    Padrão DNS p/ rede interna
    Gente,
    estou usando o Bind 9.2 no Red Hat 9, através dele consigo navegar na net normalmente. Ele esta resolvendo os nomes legais. Mas esta dando um problemas p/ resolver os nomes de dentro da minha rede.
    Qdo estarto ele, levanta blz, mas dei uma olhada no /var/log/messages e lá me mostrou pq ele não resolve os nomes da rede interna.
    /var/log/messages
    named[5961]: listening on IPv4 interface lo, 127.0.0.1#53
    named[5961]: listening on IPv4 interface eth0, 192.168.0.8#53
    named[5961]: command channel listening on 127.0.0.1#953
    named[5961]: zone 0.0.127.in-addr.arpa/IN: loaded serial 1997022700
    named[5961]: zone 0.168.192.in-addr.arpa/IN: loaded serial 1997022700
    named[5961]: intranet.zone:14: file does not end with newline
    named[5961]: zone intranet/IN: loaded serial 2003090200
    named[5961]: zone localhost/IN: loaded serial 42
    named[5961]: running
    named[5961]: zone intranet/IN: sending notifies (serial 2003090200)
    file does not end with newline o q ele esta querendo dizer c/ isso?
    Bem, vou passar tb meus arquivos de configuração do bind derrepente lá pode ter alguma coisa errada.
    /etc/named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    // a caching only nameserver config
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "dominio" IN {
    type master;
    file "intranet.zone";
    zone "0.168.192.in-addr.arpa" IN {
    type master;
    file "192.168.0.rev";
    include "/etc/rndc.key";
    /var/named/intranet
    $TTL 86400
    @ IN SOA dominio. root.dominio. (
    2003090200 ; serial
    28800 ; refresh
    14400 ; retry
    3600000 ; expire
    86400 ) ; minimum
    @ IN NS web.dominio.
    web.dominio IN A 192.168.0.8
    www.dominio IN A 192.168.0.8
    /var/named/192.168.0.rev
    $TTL 86400
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    @ IN NS dominio.
    #8.0.168.192.in-addr.arpa IN PTR dominio.
    1 IN PTR web.dominio.
    2 IN PTR www.dominio.
    Desculpe pelo tamanho do texto.
    Valeu...
    Valeu pessoal consegui resolver.
    Briagdão..
    robson_alves
    Cara como faço para resolver nomes com a rede interna no bind
    guardian_metal
    Cara;
    Não sei se estou falando muita merda mas acho que vc tem que editar o arquivo hosts que fica em /etc.
    127.0.0.1 servidor localhost.localdomain localhost
    192.168.0.3 micro-1
    192.168.0.4 micro-2
    E por ae vai..
    para resolver nomes vc pode cadastrar um dominio interno no seu DNS ..... isso só fica na sua rede interna .
    Olha na linha 14 do seu arquivo /var/named/intranet.zone se tem algo anormal...
    Abraços!
    *sigh* eh soh dar uma enter no final do arquivo.... vergonha nao saber o que eh newline... tentem jogar o erro de voces na google, ou na proprio tradutor... newline.. linha nova.. etc etc
    dctalk
    no /etc/hosts
    lá que tem que tá o IP , nome completo e apelido
    10.3.1.100 maquina1.dominio.com.br maquina1
    dê um
    man 5 hosts
    que lá mostra os exemplos.
