  1. tem que colocar as regras no inicio do firewall...
    iptables -F
    iptables -t nat -F
    pq depois que vc limpa as regras vc perde o contato com o servidor, por isso qdo vc executa o rc.firewall ele limpa as regras mas ele mesmo trata de liberar o putty pra vc de novo.. rsrs...
  2. #7
    bruno_forum
    Segue meu firewall...
    caso tiver que mudar alguma coisa me falem em que trecho por favor:
    echo Inicializacoes...
    INET_IP="200.161.141.114"
    INET_IFACE="eth0"
    INET_BROADCAST="200.161.141.127"
    LAN_IP="192.168.0.1"
    LAN_IP_RANGE="192.168.0.0/24"
    LAN_IFACE="eth1"
    LO_IFACE="lo"
    LO_IP="127.0.0.1"
    IPTABLES="/sbin/iptables"
    echo Carregando modulos...
    /sbin/depmod -a
    /sbin/modprobe ip_tables
    /sbin/modprobe ip_conntrack
    /sbin/modprobe iptable_filter
    /sbin/modprobe iptable_mangle
    /sbin/modprobe iptable_nat
    /sbin/modprobe ipt_LOG
    /sbin/modprobe ipt_limit
    /sbin/modprobe ipt_state
    echo "1" > /proc/sys/net/ipv4/ip_forward
    echo Setando politicas...
    $IPTABLES -P INPUT DROP
    $IPTABLES -P OUTPUT DROP
    $IPTABLES -P FORWARD DROP
    echo Criando cadeias...
    $IPTABLES -N bad_tcp_packets
    $IPTABLES -N allowed
    $IPTABLES -N tcp_packets
    $IPTABLES -N udp_packets
    $IPTABLES -N icmp_packets
    echo Criando regras para novas cadeias
    $IPTABLES -A bad_tcp_packets -p tcp --tcp-flags SYN,ACK SYN,ACK \
    -m state --state NEW -j REJECT --reject-with tcp-reset
    $IPTABLES -A bad_tcp_packets -p tcp ! --syn -m state --state NEW -j LOG \
    --log-prefix "New not syn:"
    $IPTABLES -A bad_tcp_packets -p tcp ! --syn -m state --state NEW -j DROP
    $IPTABLES -A allowed -p TCP --syn -j ACCEPT
    $IPTABLES -A allowed -p TCP -m state --state ESTABLISHED,RELATED -j ACCEPT
    $IPTABLES -A allowed -p TCP -j DROP
    $IPTABLES -A icmp_packets -p ICMP -s 0/0 --icmp-type 8 -j ACCEPT
    $IPTABLES -A icmp_packets -p ICMP -s 0/0 --icmp-type 11 -j ACCEPT
    echo Regras para INPUT...
    $IPTABLES -A INPUT -p tcp -j bad_tcp_packets
    $IPTABLES -A INPUT -p ALL -i $LAN_IFACE -s $LAN_IP_RANGE -j ACCEPT
    $IPTABLES -A INPUT -p ALL -i $LO_IFACE -s $LO_IP -j ACCEPT
    $IPTABLES -A INPUT -p ALL -i $LO_IFACE -s $LAN_IP -j ACCEPT
    $IPTABLES -A INPUT -p ALL -i $LO_IFACE -s $INET_IP -j ACCEPT
    $IPTABLES -A INPUT -p UDP -i $LAN_IFACE --dport 67 --sport 68 -j ACCEPT
    $IPTABLES -A INPUT -p ALL -d $INET_IP -m state --state ESTABLISHED,RELATED \
    -j ACCEPT
    $IPTABLES -A INPUT -p TCP -i $INET_IFACE -j tcp_packets
    $IPTABLES -A INPUT -p UDP -i $INET_IFACE -j udp_packets
    $IPTABLES -A INPUT -p ICMP -i $INET_IFACE -j icmp_packets
    echo Regras para FORWARD...
    $IPTABLES -A FORWARD -p tcp -j bad_tcp_packets
    $IPTABLES -A FORWARD -i $LAN_IFACE -j ACCEPT
    $IPTABLES -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
    echo Regras para OUTPUT...
    $IPTABLES -A OUTPUT -p tcp -j bad_tcp_packets
    $IPTABLES -A OUTPUT -p ALL -s $LO_IP -j ACCEPT
    $IPTABLES -A OUTPUT -p ALL -s $LAN_IP -j ACCEPT
    $IPTABLES -A OUTPUT -p ALL -s $INET_IP -j ACCEPT
    $IPTABLES -t nat -A POSTROUTING -o $INET_IFACE -j SNAT --to-source $INET_IP
  3. Coloca estas regras no início do seu firewall
    iptables -F
    iptables -t nat -F
    Daih em vez de vc executa-las e depois executar o firewall vc soh executa o script.
    De qualquer forma que vc fizer a sua conecção vai cair e vc vai ter que connectar novamente.
  4. #9
    bruno_forum
    Magavilha...
    deu certinho...
    Sabe como é né cansa de fica levantando por senha de root apertar 2 vezes a setinha pra cima e aperta enter e escrever exit...
    Valeu pela força de todos!
  5. #10
    O problema todo é que o firewall dele é default drop. Não se pode fazer um flush no terminal pq senão toda a conexão passa a ser negada sem que vc tenha a chance de chamar o script - trava mesmo (rs). Mas se isto for feito no script, o script todo será executado e vc não cai... sofre um congelamento de alguns segundos (enqto as regras são remontadas), mas volta.
    Citação Postado originalmente por White_Tiger
    iptables -F
    iptables -t nat -F
  1. Kazaa + firewall
    Por serrato no fórum Servidores de Rede
    Último Post: 10-01-2005, 20:21
  2. Não consigo configurar firewall
    Por buosinet no fórum Servidores de Rede
    Respostas: 5
    Último Post: 29-11-2004, 19:09
  3. Squid + Firewall
    Respostas: 10
    Último Post: 02-12-2002, 18:54
  4. firewall x webmail ou firewall x php?
    Por eclaudin no fórum Segurança
    Último Post: 23-08-2002, 04:14
  5. Não consigo configurar firewall
    Último Post: 28-03-2002, 21:44
