  1. Olá !!!
    Para começar vc deve compilar o driver, ele não é nativo do kernel, nem do 2.4 e nem 2.6, para começar veja se ele reconheceu as placas com o comando
    # cat /proc/pci
    Caso ela lista basta vc compilar o driver e criar o script para levantar o módulo da placa, tem o script no site do emota.com.br
    Att...
    Gaby
    olha eu já tentei isso e o kernel que eu quero é o 2.6 veja os resultados da compilação do driver:
    # [root@neo Linux]# make
    # make[1]: Entering directory `/home/tester/Desktop/wireless/Am1771/Linux/Knet'
    # gcc -MM -DEXPORT_SYMTAB -DMODULE -D__KERNEL__ -DLINUX -DCONFIG_PROC_FS -I/home/tester/Desktop/wireless/Am1771/Linux/../Include -I/usr/src/linux/include -Wall -DNAUTILUS_CFG_PLATF_X86 -DNAUTILUS_CFG_PCI -DNAUTILUS_SYSTEM_IS_MAC_SME_TARGET -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=`uname -m` -malign-functions=4 -fno-omit-frame-pointer -Os -DCONFIG_KMOD -DEXPORT_SYMTAB -DMODULE -D__KERNEL__ -DLINUX -DCONFIG_PROC_FS -I/home/tester/Desktop/wireless/Am1771/Linux/../Include -I/usr/src/linux/include -Wall -DNAUTILUS_CFG_PLATF_X86 -DNAUTILUS_CFG_PCI -DNAUTILUS_SYSTEM_IS_MAC_SME_TARGET -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=`uname -m` -malign-functions=4 -fno-omit-frame-pointer -Os -I/home/tester/Desktop/wireless/Am1771/Linux/../Include -I/usr/src/linux/include -I../Include -I../../Include \
    # Knet.c > GNUmakefile.dep
    # cc1: warning: -malign-functions is obsolete, use -falign-functions
    # In file included from ../Include/Interfaces.h:56,
    # from Knet.h:56,
    # from Knet.c:56:
    # ../Include/Sysdep.h:106:4: #error "This kernel is too recent: not supported by this file"
    # In file included from /usr/src/linux/include/linux/sched.h:12,
    # from ../Include/Sysdep.h:137,
    # from ../Include/Interfaces.h:56,
    # from Knet.h:56,
    # from Knet.c:56:
    # /usr/src/linux/include/linux/jiffies.h:385:41: division by zero in #if
    # /usr/src/linux/include/linux/jiffies.h:396:18: division by zero in #if
    # /usr/src/linux/include/linux/jiffies.h:416:41: division by zero in #if
    # /usr/src/linux/include/linux/jiffies.h:432:28: division by zero in #if
    # In file included from /usr/src/linux/include/linux/interrupt.h:11,
    # from ../Include/Os_if.h:75,
    # from ../Include/Interfaces.h:63,
    # from Knet.h:56,
    # from Knet.c:56:
    # /usr/src/linux/include/linux/hardirq.h:104:26: macro "irq_exit" passed 1 arguments, but takes just 0
    # make[1]: ** [depend] Erro 1
    # make[1]: Leaving directory `/home/tester/Desktop/wireless/Am1771/Linux/Knet'
    # make: ** [all_sub] Erro 1
    SOCORROOOOOOOOO!!
  2.    Publicidade
  3. Citação Postado originalmente por pintadense
    nem com ndiswrapper funciona?
    Pior que não já tô quase querendo vender ela pros cplecionadores de ruindows, mas é um desacato essa coisa não funcionar!
    Usei o seguite:
    #ndiswrapper -i /mnt/cdrom/Driver/xp2k/NetAm772.inf
    #ndiswrapper -l
    #netam772 driver present hardware present
    #modprobe ndiswrapper
    #lsmod
    após este comando eu tenho a certeza que o módulo ndiswrapper foi carregado mas na hora de executar o iwconfig ou iwlist para verificar não dá nada, pra falar a verdade, eu esbarrei mesmo foi no wlan0 eu não o acho de forma alguma, nem sei o que fazer para criá-lo, não consegui maiores detalhes na net é exibido apenas o "lo" e "eth0" :roll:
    uso o conectiva linux 10 kernel 2.6.11 kde 3.3 e em outra partição o kde 3.4 (sei que o que vale mesmo é o kernel)
    se alguém conhecer bem o ndiswrapper favor apontar onde está um provável erro, ou se o erro é mesmo o meu por ter comprado essa placa.
    Valew
    Ola amigo, vc deve tbm criar a confg da interface wlan0 la no /etc/sysconfig/networ-scripts/ifcfg-wlan0 com esse conteúdo
    DEVICE=wlan0
    BOOTPROTO=static
    BROADCAST=192.164.208.3
    IPADDR=192.164.208.2
    NETMASK=255.255.255.252
    NETWORK=192.164.208.0
    GATEWAY=192.164.208.1
    ONBOOT=yes
    Mude de acordo com sua rede, depois de um boot e tente levantar a interface!!! Posta o resultado aê depois!!
    :good:
  4. Já fiz essa configuração e a rede não levanta, dá "atrasando wlan0" interessante é que o módulo ndiswrapper está carregado segundo o comando lsmod.
    Mas na hora de executar o iwconfig ..... NADA! o dispositivo não existe, nem no kurumin 4.1 que tem scripts bons ela levanta.
  5.    Publicidade
