    Padrão Não acessando outros ambientes apos install Driver Nvidia
    ae galera... naum estou conseguindo acessar outros ambientes depois q instalei o driver da Nvidia... tipo do ctrl+alt+f1 até o f6 num consigo acessar... o monitor entra em stand by
    alguem ae tem noção do q pode tá acontecendo?
    galera... ajuda ae... li o readme da nvidia inteiro e num consegui chegar numa soulução....
    posta seu /etc/inittab ae
    Citação Postado originalmente por 1c3_m4n
    tá logo abaixo... brigadu
    # inittab This file describes how the INIT process should set up
    # the system in a certain run-level.
    # Author: Miquel van Smoorenburg, <[email protected]>
    # Modified for RHS Linux by Marc Ewing and Donnie Barnes
    # Default runlevel. The runlevels used by RHS are:
    # 0 - halt (Do NOT set initdefault to this)
    # 1 - Single user mode
    # 2 - Multiuser, without NFS (The same as 3, if you do not have networking)
    # 3 - Full multiuser mode
    # 4 - unused
    # 5 - X11
    # 6 - reboot (Do NOT set initdefault to this)
    # System initialization.
    si::sysinit:/etc/rc.d/rc.sysinit
    l0:0:wait:/etc/rc.d/rc 0
    l1:1:wait:/etc/rc.d/rc 1
    l2:2:wait:/etc/rc.d/rc 2
    l3:3:wait:/etc/rc.d/rc 3
    l4:4:wait:/etc/rc.d/rc 4
    l5:5:wait:/etc/rc.d/rc 5
    l6:6:wait:/etc/rc.d/rc 6
    # Trap CTRL-ALT-DELETE
    ca::ctrlaltdel:/sbin/shutdown -t3 -r now
    # When our UPS tells us power has failed, assume we have a few minutes
    # of power left. Schedule a shutdown for 2 minutes from now.
    # This does, of course, assume you have powerd installed and your
    # UPS connected and working correctly.
    pf:owerfail:/sbin/shutdown -f -h +2 "Power Failure; System Shutting Down"
    # If power was restored before the shutdown kicked in, cancel it.
    pr:12345owerokwait:/sbin/shutdown -c "Power Restored; Shutdown Cancelled"
    # Run gettys in standard runlevels
    1:2345:respawn:/sbin/mingetty tty1
    2:2345:respawn:/sbin/mingetty tty2
    3:2345:respawn:/sbin/mingetty tty3
    4:2345:respawn:/sbin/mingetty tty4
    5:2345:respawn:/sbin/mingetty tty5
    6:2345:respawn:/sbin/mingetty tty6
    # Run xdm in runlevel 5
    x:5:respawn:/etc/X11/prefdm -nodaemon
    faz um teste ae
    troca /sbin/mingetty por /sbin/agetty
    mas troka soh no 4,5,6, depois entra entrar nos consoles alt+f4,etc.. se funfar ai vc troca em todos
    deu certo naum ice.. to desesperado já :cry: ... olha ae como tá agora... mas tipo num deu certo blz.. mas q q se tava tentando fazer??? esse agetty e mingetty são programas?? e vc estava tentando troca-los??
    # 4 - unused
    # 5 - X11
    4:2345:respawn:/sbin/agetty tty4
    5:2345:respawn:/sbin/agetty tty5
    6:2345:respawn:/sbin/agetty tty6
    vc recompilou o kernel neh???? qdo vc boota a maquina aparece as linhas dos comandos normal?
    PS: o agetty mingetty entre outros eh o responsavel pelos terminais
    eu propriamente naum... só se for o driver q fez issu... nem sei recompilar essa joça... no boot aparece os serviços q tá carregando e tal...mas quando reinicia a maquina o monitor desliga e fica um tempo (terminando os serviços creio eu) e ae reinicia... mesma coisa quando vai desligar
    Citação Postado originalmente por gargwlas
    cara vc habilitou o logun garfico automatico?
    eu tinha esse pro de naum conseguir acessar o terminal qdo colokei o rc.4 start no rc.local ai meus termnais crtl + alt f1,2,3,4,45,6 foram p o espaço, ele soh entrava em standby e mais nd e soh voltaram qdo eu retirei
    Que distro você tá usando?
    caras... to digtando a senha pra entrar no sistema... e estou usando o Red Hat 9
    up!!
    Coincidentemente eu tive um problema com isso no Debian estes dias.
    Quando eu liguei o TV-OUT, ele não abriu outros terminais, mas quando eu desliguei o cabo, funcionou normal, acho que isso pode ser algo da frequência de atualização do monitor ou alguma incompatibilidade com o DRIVER.
    Abraços!
    ahn??? será cara?? num fala issu... eu uso aki o Video in e o Video Out pra variar... nossa de der certu vc naum sabe o tanto q irei pular de alegria... assim q chegar em casa irei testar e postarei o resultado. Alias.. como vc descobriu issu?? foi por acaso??
    Olá amigo, como vai? Espero que bem.
    Eu estava lendo o README da NVIDIA só por curiosidade e descobri que se você tem o módulo rivafb no seu kernel (modularizado ou built-in no kernel, tá?), ele vai dar problemas trocando os ambientes. Leia isto:
    Q: My system hangs when vt-switching if I have rivafb enabled.
    A: Using both rivafb and the NVIDIA kernel module at the same time is
    currently broken. In general, using two independent software drivers
    to drive the same piece of hardware is a bad idea.
    Quando eu fui olhar o meu kernel, adivinha o que eu encontrei? A porrinha da opção habilitada no kernel. Desmarquei e está funcionando belezinha...
    Citação Postado originalmente por xstefanox
    ihhh ae é pobrema hein... num tenho ideia de como meche no kernel.. alguma luz ae??
