  1. Pessoal boa tarde, estou aqui de novo e para variar um pouquinho procurando a ajuda de voces e contando com a paciência em mais um problema.
    Seguinte instalei o squid e fiz as configurações .conf. Starto o mesmo e aparentemente esta tudo em ordem, coloquei as configurações de proxy nos navegores (IE) dos clientes e os mesmos não navegam.
    Novamente não consigo achar o problema, mas vou colocar as mensagens do log (cache.log) para ver se alguem tem alguma ideia
    2005/05/05 17:01:59| Starting Squid Cache version 2.5.STABLE9 for i686-redhat-linux-gnu...
    2005/05/05 17:01:59| Process ID 4324
    2005/05/05 17:01:59| With 1024 file descriptors available
    2005/05/05 17:01:59| DNS Socket created at 0.0.0.0, port 1038, FD 5
    2005/05/05 17:01:59| Adding nameserver 200.204.0.10 from /etc/resolv.conf
    2005/05/05 17:01:59| Adding nameserver 200.204.0.138 from /etc/resolv.conf
    2005/05/05 17:01:59| User-Agent logging is disabled.
    2005/05/05 17:01:59| Referer logging is disabled.
    2005/05/05 17:01:59| Unlinkd pipe opened on FD 10
    2005/05/05 17:01:59| Swap maxSize 102400 KB, estimated 7876 objects
    2005/05/05 17:01:59| Target number of buckets: 393
    2005/05/05 17:01:59| Using 8192 Store buckets
    2005/05/05 17:01:59| Max Mem size: 8192 KB
    2005/05/05 17:01:59| Max Swap size: 102400 KB
    2005/05/05 17:01:59| Rebuilding storage in /var/spool/squid (DIRTY)
    2005/05/05 17:01:59| Using Least Load store dir selection
    2005/05/05 17:01:59| Set Current Directory to /var/spool/squid
    2005/05/05 17:01:59| Loaded Icons.
    2005/05/05 17:02:00| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
    2005/05/05 17:02:00| Accepting ICP messages at 0.0.0.0, port 3130, FD 12.
    2005/05/05 17:02:00| WCCP Disabled.
    2005/05/05 17:02:00| Ready to serve requests.
    2005/05/05 17:02:01| Done scanning /var/spool/squid swaplog (0 entries)
    2005/05/05 17:02:01| Finished rebuilding storage from disk.
    2005/05/05 17:02:01| 0 Entries scanned
    2005/05/05 17:02:01| 0 Invalid entries.
    2005/05/05 17:02:01| 0 With invalid flags.
    2005/05/05 17:02:01| 0 Objects loaded.
    2005/05/05 17:02:01| 0 Objects expired.
    2005/05/05 17:02:01| 0 Objects cancelled.
    2005/05/05 17:02:01| 0 Duplicate URLs purged.
    2005/05/05 17:02:01| 0 Swapfile clashes avoided.
    2005/05/05 17:02:01| Took 2.1 seconds ( 0.0 objects/sec).
    2005/05/05 17:02:01| Beginning Validation Procedure
    2005/05/05 17:02:01| Completed Validation Procedure
    2005/05/05 17:02:01| Validated 0 Entries
    2005/05/05 17:02:01| store_swap_size = 0k
    2005/05/05 17:02:02| storeLateRelease: released 0 objects
    Obrigado.
  2. da uma olhada no access.log pra ver se tem alguma coisa, vc setou o dns nos clientes tb?
  3. E ai Ice, olha eu te pertubando de novo né??
    Bom no access.log não tem nada e nos clientes win esta setado o dns.
    Nada tambem em squid.out e nem em strore.log
  4. teu fw num ta bloqueando os clientes nao?
  5. Bom fui no navegador e retirei o proxy, não navegou...
    Aí retirei a linha de direcionamento do firewall....
    #iptables -A FORWARD -s $LAN_IP_NET -p tcp --dport 3128 -j ACCEPT
    #iptables -t nat -A PREROUTING -s $LAN_IP_NET -p tcp -i eth1 --dport 80 -j DNAT --to $FORWARD_IP:3128
    ai navega normalmente.
    Alguma coisa errada aí nessa regra? A internet está na eth0 e a rede na eht1.
    Tenho que manter a conexão de recebimento de http na porta 80 pois tenho o bendito servidor das câmeras nela.
  1. Respostas: 9
    Último Post: 20-03-2015, 08:59
  2. Respostas: 9
  3. Squid funciona... Mas terminais podem navegar sem ser pelo proxy
    Por vfsmount no fórum Servidores de Rede
    Respostas: 5
    Último Post: 28-11-2006, 00:18
  4. NÃO PASSAR PELO PROXY(3128)
    Por rogeriotux no fórum Servidores de Rede
    Respostas: 7
    Último Post: 19-02-2004, 14:32
  5. Respostas: 2
    Último Post: 04-10-2003, 21:46
