    jabsnet
    Padrão DUP! no ping o que eh?
    PING 192.168.1.255 (192.168.1.255): 56 data bytes
    64 bytes from 192.168.1.19: icmp_seq=0 ttl=255 time=9.3 ms
    64 bytes from 192.168.1.250: icmp_seq=0 ttl=255 time=78.8 ms (DUP!)
    64 bytes from 192.168.1.250: icmp_seq=1 ttl=255 time=9.2 ms
    64 bytes from 192.168.1.19: icmp_seq=1 ttl=255 time=43.5 ms (DUP!)
    64 bytes from 192.168.1.250: icmp_seq=2 ttl=255 time=33.0 ms
    64 bytes from 192.168.1.19: icmp_seq=2 ttl=255 time=86.8 ms (DUP!)
    64 bytes from 192.168.1.250: icmp_seq=3 ttl=255 time=57.1 ms
    64 bytes from 192.168.1.19: icmp_seq=3 ttl=255 time=91.5 ms (DUP!)
    64 bytes from 192.168.1.19: icmp_seq=4 ttl=255 time=39.4 ms
    64 bytes from 192.168.1.19: icmp_seq=5 ttl=255 time=38.8 ms
    64 bytes from 192.168.1.250: icmp_seq=5 ttl=255 time=106.9 ms (DUP!)
    64 bytes from 192.168.1.250: icmp_seq=6 ttl=255 time=26.8 ms
    64 bytes from 192.168.1.19: icmp_seq=6 ttl=255 time=75.1 ms (DUP!)
    64 bytes from 192.168.1.19: icmp_seq=7 ttl=255 time=82.9 ms
    64 bytes from 192.168.1.19: icmp_seq=8 ttl=255 time=5.3 ms
    64 bytes from 192.168.1.250: icmp_seq=8 ttl=255 time=78.2 ms (DUP!)
    64 bytes from 192.168.1.19: icmp_seq=9 ttl=255 time=29.0 ms
    64 bytes from 192.168.1.250: icmp_seq=9 ttl=255 time=98.9 ms (DUP!)
    64 bytes from 192.168.1.19: icmp_seq=10 ttl=255 time=53.0 ms
    64 bytes from 192.168.1.250: icmp_seq=11 ttl=255 time=49.1 ms
    --- 192.168.1.255 ping statistics ---
    12 packets transmitted, 12 packets received, +8 duplicates, 0% packet loss
    round-trip min/avg/max = 5.3/54.6/106.9 ms
    pinguei o broadcast e deu nisso alguem pode me explicar.....
    outra coisa que quero saber eh como posso usar o packet forwading do AP2000.... tenho dois aps com 2 cartoes cada uma setorial em cada e ambos ligados numa mesma hub que esta ligado na placa do servidor.... Abracos...
    Que o ping ta chegando duplicado, provavelmente por causa dos dois cartoes, se vc for ver, apareçe o icmp_seq=0 duas vezes ae ele diz que eh duplciado.
    falows
    jabsnet
    isso percebi mas gostaria de saber pq tah duplicando sendo que o ip final 250 tah numa ap e o final 19 esta em outra (mas ambas ligadas na mesma hub)....?
    fabriciomota
    Padrão dup
    os aparelhos d-link tem mania de fazer isso !
    weziton
    Isso ocorre sempre com equipamentos trabalhando em G ou b+, estas funcções que deixam os equipamentos com mais largura de banda, faz isso por protocolos onde usa-se 3 canais para trabalhar, acontece que se os pacotes forem por canais diferentes e chegarem com defazagem, eles se duplicam para que não ocorra a perda, isso é muito bom para uso indoor, mas para uso outddor é uma merda, sem falar na zorra que isso causa no spectro. Muitos provedores estão usando estes equipamentos para aumentar seus backbones, a principio funciona, mas quando vc precisar fazer um outros ptp, fique esperto.
    jabsnet
    vou explicar minha infraestrutura.... sao 2 aps 2 cartoes em cada cada cartao um painel setorial cada um com canal diferente... esses aps estao ligados a uma mesma hub ligadas ao servidor..... pode ser por issu o excesso de pacotes duplicados??
