Página 6 de 8 PrimeiroPrimeiro ... 2345678 ÚltimoÚltimo
    serhumano
    ae.. deu isso ae kara... eu num entendi pra q serve não.. foi mal :s
    root@cable:~# type modprobe
    modprobe is /sbin/modprobe
    root@cable:~# ldd /sbin/modprobe
    libc.so.6 => /lib/libc.so.6 (0x4002c000)
    /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
    root@cable:~# uname -r
    2.4.26
    root@cable:~#
    root@cable:~# ls /lib/modules
    2.4.26 2.6.9
    root@cable:~#
  2. #27
    gmlinux
    dando boot pelo kernel 2.6,
    uname -r
    retorna o que? 2.6.9?
    o comando
    modprobe -c
    retorna algo?
  3. #28
    serhumano
    os resultados estão ae...
    2.6.9
    root@cable:~# modprobe -c
    # Aliases extracted from modules themselves.
    alias usb:v06C2p0038dl*dh*dc*dsc*dp*ic*isc*ip* phidgetservo
    alias usb:v06C2p0039dl*dh*dc*dsc*dp*ic*isc*ip* phidgetservo
    alias usb:v0925p8101dl*dh*dc*dsc*dp*ic*isc*ip* phidgetservo
    alias usb:v0925p8104dl*dh*dc*dsc*dp*ic*isc*ip* phidgetservo
    alias usb:v04B4p0002dl*dh*dc*dsc*dp*ic*isc*ip* cytherm
    alias usb:v3823p0001dl*dh*dc*dsc*dp*ic*isc*ip* touchkitusb
    alias usb:v0EEFp0001dl*dh*dc*dsc*dp*ic*isc*ip* touchkitusb
    alias pci:v0000105Ad00006622sv*sd*bc*sc*i* sata_sx4
    alias pci:v00001039d00000180sv*sd*bc*sc*i* sata_sis
    alias pci:v00001039d00000181sv*sd*bc*sc*i* sata_sis
    alias pci:v00001069d0000B166sv00001014sd00000266bc*sc*i* ipr
    alias pci:v00001069d0000B166sv00001014sd000002D3bc*sc*i* ipr
    alias pci:v00001069d0000B166sv00001014sd00000278bc*sc*i* ipr
    alias pci:v00001069d0000B166sv00001014sd000002D4bc*sc*i* ipr
    alias pci:v00001014d0000028Csv00001014sd000002BEbc*sc*i* ipr
    alias pci:v00001014d00000180sv00001014sd00000264bc*sc*i* ipr
    alias pci:v00001014d00000180sv00001014sd000002BDbc*sc*i* ipr
    alias pci:v00001044d0000A501sv*sd*bc*sc*i* dpt_i2o
    alias pci:v00001044d0000A511sv*sd*bc*sc*i* dpt_i2o
    alias pci:v000017D5d00005731sv*sd*bc*sc*i* s2io
    alias pci:v000017D5d00005831sv*sd*bc*sc*i* s2io
    alias pci:v00008086d00002570sv*sd*bc06sc00i00* intel_mch_agp
    alias pci:v00008086d00002578sv*sd*bc06sc00i00* intel_mch_agp
    # Aliases for symbols, used by symbol_request().
    alias symbol:request_firmware firmware_class
    alias symbol:request_firmware_nowait firmware_class
    alias symbol:crc32c_be libcrc32c
    alias symbol:crc32c_le libcrc32c
    alias symbol:firmware_class firmware_class
    alias symbol:register_firmware firmware_class
    alias symbol:release_firmware firmware_class
    root@cable:~#
  4. #29
    gmlinux
    Bom, agora precisamos escolher um módulo para carregar, vamos tentar a placa de rede, primeiro vamos ver se ela já esta carregada:
    ifconfig -a
    se ela não estiver carregada, a eth0 não aparecerá (assumi que você só possui uma interface de rede)
    Agora precisamos saber qual módulo usar, você sabe qual o módulo, ou pelo menos qual a placa? (se for pci, lspci ou cat /proc/pci, pode ajudar)
    sabendo o módulo, execute
    modprobe módulo
    omita a extensão ko do nome do módulo
  5. #30
    serhumano
    eu tentei carregar o módulo da placa de vídeo....
    modprobe sis900
    aí deu isso
    FATAL: Module sis900 not found.
  1. Como Compilar kernel 2.4.18 com suporte pcmcia
    Por ebortolin no fórum Servidores de Rede
    Último Post: 03-06-2003, 12:57
  2. Respostas: 19
    Último Post: 18-12-2002, 08:38
  3. Como recompilar o kernel Passo a Passo ???
    Último Post: 13-09-2002, 22:33
  4. Atualizando Kernel... Internet
    Respostas: 6
    Último Post: 12-09-2002, 11:49
  5. kernel
    Por vanilia_sky no fórum Servidores de Rede
    Último Post: 08-09-2002, 22:44
