    Nocturno_Culto
    Padrão Instalar o raidtools
    como instalar o raid tools no slackware 10??
    peguei o pacote tar.gz
    Palma palma nao criamos canico....
    Qq tu quer fazer com o raidtools?
    slice
    installpkg raidtools-version.tgz
    para configurar... man raidtools lá tem um modelo do arquivo que vc vai ter que criar... /etc/raidtab
    Nocturno_Culto
    kras desculpem pela demora
    qndo eu dou o make ele apresenta o seguinte erro:
    [email protected]:/usr/local/raidtools-0.41# make
    gcc -g -O2 -I/usr/src/linux/include -DMD_VERSION=\""raidtools-0.41"\" -c -o mdadd.o mdadd.c
    In file included from mdadd.c:18:
    common.h:23:22: linux/md.h: No such file or directory
    common.h:39: error: parse error before "md_superblock_t"
    common.h:39: warning: no semicolon at end of struct or union
    common.h:40: error: `MD_SB_DISKS' undeclared here (not in a function)
    common.h:41: error: `MD_SB_DISKS' undeclared here (not in a function)
    common.h:42: error: `MD_SB_DISKS' undeclared here (not in a function)
    common.h:45: error: parse error before '}' token
    common.h:45: warning: data definition has no type or storage class
    mdadd.c: In function `do_mdadd':
    mdadd.c:61: error: `FLOPPY_MAJOR' undeclared (first use in this function)
    mdadd.c:61: error: (Each undeclared identifier is reported only once
    mdadd.c:61: error: for each function it appears in.)
    mdadd.c:66: error: `REGISTER_DEV' undeclared (first use in this function)
    mdadd.c: In function `do_mdstart':
    mdadd.c:78: error: `START_MD' undeclared (first use in this function)
    mdadd.c: In function `do_mdstop':
    mdadd.c:89: error: `STOP_MD' undeclared (first use in this function)
    mdadd.c: In function `main':
    mdadd.c:158: error: `LINEAR' undeclared (first use in this function)
    mdadd.c:162: error: `RAID0' undeclared (first use in this function)
    mdadd.c:166: error: `RAID1' undeclared (first use in this function)
    mdadd.c:171: error: `RAID5' undeclared (first use in this function)
    mdadd.c:208: error: `FAULT_SHIFT' undeclared (first use in this function)
    mdadd.c: At top level:
    common.h:40: error: storage size of `sb_block_offset' isn't known
    common.h:41: error: storage size of `device_name' isn't known
    common.h:42: error: storage size of `sb_present' isn't known
    make: *** [mdadd.o] Error 1
    slice
    como já disse anteriormente...
    wget http://www.slackware.at/data/slackwa...0.3-i386-1.tgz
    installpkg raidtools-1.00.3-i386-1.tgz
    flw!
    Slice
    Lestat1
    Amigo, eu uso o Slack10 com raid, e ele já vem com a instalação full.
    Procure no seu CD e instale:
    installpkg raid...
    slice
    Citação Postado originalmente por Lestat1
    installpkg raid...
    [email protected]:~$ mount /mnt/cdrom/
    mount: block device /dev/hdd is write-protected, mounting read-only
    [email protected]:~$ cd /mnt/cdrom/slackware/ap/
    [email protected]:/mnt/cdrom/slackware/ap$ cat raidtools-1.00.3-i386-1.txt
    raidtools: raidtools (software RAID tools)
    raidtools:
    raidtools: The raidtools package includes the system utilities you need to set up
    raidtools: and maintain a software RAID device (using two or more disk drives in
    raidtools: combination for fault tolerance and improved performance) on a Linux
    raidtools: system.
    raidtools:
    raidtools:
    raidtools:
    raidtools:
    raidtools:
    [email protected]:/mnt/cdrom/slackware/ap$ su
    Password:
    [email protected]:/mnt/cdrom/slackware/ap# installpkg raidtools-1.00.3-i386-1.tgz
    Installing package raidtools-1.00.3-i386-1 ([optional])...
    PACKAGE DESCRIPTION:
    raidtools:
    raidtools: system.
    raidtools:
    Executing install script for raidtools-1.00.3-i386-1...
    [email protected]:/mnt/cdrom/slackware/ap# exit
    [email protected]:/mnt/cdrom/slackware/ap$ cd /home/slice/
    [email protected]:~$ umount /mnt/cdrom/
    [email protected]:~$are good for you boy?!
    Nocturno_Culto
    fiz entao: installpkg raidtools*.tgz
    nao teu nenhum erro
    mas nao criou nenhum arquivo do raidtools
    nem arquivo para configuração
    estou usando o slackware 10
    com instalação full do mesmo;
    slice
    man raidtools
    man raidtab
    man raidstart
    man raidstop
    man raidhotadd
    no man raidtools tem o exemplo de como vc deve configurar o /etc/raidtab para teu raid funcionar corretamente, e esse arquivo deve ser configurado manualmente.
    no link abaixo teu um tutorial de como configurar o raidtools, lembrando que vc consegue fazer raid 0 e raid 1 tanto no mesmo hd, como em hd´s separados e também em direfentes filesystems...
    http://www.vivaolinux.com.br/artigos...php?codigo=954
    []´s
    Slice
    Nocturno_Culto
    Kra, eu acho q nao instalou
    [email protected]:/# man raidtools
    No manual entry for raidtools
    Nocturno_Culto
    [email protected]:/etc/rc.d# whereis raidtools
    raidtools:
    Nocturno_Culto
    [email protected]:/public# installpkg raidtools-1.00.3-i386-1.tgz
    Installing package raidtools-1.00.3-i386-1...
    raidtools:
    raidtools: system.
    raidtools:
