  1. deu certo naum ice.. to desesperado já :cry: ... olha ae como tá agora... mas tipo num deu certo blz.. mas q q se tava tentando fazer??? esse agetty e mingetty são programas?? e vc estava tentando troca-los??
    # inittab This file describes how the INIT process should set up
    # the system in a certain run-level.
    # Author: Miquel van Smoorenburg, <miquels@drinkel.nl.mugnet.org>
    # Modified for RHS Linux by Marc Ewing and Donnie Barnes
    # Default runlevel. The runlevels used by RHS are:
    # 0 - halt (Do NOT set initdefault to this)
    # 1 - Single user mode
    # 2 - Multiuser, without NFS (The same as 3, if you do not have networking)
    # 3 - Full multiuser mode
    # 4 - unused
    # 5 - X11
    # 6 - reboot (Do NOT set initdefault to this)
    # System initialization.
    si::sysinit:/etc/rc.d/rc.sysinit
    l0:0:wait:/etc/rc.d/rc 0
    l1:1:wait:/etc/rc.d/rc 1
    l2:2:wait:/etc/rc.d/rc 2
    l3:3:wait:/etc/rc.d/rc 3
    l4:4:wait:/etc/rc.d/rc 4
    l5:5:wait:/etc/rc.d/rc 5
    l6:6:wait:/etc/rc.d/rc 6
    # Trap CTRL-ALT-DELETE
    ca::ctrlaltdel:/sbin/shutdown -t3 -r now
    # When our UPS tells us power has failed, assume we have a few minutes
    # of power left. Schedule a shutdown for 2 minutes from now.
    # This does, of course, assume you have powerd installed and your
    # UPS connected and working correctly.
    pf:owerfail:/sbin/shutdown -f -h +2 "Power Failure; System Shutting Down"
    # If power was restored before the shutdown kicked in, cancel it.
    pr:12345owerokwait:/sbin/shutdown -c "Power Restored; Shutdown Cancelled"
    # Run gettys in standard runlevels
    1:2345:respawn:/sbin/mingetty tty1
    2:2345:respawn:/sbin/mingetty tty2
    3:2345:respawn:/sbin/mingetty tty3
    4:2345:respawn:/sbin/agetty tty4
    5:2345:respawn:/sbin/agetty tty5
    6:2345:respawn:/sbin/agetty tty6
    # Run xdm in runlevel 5
    x:5:respawn:/etc/X11/prefdm -nodaemon
  2. vc recompilou o kernel neh???? qdo vc boota a maquina aparece as linhas dos comandos normal?
    PS: o agetty mingetty entre outros eh o responsavel pelos terminais
  3. Citação Postado originalmente por 1c3_m4n
    eu propriamente naum... só se for o driver q fez issu... nem sei recompilar essa joça... no boot aparece os serviços q tá carregando e tal...mas quando reinicia a maquina o monitor desliga e fica um tempo (terminando os serviços creio eu) e ae reinicia... mesma coisa quando vai desligar
  4. Citação Postado originalmente por gargwlas
    cara vc habilitou o logun garfico automatico?
    eu tinha esse pro de naum conseguir acessar o terminal qdo colokei o rc.4 start no rc.local ai meus termnais crtl + alt f1,2,3,4,45,6 foram p o espaço, ele soh entrava em standby e mais nd e soh voltaram qdo eu retirei
  5. Que distro você tá usando?
  1. como eu mudo para outro ambiente tipo gnome p fluxbox
    Por ldeftones no fórum Servidores de Rede
    Último Post: 12-02-2005, 18:27
  2. Squid acessando outro proxy
    Por crisduarte no fórum Servidores de Rede
    Último Post: 05-10-2004, 08:34
  3. Nome das Estacoes nao aparecem no Ambiente de Rede
    Por Rurouni_Kenshin no fórum Servidores de Rede
    Respostas: 5
    Último Post: 02-06-2004, 09:09
  4. Respostas: 1
    Último Post: 19-05-2004, 10:38
  5. Respostas: 5
    Último Post: 23-01-2003, 21:00
