    JVKurumin
    Padrão Samba PDC - Windows XP nao encontra controlador de dominio
    hello community!!!
    e o seguinte, eu tenho o Samba rodando no meu servidor, o acesso com o meu host linux funciona, mas qdo tento colocar o SAMBA rodando como PDC, o Windows XP fala que nao pode encontrar um controlador de dominio na minha rede.
    WINDOWS " A domain controller for the domain LINUX could not be contacted".
    estou usando o SAMBA 2.2.3 para Debian.
    * eu ja configurei o smb.conf com as informacoes do dominio.. segue!!!
    [global]
    # Change this for the workgroup/NT-domain name your Samba server will part of
    netbios name = DEBIAN
    workgroup = LINUX
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    domain master = yes
    local master = yes
    os level = 80
    preferred master = yes
    security = user
    domain logons = yes
    wins support = yes
    logon path = \\%L\profiles\
    logon drive = Z:
    logon home = \\%L\profiles\
    domain admin group = root
    * e informacoes de compartilhamento... segue!!!!
    [netlogon]
    comment = Network Logon Service
    path = /home/samba/netlogon
    writable = no
    browsable = no
    [profiles]
    comment = Servidor de Dominio
    public = no
    path = /home/%u
    browsable = yes
    writable = yes
    create mask = 0600
    directory mask = 0700
    [printers]
    comment = All Printers
    browseable = no
    path = /tmp
    printable = yes
    public = no
    writable = no
    create mode = 0700
    * tambe executei o cmd testparm /etc/samba/smb.conf e esta tudo OK.
    * qdo eu verifico o estado do compartilhamento do server, essa e a resposta!!!
    Debian1:~# smbclient -L 10.0.0.1 -N
    added interface ip=10.0.0.1 bcast=10.0.0.255 nmask=255.255.255.0
    added interface ip=192.168.0.1 bcast=192.168.0.3 nmask=255.255.255.252
    Anonymous login successful
    Domain=[LINUX] OS=[Unix] Server=[Samba 2.2.3a-12.3 for Debian]
    Sharename Type Comment
    profiles Disk Servidor de Dominio
    IPC$ IPC IPC Service (Samba 2.2.3a-12.3 for Debian)
    ADMIN$ Disk IPC Service (Samba 2.2.3a-12.3 for Debian)
    Server Comment
    DEBIAN Samba 2.2.3a-12.3 for Debian
    Workgroup Master
    LINUX DEBIAN
    Debian1:~#
    * tambem criei o grupo "trust" para as maquinas
    groupadd trust
    * e a conta da maquina tb
    useradd -g trust -s /dev/null -d /dev/null vitor$
    smbpasswd -a -m lamer
    * root user no smbpasswd
    smbpasswd -a root
    * quando eu faco o teste com o nmblookup, essa e a resposta!!!
    Debian1:~# nmblookup -A -M 10.0.0.0
    Looking up status of 10.0.0.0
    DEBIAN <00> - M <ACTIVE>
    DEBIAN <03> - M <ACTIVE>
    DEBIAN <20> - M <ACTIVE>
    ..__MSBROWSE__. <01> - <GROUP> M <ACTIVE>
    LINUX <00> - <GROUP> M <ACTIVE>
    LINUX <1b> - M <ACTIVE>
    LINUX <1c> - <GROUP> M <ACTIVE>
    LINUX <1d> - M <ACTIVE>
    LINUX <1e> - <GROUP> M <ACTIVE>
    Debian1:~#
    e mesmo depois de tudo configurado, servidor restartado, a mensagem dizendo que o windows nao pode acha o controlador de dominio continua de qualquer jeito...
    quarquer ajuda sera de grande valor... obrigado
    Vitor - JVdebian
    cara vc adicionou a maquina no samba , e verifica tambem que ip esta no endereço de wins blz
    john_connor
    vitor, vc adicionou uma máquina no sistema outra no samba? ou foi só exemplo?
    jvdebian
    adicionei a maquina no smpasswd e no passwd tb!!! e nada, mas acho que o servidor, por algum motivo nao esta respondendo, pq quando tento setar ele no windows, ele me responde que o servidor de dominio nao pode ser encontrado!!!!
    Citação Postado originalmente por jvdebian
    tenta colocar o ip desse server samba como dns do cliente (unico e exclusivo dns) ae tenta colocar no dominio, se der certu é só voltar o dns q vc estava usando antes o win continua logando de boa... eu enfrentava problemas assim com win2k server + win xp pro e resolvia desta forma...
    jvdebian
    Essa ideia do DNS funcionou, agora o windows consegue encontrar o Samba como PDC mas mesmo depois de adicionar a conta de maquina no passwd e no smbpasswd e tambem o root no smbpasswd, quando eu adiciono a maquina no dominio ele pede a conta de administrador, eu utilizo a conta root e mesmo assim da a msg de access denied!!! PQP!!! o q sera q ta acontecendo agora??? vou colocar os comandos que eu utilizei, quem sabe alguem possa me ajudar!!!!
    # groupadd trust
    # useradd -g trust -s /dev/null -d /dev/null lamer$
    # smbpasswd -a -m lamer
    # smbpasswd -a root
    e depois tento colocar o host Windows com o nome lamer e usando a senha de root e ele me responde "Access Denied!!!"
    What's going on?
    blz.... se vc conseguir resolver posta ae pra nois... :good:
    fabriciolf
    hey galera...
    alguma posicao sobre a config do samba como PDC da rede....
    eh q estou com um projeto de migrar as estacoes da rede de win98se
    para win2k...
    ja estamos testando aki... configuro o windows com o grupo e talx
    informo o usuario e senha validos no samba mas o win retorna dizendo que
    o nome ou senha do usuario estao incorretos!!!
    e ai, alguem tem algum tutorial que explique a configuracao adequada do smb.conf para o win2k /winxp ingressarem em um dominio!??!
    valeu...
    num tem q mexer no registro do windows para ele NÃO mandar a senha encriptada?? verifiquem issu ae... mexi com samba faz tempo ja...
    fabriciolf
    hey pessoal...
    alguem que ja tenha configurado o samba de forma a fazer com que os
    clientes win2k logasse na rede sem problemas., pode nos dar uma forca...
    nao sei ainda o que o jvdebian resolveu...
    funcionou.. ou naum..
    o que vejo por ae.. sao alguns tutoriais de como fazer isso funcionar..
    mas dos que eu li... sempre mostra a config diferente.. e /ou forma diferente de fazer...!!
    alguem pode nos dar uma forca...
    valeu!!
