    spider_man
    Padrão Dvd-Rw no Fedora 3
    Salve galera,
    Estou precisando intalar um drive de dvd para fazer Bkp nos servidores da empresa, mas antes disso estou testando na minha maquina. Estou tendado utilizar o cdrecorder, tranformei as pastas desejadas em .iso, identifiquei meu driver com o comando cdrecorder -scanbus e ele me retorna o seguinte:
    [[email protected] sbin]# cdrecorde -scanbus
    bash: cdrecorde: command not found
    [[email protected] sbin]# cdrecord -scanbus
    Cdrecord-Clone 2.01-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
    Note: This version is an unofficial (modified) version with DVD support
    Note: and therefore may have bugs that are not present in the original.
    Note: Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla
    Note: The author of cdrecord should not be bothered with problems in this version.
    scsidev: 'ATA'
    devname: 'ATA'
    scsibus: -2 target: -2 lun: -2
    Linux sg driver version: 3.5.27
    Using libscg version 'schily-0.8'.
    cdrecord: Warning: using inofficial libscg transport code version (schily - Red Hat-scsi-linux-sg.c-1.83-RH '@(#)scsi-linux-sg.c 1.83 04/05/20 Copyright 1997 J. Schilling').
    scsibus0:
    0,0,0 0) *
    cdrecord: Warning: controller returns wrong size for CD capabilities page.
    0,1,0 1) ' ' 'CD56XI ' 'A4CH' Removable CD-ROM
    0,2,0 2) *
    0,3,0 3) *
    0,4,0 4) *
    0,5,0 5) *
    0,6,0 6) *
    0,7,0 7) *
    scsibus1:
    1,0,0 100) 'HL-DT-ST' 'DVDRAM GSA-4163B' 'A100' Removable CD-ROM
    1,1,0 101) *
    1,2,0 102) *
    1,3,0 103) *
    1,4,0 104) *
    1,5,0 105) *
    1,6,0 106) *
    1,7,0 107) *
    na hora de gravar eu dou o seguinte comando:
    cdrecord dev=1,0,0 -v speed=8 -eject -data /nome_do_arquivo.iso
    cdrecord: No write mode specified.
    cdrecord: Asuming -tao mode.
    cdrecord: Future versions of cdrecord may have different drive dependent defaults.
    cdrecord: Continuing in 5 seconds...
    TOC Type: 1 = CD-ROM
    scsidev: '1,0,0'
    scsibus: 1 target: 0 lun: 0
    cdrecord: Success. Cannot open SCSI driver.
    cdrecord: For possible targets try 'cdrecord -scanbus'.
    cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
    Alguem sabe como eu posso resolver este problema? Não precisa ser com o cdrecorder, pode ser qualquer programa, a unica coisa que eu preciso eh que seja em texo para poder ser feito via ssh.
    Valeu
    ja usou o cdrao??
    falows
    spider_man
    Não, soh tentei usar o cdrecorder. Tem algum tutorial sobre ele? Eu acho que meu problema esta em meu dvd-rw não estar sendo reconhecido como ide scsi.
    Acho que tenho que subir o modulo ide=scsi, mas como fazer com que o driver seja reconhecido como scsi???
    spider_man
    Galera
    Me deram a dica de tentar gravar usando o seguinte comando
    cdrecord -v -fs=16M speed=16 -data nome_do_arquivo.iso
    Quando faço isso acho que o cd recorder assume que o dvd-rw esta em /dev/cdrom, mas no fedora ele monta por padrao em /media/cdrecorder
    Alguem tem alguma ideia???
    Valeu
    underground-sa
    Padrão fedora
    estou com o mesmo problema aki mas no meu caso eu kero usar o apt no cdrom...mas o apt só reconhece se for no /mnt/cdrom...
    bom como vc só ker gravar cds...tenta editar o /etc/fstab
    vi /etc/fstab e trok la onde aparecer /media/cdrecorder coloca /mnt/cdrecorder ou /dev/cdrecorder
    e naum eskece de criar o diretorio cdrecorder em /mnt ou /dev
    espero ter ajudado e agora tb vou tentar gravar cds aki...mas minha briga mesmo é om o apt...se alguem puder ajudar ae!!!
    spider_man
    Valeu galera!!!
    Consegui gravar sem alterar nada!!! Simples mente usei -dev=/dev/ndc e rolou!!!
    /media/cdrecorder eh tipo um link para o /dev/hdc! Agora ta blz!
