    alexandresamorim
    Padrão Firebird+Slackware não inicial
    Olá boa noite, estou tentando instalar o FirebirdSS 1.5.1.tar.gz no slackware.
    1º a instalacão foi ok na instalalão me pediu a senha do sysdba coloquei e ok.
    2º então fui até o diretorio /ops/firebird/bin e digitei ./fbmgr -strat -user sysdba -password (senha) ai vem o problema..
    invalid switch
    syntax error in command line
    Obs..
    Ja fui em /etc/hosts e /etc/hosts.equiv e coloquei localhost.
    O que mais posso fazer?
    Obrigado dez de já a galera do forum
    Alexandre Amorim
    Código :
    #!/bin/sh
    # chkconfig: 345 20 80
    # description: Start/Stop firebird database server
    # This file belongs in /etc/init.d where it will be run
    # on system startup and shutdown to start the background
    # Firebird/interbase database server daemon
    FIREBIRD=/opt/firebird
    ISC_USER=SYSDBA
    ISC_PASSWORD=senhaakiiii!!!
    FBRunUser=firebird
    # WARNING: in a real-world installation, you should not put the
    # SYSDBA password in a publicly-readable file.
    # Eventually this file should not need to contain any passwords.
    # as root user alone should be sufficient privledge to stop/start
    # the server.
    export FIREBIRD
    export ISC_USER
    export ISC_PASSWORD
    # Check the file is there and is executable.
    [ -x $FIREBIRD/bin/fbmgr ] || exit 0
    # See how we were called.
    case "$1" in
      start)
    	echo -n "Starting Firebird server: "
            echo '$FIREBIRD/bin/fbmgr -start -forever' | su $FBRunUser
    	RETVAL=$?
      restart|reload)
    	$0 stop
    	$0 start
    	RETVAL=$?
      stop)
            echo -n "Parando serviço Firebird ..."
    	if ps -e | grep fbguard > /dev/null
    	then
    		killall fbguard
    		killall fbserver
    	fi
            echo "done."
            RETVAL=0
      status)
    	echo -n "Firebird Service Status ..."
    	if ps -e | grep fbguard > null
    	then
    		echo "Running"
    	else
    		echo "Stoped"
    	fi
    	echo "Usage: firebird {start|stop|restart}"
    	exit 1
    esac
    exit $RETVAL
    use este arkivo para inicia/parar o firebird... edite a senha no começo do arquivo....certifique-se que o usuario e grupo firebird estão criados...
    alexandresamorim
    Padrão script
    Primeira mente obrigado pela ajuda...
    Cara estou iniciando no slackware.... por isso quero por gentileza que me ajude a tornar esse texto em script..
    Bem fiz assim coloque ele com o nome de rc.firebird.sh
    Qual seria o [email protected]
    Obrigado..
    Alexandre Amorim
