Unix/Syslog.gz
Fetching with Net::FTP:
Trying with "/usr/bin/lynx -source" to get
Trying with "/usr/bin/ncftpget" to get
Trying with "/usr/bin/wget -O -" to get
ftp://ftp.perl.org/pub/CPAN/authors/id/U/U//U/Un/Unix/Syslog</B>
GENTE O QUE EU FAÇO PARA INSTALAR ESSES BENDITOS MODULOS.....
POR FAVOR ME AJUDEM.......
<IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif">
SHELL CPAN
SHELL CPAN
entre em www.cpan.org e faça download dos modulos:
Unix::Syslog
Convert::UUlib
Convert::TNEF
Compress::Zlib
Archive::Tar
Archive::Tar
depois de fazer o download descompacte eles
tar -zxvf PACOTE
cd PACOTE
./configure
make
make install
SHELL CPAN
Pegue o módulo aqui
tar xvzf Unix-Syslog-0.99.tar.gz
cd Unix-Syslog-0.99/
perl Makefile.PL
make test
make install
*Não tem ./configure em módulo Perl*
Parece que a sua shell do CPAN não achou o Unix::Syslog por causa do mirror. Pegueo o arquivo MIRRORED.BY em ftp://ftp.matrix.com.br/pub/perl/CPAN/ coloque dentro de .cpan/sources entre no shell do CPAN de novo, rode "o conf init" e escolha um outro mirror. Isso pode ajudar.
SHELL CPAN
eh verdade... desculpe a falha....
ao inves de configure eh perl Makefile....
SHELL CPAN
BrunoC ou 1c3_m4n,
Eu consegui baixar o Unix-Syslog-0.99.tar.gz, só que eu precisso de outros modulos também......
Os modulos são:
Convert::UUlib
Convert::TNEF
Compress::Zlib
Archive::Tar
Archive::Zip
Será que vcs poderiam me passar a url deles tb....
Grato..... <IMG SRC="images/forum/icons/icon21.gif"> <IMG SRC="images/forum/icons/icon21.gif">
SHELL CPAN
Alguém sabe a url deste outros modulos???
Grato...
SHELL CPAN
Galera,
Eu consegui baixar os modulos e já compilei.
Agora o problema é outro, ao executar a linha de comando
ele me apresenta as seguinte informações, ou seja os modulos perl já foi resolvido, agora o problema é outro.
Erro
checking for perl modules... found
checking for file... /usr/bin/file
checking if file can be brief... yes
checking for id... /usr/bin/id
checking for arc... no
Configure: error: Sorry, you need arc.
Galera o que pode ser isso agora.
Instalar o AMAVIS é muita treta...... <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif">
SHELL CPAN
Alguém pode ajudar.
Please, I need help......
SHELL CPAN
cara entra no www.cpan.org....
lah tem um link escrito "ALL MODULES" entra nele e baixe oq falta
SHELL CPAN
Aí já não é problema de módulo. Falta o arc propriamente dito. Provavelmente ele vai reclamar de outras ferramentas de compressão / descompressão. A princípio tá tudo aqui. Pegue o ARC (e qualquer outra ferramenta que ele pedir), instale e rode o configure de novo.
SHELL CPAN
Obrigado pessoal,
Até que enfim eu consegui instalar o AMAVIS..
Thanks my friends..
