    gustcol
    Padrão Ajuda com autenticação...
    Galera, estou com problemas para colocar a autenticação no meu apache..
    vc poderião estar ajudando..
    eu quero q o http://aquilola.com.br/home/user2 pop uma tela de requisação de user and password.. sendo q o aquilola.com.br é um virtual host no meu apache... como faço.. p.s.: segue o meu httpd.conf help please;;;;
    ServerRoot "/etc/httpd"
    LockFile /var/run/httpd.lock
    PidFile /var/run/httpd.pid
    ScoreBoardFile logs/apache_runtime_status
    Timeout 300
    Off
    MaxKeepAliveRequests 100
    MaxClients 150
    MaxRequestsPerChild 1000
    Port 80
    <IfDefine HAVE_SSL>
    Listen 80
    Listen 443
    </IfDefine>
    User apache
    Group apache
    ServerAdmin [email protected]
    DocumentRoot "/var/www/html"
    <Directory />
    Options FollowSymLinks
    # AllowOverride None
    AllowOverride FileInfo
    </Directory>
    <Directory "/var/www/html">
    Options Indexes FollowSymLinks
    AllowOverride AuthConfig
    Order allow,deny
    Allow from all
    </Directory>
    <Directory "/var/www/html/prod/webbill/billprov">
    Allow from all
    </Directory>
    ProxyPass /report http://webbill.timnet.com:8180/billprov/jsp/index.jsp
    ProxyPassReverse /report http://webbill.timnet.com:8180/billprov/jsp/index.jsp
    <IfModule mod_userdir.c>
    UserDir public_html
    </IfModule>
    <IfModule mod_dir.c>
    # DirectoryIndex index.html index.htm index.shtml index.php index.php4 index.php3 index.phtml index.cgi index.jsp default.jsp
    DirectoryIndex none
    </IfModule>
    AccessFileName .htaccess
    <Files ~ "^\.ht">
    Order allow,deny
    Deny from all
    Satisfy All
    </Files>
    UseCanonicalName On
    <IfModule mod_mime.c>
    TypesConfig /etc/mime.types
    </IfModule>
    <IfModule mod_mime_magic.c>
    # MIMEMagicFile /usr/share/magic.mime
    MIMEMagicFile conf/magic
    </IfModule>
    HostnameLookups Off
    ErrorLog logs/error_log
    LogLevel warn
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    LogFormat "%{Referer}i -> %U" referer
    LogFormat "%{User-agent}i" agent
    CustomLog logs/access_log combined
    <IfModule mod_alias.c>
    Alias /icons/ "/var/www/icons/"
    <Directory "/var/www/icons">
    Options Indexes MultiViews
    AllowOverride None
    Order allow,deny
    Allow from all
    </Directory>
    ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
    <Directory "/var/www/cgi-bin">
    AllowOverride None
    Options None
    Order allow,deny
    Allow from all
    </Directory>
    </IfModule>
    DefaultIcon /icons/unknown.gif
    IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
    </IfModule>
    <IfModule mod_negotiation.c>
    LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ru ltz ca es sv tw
    </IfModule>
    <IfModule mod_php3.c>
    AddType application/x-httpd-php3 .php3
    AddType application/x-httpd-php3-source .phps
    </IfModule>
    <IfModule mod_php4.c>
    AddType application/x-httpd-php .php .php4 .php3 .phtml
    AddType application/x-httpd-php-source .phps
    </IfModule>
    <IfModule mod_php.c>
    AddType application/x-httpd-php .phtml
    </IfModule>
    AddType application/x-tar .tgz
    AddType text/html .shtml
    AddHandler server-parsed .shtml
    AddHandler imap-file map
    </IfModule>
    <IfModule mod_setenvif.c>
    BrowserMatch "Mozilla/2" nokeepalive
    BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
    BrowserMatch "RealPlayer 4\.0" force-response-1.0
    BrowserMatch "Java/1\.0" force-response-1.0
    BrowserMatch "JDK/1\.0" force-response-1.0
    </IfModule>
    Alias /doc/ /usr/share/doc/
    <Directory /usr/share/doc>
    order deny,allow
    deny from all
    allow from localhost .localdomain
    </Directory>
    NameVirtualHost 10.18.14.20
    <VirtualHost _default_:443>
    SSLCertificateKeyFile /etc/httpd/conf/ssl.key/server.key
    <Files ~ "\.(cgi|shtml|phtml|php3?)$">
    SSLOptions +StdEnvVars
    </Files>
    </Directory>
    SetEnvIf User-Agent ".*MSIE.*" \
    nokeepalive ssl-unclean-shutdown \
    CustomLog logs/ssl_request_log \
    "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
    </VirtualHost>
    </IfDefine>
    <VirtualHost ola.com:80>
    NameVirtualHost ola.com
    DocumentRoot /home/user1/
    <Directory "/home/user1">
    Options Indexes FollowSymLinks MultiViews ExecCGI
    AllowOverride none
    Order allow,deny
    Allow from all
    </Directory>
    ServerName ola.com
    </VirtualHost>
    <VirtualHost aquilola.com.br:80>
    NameVirtualHost aquilola.com.br
    DocumentRoot /home/user2/
    <Directory "/home/user2">
    AllowOverride none
    Order allow,deny
    Allow from all
    </Directory>
    ServerName aquilola.com.br
    </VirtualHost>
    <IMG SRC="images/forum/icons/icon_wink.gif">
    Ola..
    Acesse este link, ira te ajudar...
    http://www.fe.up.pt/cica3w/helpdesk/faqs/unix_11.html
    T+ <IMG SRC="images/forum/icons/icon_wink.gif">
