    ApitaAqui
    # iptables -L
    Chain INPUT (policy DROP)
    target prot opt source destination
    ACCEPT tcp -- a212-113-164-54.netcabo.pt anywhere tcp flags:!SYN,RST,ACK/SYN
    ACCEPT udp -- a212-113-164-54.netcabo.pt anywhere
    ACCEPT tcp -- a212-113-164-46.netcabo.pt anywhere tcp flags:!SYN,RST,ACK/SYN
    ACCEPT udp -- a212-113-164-46.netcabo.pt anywhere
    ACCEPT tcp -- ns2.tvcabo.pt anywhere tcp flags:!SYN,RST,ACK/SYN
    ACCEPT udp -- ns2.tvcabo.pt anywhere
    ACCEPT tcp -- ns1.tvcabo.pt anywhere tcp flags:!SYN,RST,ACK/SYN
    ACCEPT udp -- ns1.tvcabo.pt anywhere
    ACCEPT all -- anywhere anywhere
    ACCEPT icmp -- anywhere a213-22-252-0.netcabo.pt/23 limit: avg 10/sec burst 5
    NR all -- !a213-22-252-0.netcabo.pt/23 anywhere
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:31337 limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpt:31337 limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:33270 limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpt:33270 limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:1234 limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:6711 limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:16660 flags:SYN,RST,ACK/SYN limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:60001 flags:SYN,RST,ACK/SYN limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpts:12345:12346 limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpts:12345:12346 limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:loc-srv limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpt:loc-srv limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:ingreslock limit: avg 2/min burst 5
    LD tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpt:27665 limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpt:27444 limit: avg 2/min burst 5
    LD udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpt:31335 limit: avg 2/min burst 5
    LD all -- BASE-ADDRESS.MCAST.NET/8 anywhere
    LD all -- anywhere BASE-ADDRESS.MCAST.NET/8
    LD all -- 255.255.255.255 anywhere
    LD all -- anywhere 0.0.0.0
    DROP all -- anywhere anywhere state INVALID
    LD all -f anywhere anywhere limit: avg 10/min burst 5
    ACCEPT tcp -- anywhere anywhere tcp dpts:bootps:bootpc
    ACCEPT udp -- anywhere anywhere udp dpts:bootps:bootpc
    LD tcp -- anywhere anywhere tcp flags:!SYN,RST,ACK/SYN state NEW
    STATE tcp -- anywhere a213-22-252-0.netcabo.pt/23 tcp dpts:1024:65535
    ACCEPT udp -- anywhere a213-22-252-0.netcabo.pt/23 udp dpts:1023:65535
    LD all -- anywhere anywhere
    Chain FORWARD (policy DROP)
    Chain OUTPUT (policy DROP)
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:31337 limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpt:31337 limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:33270 limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpt:33270 limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:1234 limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:6711 limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:16660 flags:SYN,RST,ACK/SYN limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:60001 flags:SYN,RST,ACK/SYN limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpts:12345:12346 limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpts:12345:12346 limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:loc-srv limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpt:loc-srv limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:ingreslock limit: avg 2/min burst 5
    LD tcp -- a213-22-252-0.netcabo.pt/23 anywhere tcp dpt:27665 limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpt:27444 limit: avg 2/min burst 5
    LD udp -- a213-22-252-0.netcabo.pt/23 anywhere udp dpt:31335 limit: avg 2/min burst 5
    DROP tcp -- anywhere anywhere tcp flags:!SYN,RST,ACK/SYN state NEW
    all -- anywhere anywhere TTL match TTL == 64
    ACCEPT icmp -- a213-22-252-0.netcabo.pt/23 anywhere
    Chain LD (137 references)
    LOG all -- anywhere anywhere LOG level info
    Chain NR (1 references)
    LD all -- 0.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 1.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 2.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 5.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 7.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 10.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 23.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 27.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 31.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 36.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 37.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 39.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 41.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 42.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 49.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- 50.0.0.0/8 a213-22-252-0.netcabo.pt/23
    LD all -- ppp-net.infoweb.ne.jp/8 a213-22-252-0.netcabo.pt/23
    LD all -- 59.0.0.0/8 a213-22-252-0.netcabo.pt/23
    oh my god, apareçeu-me isto tudo.. e eu nunca mexi nisto.. secalhar é por causa disto.. como posso resolver isto ou abrir a porta do a mule? ou assim.. ty
  2. iptables -F
  3. Citação Postado originalmente por The-shadow
    iptables -F
    Isso mesmo com esse comando ele limpa todas as regras do iptables.
    falows
  4. #14
    iptables -P INPUT ACCEPT
    iptables -P FORWARD DROP
    iptables -P OUTPUT ACCEPT
    iptables -F
    iptables -F INPUT
    iptables -F OUTPUT
    iptables -X
  5. removendo as regras, esta tirando parte de sua segurança.
    Lembre-se disto
  1. AJUDEM ME. PLZ
    Por ehehe no fórum Servidores de Rede
    Último Post: 23-03-2004, 08:12
  2. AJUDEM ME A COMPARTILHAR NET COM LINUX CONECTIVA 8
    Por wlourenco no fórum Servidores de Rede
    Último Post: 16-03-2004, 13:13
  3. Ajudem me
    Por Bravo no fórum Servidores de Rede
    Último Post: 27-11-2003, 09:00
  4. ajudem me com meu slack 9. POR FAVOR
    Por augustoaf no fórum Servidores de Rede
    Respostas: 6
    Último Post: 14-07-2003, 12:12
  5. Ajudem me por favor
    Por jackberserk no fórum Servidores de Rede
    Último Post: 09-04-2003, 17:08
