    nacovolo
    Olá pessoal ...
    Instalei no RH 9 o vsftpd-1.2.1 ... usei o tutorial diposnivel em http://www.vsftpdrocks.org/source/
    o serviço do vsftpd esta sendo iniciado sem problema ... inclusive estou conseguindo logar como anonymous ...
    daí eu criei uma usuário no linux ... e eu gostaria de acessar o ftp por esse usuário ... só que não está sendo possivel ...
    [root@dbserver etc]# ftp localhost
    Connected to localhost (127.0.0.1).
    220 (vsFTPd 1.2.1)
    Name (localhost:root): nelson
    530 This FTP server is anonymous only.
    Login failed.
    ftp>
    alguém poderia me ajudar?
    Eu acho que dever ser algum parametro do meu arquivo vsftpd.conf
    segue abaixo o meu arquivo vsftpd.conf
    # Example config file /etc/vsftpd.conf
    # The default compiled in settings are fairly paranoid. This sample file
    # loosens things up a bit, to make the ftp daemon more usable.
    # Please see vsftpd.conf.5 for all compiled in defaults.
    # READ THIS: This example file is NOT an exhaustive list of vsftpd options.
    # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
    # capabilities.
    # Allow anonymous FTP? (Beware - allowed by default if you comment this out).
    anonymous_enable=YES
    # Uncomment this to allow local users to log in.
    local_enable=YES
    # Uncomment this to enable any form of FTP write command.
    write_enable=YES
    # Default umask for local users is 077. You may wish to change this to 022,
    # if your users expect that (022 is used by most other ftpd's)
    #local_umask=022
    # Uncomment this to allow the anonymous FTP user to upload files. This only
    # has an effect if the above global write enable is activated. Also, you will
    # obviously need to create a directory writable by the FTP user.
    #anon_upload_enable=YES
    # Uncomment this if you want the anonymous FTP user to be able to create
    # new directories.
    #anon_mkdir_write_enable=YES
    # Activate directory messages - messages given to remote users when they
    # go into a certain directory.
    dirmessage_enable=YES
    # Activate logging of uploads/downloads.
    xferlog_enable=YES
    # Make sure PORT transfer connections originate from port 20 (ftp-data).
    connect_from_port_20=YES
    # If you want, you can arrange for uploaded anonymous files to be owned by
    # a different user. Note! Using "root" for uploaded files is not
    # recommended!
    #chown_uploads=YES
    #chown_username=whoever
    # You may override where the log file goes if you like. The default is shown
    # below.
    #xferlog_file=/var/log/vsftpd.log
    # If you want, you can have your log file in standard ftpd xferlog format
    #xferlog_std_format=YES
    # You may change the default value for timing out an idle session.
    #idle_session_timeout=600
    # You may change the default value for timing out a data connection.
    #data_connection_timeout=120
    # It is recommended that you define on your system a unique user which the
    # ftp server can use as a totally isolated and unprivileged user.
    #nopriv_user=ftpsecure
    # Enable this and the server will recognise asynchronous ABOR requests. Not
    # recommended for security (the code is non-trivial). Not enabling it,
    # however, may confuse older FTP clients.
    #async_abor_enable=YES
    # By default the server will pretend to allow ASCII mode but in fact ignore
    # the request. Turn on the below options to have the server actually do ASCII
    # mangling on files when in ASCII mode.
    # Beware that turning on ascii_download_enable enables malicious remote parties
    # to consume your I/O resources, by issuing the command "SIZE /big/file" in
    # ASCII mode.
    # These ASCII options are split into upload and download because you may wish
    # to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
    # without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
    # on the client anyway..
    #ascii_upload_enable=YES
    #ascii_download_enable=YES
    # You may fully customise the login banner string:
    #ftpd_banner=Welcome to blah FTP service.
    ftpd_banner=Welcome to Oleos Menu FTP service.
    # You may specify a file of disallowed anonymous e-mail addresses. Apparently
    # useful for combatting certain DoS attacks.
    #deny_email_enable=YES
    # (default follows)
    #banned_email_file=/etc/vsftpd.banned_emails
    # You may specify an explicit list of local users to chroot() to their home
    # directory. If chroot_local_user is YES, then this list becomes a list of
    # users to NOT chroot().
    #chroot_list_enable=YES
    # (default follows)
    #chroot_list_file=/etc/vsftpd.chroot_list
    # You may activate the "-R" option to the builtin ls. This is disabled by
    # default to avoid remote users being able to cause excessive I/O on large
    # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
    # the presence of the "-R" option, so there is a strong case for enabling it.
    #ls_recurse_enable=YES
    listen=NO
    # Grava todos os acessos dos usuario em /var/log/messages
    sys_log=YES
    Desde já agradeço a atenção e colaboração de todos.
    Atenciosamente,
    Nelson Antonio
  2. Ja tentou logar de outra máquina pela rede?
    nacovolo
    já ...
    mas naum consegui ainda ...
  4. Tente rodar o vsftpd em modo standalone. Alterando os seguintes parametros:
    listen=YES
    tcp_wrappers=YES
    nacovolo
    ainda não deu certo não ...
    só estou conseguindo conectar como anonymous ...
    outra coisa ...
    o que eu devo fazer para que o meu vsftpd seja iniciado automaticamente todas as vezes que eu ligo minha máquina?
    Desde já, agradeço mais uma vez a atenção e colaboração de todos.
    Atenciosamente,
    Nelson Antonio
  1. Problemas na configuracao do X no slack
    Por vonlinkerstain no fórum Servidores de Rede
    Respostas: 7
    Último Post: 25-11-2004, 21:22
  2. Problemas na configuração do monitor no CL9
    Respostas: 12
    Último Post: 07-11-2004, 07:51
  3. problema na configuração do vsftpd
    Por roggy no fórum Servidores de Rede
    Último Post: 03-05-2004, 12:54
  4. problemas na instalação do vsftpd
    Último Post: 29-05-2003, 15:41
  5. problemas na autenticação do ncsa_auth no Red Hat 7.3
    Respostas: 14
    Último Post: 15-11-2002, 16:16
