    winck
    Padrão problemas para instalar amsn0_94
    nao estou conseguindo instalar o amsn, tenho pouca experiencia em linux, e gostaria q alguem me ajudace...
    obrigado!!
    se vc nao falar oq ta dando de errado ninguem vai poder te ajudar...
    winck
    [[email protected] root]# ls
    amsn-0_94 Desktop smb.conf vsftpd-1.2.0
    amsn-0_94.tar.gz install.log upgrade.log vsftpd-1.2.0.tar.gz
    anaconda-ks.cfg install.log.syslog upgrade.log.syslog vsftpd-1.2.0.tar.gz.1
    [[email protected] root]# cd amsn-0_94
    [[email protected] amsn-0_94]# ls
    abook.tcl blocking.tcl GNUGPL migmd5.tcl remote.tcl
    alarm.tcl chatwindow.tcl groups.tcl mutex.tcl skins
    amsn combobox.tcl gui.tcl notes.tcl skins.tcl
    amsn.debianmenu config.tcl HELP plugins smileys.tcl
    amsn.desktop CREDITS hotmail.tcl plugins.tcl sndplay
    amsn-remote ctadverts.tcl hotmlog.htm png.tcl socks.tcl
    amsn-remote-CLI ctthemes.tcl icons preferences.tcl sxml.tcl
    amsn.spec cvs_date lang progressbar.tcl TODO
    anigif.tcl des.tcl langlist protocol.tcl trayicon.tcl
    AppMain.tcl dock.tcl lang.tcl proxy.tcl utils
    automsg.tcl docs loging.tcl README xmms.tcl
    balloon.tcl FAQ Makefile remote.help
    [[email protected] amsn-0_94]# ./amsn
    /usr/bin/env: wish: Arquivo ou diretório não encontrado
    se vc olhar na documentacao dele ou mesmo no site no FAQ vc vai ver que eh necessario instalar o tcl e o tk pra rodar o amsn...
    sem eles nao existe o comando wish q vai rodar o msn
    winck
    [[email protected] unix]# ls
    aclocal.m4 install-sh tclLoadDl.c tclUnixChan.c tclUnixSock.c
    confdefs.h ldAix tclLoadDld.c tclUnixEvent.c tclUnixTest.c
    config.cache Makefile.in tclLoadDyld.c tclUnixFCmd.c tclUnixThrd.c
    config.log README tclLoadNext.c tclUnixFile.c tclUnixThrd.h
    configure tclAppInit.c tclLoadOSF.c tclUnixInit.c tclUnixTime.c
    configure.in tclConfig.sh.in tclLoadShl.c tclUnixNotfy.c tclXtNotify.c
    dltest tclLoadAix.c tcl.m4 tclUnixPipe.c tclXtTest.c
    installManPage tclLoadAout.c tcl.spec tclUnixPort.h
    [[email protected] unix]# ./configure
    loading cache ./config.cache
    checking whether to use symlinks for manpages... no
    checking whether to compress the manpages... no
    checking whether to add a package name suffix for the manpages... no
    checking for gcc... no
    checking for cc... no
    configure: error: no acceptable cc found in $PATH
    vixi......... vc vai ter muuuuuuuuito trabalho ainda
    vai faltar instalar o gcc,glibc,libc,etc....
    q distro vc ta usando?
    winck
    red hat 9...
    me passa em ordem tudo o q preciso para instalar!!
    winck
    tu tem msn??
    faz o seguinte, se vc tiver o apt instalado ai
    roda
    apt-get install tcl
    q ele jah vai instalar todas as dependencias
    winck
    qual arquivo eu devo usar o comando q vc acabou de me passar??
    eu so novato em linux!!
    eh soh executar o comando no terminal, nao tem arquivo nenhum
