    celosc
    Cara tenta reinstalar o pacote do samba através do cd da tua distribuição, pelo visto é o RH 9 correto ?
    Tenta isso
    Existe um espaço entre o smbclient e o -l, deve ser assim:
    smbcliente -l webstream2
    []s,
    André Guerra
    [root@localhost samba]# smbclient-l webstream2
    bash: smbclient-l: command not found
    Desculpe o erro anterior é: smbclient e não smbcliente..<IMG SRC="images/forum/icons/icon_cool.gif">
    Erro de digitacao e displicencia juntos...
    []s,
    André Guerra
    JDboard
    [root@localhost root]# smbclient
    params.c<IMG SRC="images/forum/icons/icon_eek.gif">penConfFile() - Unable to open configuration file "/etc/samba/smb.conf":
    No such file or directory
    Can&acute;t load /etc/samba/smb.conf - run testparm to debug it
    added interface ip=10.10.0.10 bcast=10.10.0.255 nmask=255.255.255.0
    Usage: smbclient service <password> [options]
    Version 2.2.7a
    -s smb.conf pathname to smb.conf file
    -O socket_options socket options to use
    -R name resolve order use these name resolution services only
    -M host send a winpopup message to the host
    -i scope use this NetBIOS scope
    -N don&acute;t ask for a password
    -n netbios name. Use this name as my netbios name
    -d debuglevel set the debuglevel
    -P connect to service as a printer
    -p port connect to the specified port
    -l log basename. Basename for log/debug files
    -h Print this help message.
    -I dest IP use this IP to connect to
    -E write messages to stderr instead of stdout
    -U username set the network username
    -L host get a list of shares available on a host
    -t terminal code terminal i/o code {sjis|euc|jis7|jis8|junet|hex}
    -m max protocol set the max protocol level
    -A filename get the credentials from a file
    -W workgroup set the workgroup name
    -T<c|x>IXFqgbNan command line tar
    -D directory start from directory
    -c command string execute semicolon separated commands
    -b xmit/send buffer changes the transmit/send buffer (default: 65520)
    Fiz isso me mostrou isso que veem e agora o que que eu faco , me desculpe estar sendo chato mas sou novo no linux e estou no meu estagio e tenho que aprender tambem ne se me ajudarem ficarei grato!!!!!
    <IMG SRC="images/forum/icons/icon_biggrin.gif">
    LeonSimpai
    JDboard
    Sera que alguem podia me ajudar estou precisando muito disso!!!!!
    LeonSimpai <IMG SRC="images/forum/icons/icon27.gif">
  1. Windows XP reinicia quando tenta logar no samba+ldap
    Por noir no fórum Servidores de Rede
    Respostas: 5
    Último Post: 07-04-2008, 22:58
  2. Alterando registro do windows ao logar no dominio
    Por LeoJfa no fórum Servidores de Rede
    Último Post: 13-12-2006, 23:36
  3. Perfil no windows ao sambar
    Por earaujos no fórum Servidores de Rede
    Último Post: 27-09-2002, 07:47
  4. Apache + PHP no Windows XP
    Por A2 no fórum Servidores de Rede
    Último Post: 16-08-2002, 20:49
  5. Não consigo exergar o linux no windows
    Por sandalo no fórum Servidores de Rede
    Último Post: 13-05-2002, 08:46
