  1. testei o comando que tu me deste, mas não adiantou... olha o erro que ele me gera....
    [2004/08/23 10:21:51, 0] printing/print_cups.c:cups_printer_fn(108)
    Unable to connect to CUPS server localhost - Conexão recusada
    [2004/08/23 10:21:51, 0] printing/print_cups.c:cups_queue_get(854)
    [2004/08/23 10:26:01, 0] printing/print_cups.c:cups_queue_get(854)
    [2004/08/23 10:30:12, 0] printing/print_cups.c:cups_queue_get(854)
    to passando tb o meu smb.conf
    [global]
    workgroup = samba
    netbios name = samba
    announce as = NT Server
    server string = Samba [%v]
    printcap name = /etc/printcap
    load printers = yes
    printing = cups
    # log por maquina
    log file = /var/log/samba/log.%m
    max log size = 100
    debug level = 1
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # passwords
    password level = 8
    smb passwd file = /etc/samba/smbpasswd
    unix password sync = no
    encrypt passwords = yes
    null passwords = no
    username map = /etc/samba/smbusers
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*password* %n\n *Retype*new*password* %n\n \
    *passwd:*all*authentication*tokens*update*successfully*
    security = user
    guest ok = yes
    # PDC
    os level = 100
    local master = yes
    domain master = yes
    preferred master = yes
    domain logons = yes
    #hosts e dns
    hosts equiv = /etc/hosts
    hostname lookups = yes
    hosts allow = 192.168.0.
    dns proxy = no
    # logon
    logon path = \\%L\profiles\%U
    logon script = login.bat
    message command = /usr/bin/x11/linpopup "%f" "%m" %s ; rm %s
    [pdf]
    comment = Gerador de PDFs
    path = /var/spool/samba
    printable = yes
    guest ok = yes
    use client driver = yes
    browseable = yes
    writeable = no
    print command = /usr/bin/ps2pdf -dEmbedAllFonts=true %s /home/%U/`echo "%J" | tr -d ' ' | sed 's/Microsoft//' | \
    tr -d [\&\%\=\?\+] | tr '\\\' '/' | xargs basename | sed 's/....$/.pdf/' | sed 's/\.\./\./' 2>>/var/spool/samba/err; \
    rm -f %s; /usr/bin/find /home/%U/ -type f -cmin +1440 -exec rm -f {} \;
    lpq command = echo "Printer: %p@samba.teste (dest ps2pdf)"; echo " Queue: no printable jobs in queue"; echo " Status: Ready"
    Mais alguma idéia????
  2. #7
    gmlinux
    O cups pode estar integrado ao samba (ldd smbd deve mostrar libcups), neste caso pode falhar o que eu disse, dai, deve-se alterar
    printing = bsd
    Desta forma, ele não usa a libcups, ele usa os comando lpr/lpq para enviar para a fila, ai, talvez a alteração dos comandos tenham efeito.
  3. #8
    slice
    Citação Postado originalmente por edisonjr
    valeu pela dica, vou testar imediatamente, mas me surgiu uma dúvida a partir disso:
    Qual a opção que tu usa no parâmetro printing da sessão global do seu smb.conf...
    Não deve ser cups??
    uso as opções abaixo:
    load printers = yes
    printing = bsd
    []´s
    Slice
  1. Impressora PDF no Linux, simples como DoPDF
    Por chicobento no fórum Servidores de Rede
    Último Post: 18-08-2010, 07:31
  2. [AJUDA] Impressora virtual PDF - SAMBA - Debian Lenny - 5.04
    Por aki00 no fórum Servidores de Rede
    Último Post: 17-06-2010, 16:32
  3. impressora virtual de PDF
    Por lucianogf no fórum Servidores de Rede
    Último Post: 01-08-2006, 16:28
  4. impressora virtual pdf no samba
    Por whinston no fórum Servidores de Rede
    Último Post: 16-12-2004, 00:20
  5. Configurando impressora? HELP!!!
    Último Post: 24-04-2003, 13:56
