    Padrão Logs do apache
    E ae povo baum?
    Seguinte to montando um pacote de regras pro layer7, principalmente pra bloquear akeles worms chatos da m$ ou entaum akeles ataques de iis, sei q essa porcaria num afeta em nada o apache mas pelo menos da pra bloquear antes dele chegar no apache.
    Se vcs tiverem mais logs desse tipo postem aki pra eu criar as regras, por enqto tenho essas:
    Código :
    /default\.ida\?NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
    NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
    NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
    NNNNNNNNNNNNNNNNNNNNNNNNNNNNN%u9090%u6858%ucbd3%u7801%u9090%u6858%ucbd3
    %u7801%u9090%u6858%ucbd3%u7801%u9090%u9090%u8190%u00c3%u0003%u8b00%u531b
    %u53ff%u0078%u0000%u00=a
    GET (/scripts/root\.exe\?/c\+dir|/MSADC/root\.exe\?/c\+dir|/c/winnt/system32/cmd\.exe\?
    /c\+dir|/d/winnt/system32/cmd\.exe\?/c\+dir|/scripts/\.\.%5c\.\./winnt/system32/cmd\.exe\?
    /c\+dir|/_vti_bin/\.\.%5c\.\./\.\.%5c\.\./\.\.%5c\.\./winnt/system32/cmd\.exe\?
    /c\+dir|/_mem_bin/\.\.%5c\.\./\.\.%5c\.\./\.\.%5c\.\./winnt/system32/cmd\.exe\?
    /c\+dir|/msadc/\.\.%5c\.\./\.\.%5c\.\./\.\.%5c/\.\.\xc1\x1c\.\./\.\.\xc1\x1c\.\./\.\.\xc1\x1c\.\.
    /winnt/system32/cmd\.exe\?/c\+dir|/scripts/\.\.\xc1\x1c\.\./winnt/system32/cmd\.exe\?
    /c\+dir|/scripts/\.\.\xc0/\.\./winnt/system32/cmd\.exe\?/c\+dir|/scripts/\.\.\xc0\xaf\.\.
    /winnt/system32/cmd\.exe\?/c\+dir|/scripts/\.\.\xc1\x9c\.\./winnt/system32/cmd\.exe\?
    /c\+dir|/scripts/\.\.%35c\.\./winnt/system32/cmd\.exe\?/c\+dir|/scripts/\.\.%35c\.\.
    /c\+dir|/scripts/\.\.%2f\.\./winnt/system32/cmd\.exe\?/c\+dir)
    /default.ida?XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXXXXXXX%u9090%u6858%ucbd3%u7801%u9090%u6858%ucbd3%u7801
    Agora tenho mais esses:
    Código :
    /scripts/..%255c%255c../winnt/system32/cmd.exe?/c+dir
    awstats.pl?configdir=|%20id%20|
    e esse repetindo esse codigo milhares de vezes:
    "SEARCH /\x90\x02\xb1\
    madem seus logs tb , vo montar o pacote de protocolos com elas e dps coloco pro pessoal fazer download
    pow.... fiquei curioso quando vi esse seu post maluco e fui ver o projeto q eh o layer7.... mto foda mesmo o kra hein?
    como vc estah implementando ele?
    []'s
    po enqto to tentando criar as rules pra ele certinho, mas o l7 tem um problema, ele soh consegue analizar o pacote qdo ele entra na maquina, intaum num da pra usa em conjunto com prerouting,etc...
    whinston
    Padrão estes mesmos
    nossa cara, da vontade de bater em cada corno que gera isto, pq sao milhares de linhas!!! mas sao estas q vc ja postou ae em cima
    Padrão Re: Logs do apache
    Poxa 1c3... não é melhor já utilizar o Snort? O l7, embora seja perfeito pra fazer um bloqueio por conteúdo do pacote, consome muito processamento...
