    superh
    Padrão acentuação no OpenOffice 1.1.3
    Eu uso oslackware 10.1 e não esrtou conseguindo acentuar as palavras no openoffice, eu acentuo todas as palavras nos outros aplicativos mas no open não estou conseguindo.
    j[á procurei na net varias formas de ativar a acentiação no openoffice e não deu serto.
    Está aqui meu arquivo /etc/profile que nãome deixa mentir.:
    Código :
    # /etc/profile: This file contains system-wide defaults used by
     # all Bourne (and related) shells.
     # Set the values for some environment variables:
     export MINICOM="-c on"
     export MANPATH=/usr/local/man:/usr/man:/usr/X11R6/man
     export HOSTNAME="`cat /etc/HOSTNAME`"
     export LESSOPEN="|lesspipe.sh %s"
     export LESS="-M"
     export LC_ALL=pt_BR
     export LANG=pt_BR
     # If the user doesn't have a .inputrc, use the one in /etc.
     if [ ! -r "$HOME/.inputrc" ]; then
       export INPUTRC=/etc/inputrc
     fi
     # Set the default system $PATH:
     PATH="/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/usr/games"
     # For root users, ensure that /usr/local/sbin, /usr/sbin, and /sbin are in
     # the $PATH.  Some means of connection don't add these by default (sshd comes
     # to mind).
     if [ "`id -u`" = "0" ]; then
       echo $PATH | grep /usr/local/sbin 1> /dev/null 2> /dev/null
       if [ ! $? = 0 ]; then
         PATH=/usr/local/sbin:/usr/sbin:/sbin:$PATH
       fi
     fi
     # I had problems using 'eval tset' instead of 'TERM=', but you might want to
     # try it anyway. I think with the right /etc/termcap it would work great.
     # eval `tset -sQ "$TERM"`
     if [ "$TERM" = "" -o "$TERM" = "unknown" ]; then
      TERM=linux
     fi
     # Set ksh93 visual editing mode:
     if [ "$SHELL" = "/bin/ksh" ]; then
       VISUAL=emacs
     #  VISUAL=gmacs
     #  VISUAL=vi
     fi
     # Set a default shell prompt:
     #PS1='`hostname`:`pwd`# '
     if [ "$SHELL" = "/bin/pdksh" ]; then
      PS1='! $ '
     elif [ "$SHELL" = "/bin/ksh" ]; then
      PS1='! ${PWD/#$HOME/~}$ '
     elif [ "$SHELL" = "/bin/zsh" ]; then
      PS1='%[email protected]%m:%~%# '
     elif [ "$SHELL" = "/bin/ash" ]; then
      PS1='$ '
     else
      PS1='\[email protected]\h:\w\$ '
     fi
     PS2='> '
     export PATH DISPLAY LESS TERM PS1 PS2
     # Default umask.  A umask of 022 prevents new files from being created group
     # and world writable.
     umask 022
     # Set up the LS_COLORS and LS_OPTIONS environment variables for color ls:
      eval `dircolors -z`
      eval `dircolors -s`
     else
      eval `dircolors -b`
     fi
     # Notify user of incoming mail.  This can be overridden in the user's
     # local startup file (~/.bash.login or whatever, depending on the shell)
     if [ -x /usr/bin/biff ]; then
      biff y
     fi
     # Append any additional sh scripts found in /etc/profile.d/:
     for profile_script in /etc/profile.d/*.sh ; do
       if [ -x $profile_script ]; then
         . $profile_script
       fi
     done
     unset profile_script
     # For non-root users, add the current directory to the search path:
     if [ ! "`id -u`" = "0" ]; then
      PATH="$PATH:."
     fi
     [[ -f "/etc/autopackage/paths-bash" ]] && . "/etc/autopackage/paths-bash"
    o meu openoffice esta instalado no diretório Raiz / será que isto influencia alguma coisa?
    Abraços a todos gostariade ajuda.
    1 O seu teclado está configurado de maneira correta? Funciona com acentos nas outras partes do SO?
    2 O OOO está instalado para o português?
    superh
    Citação Postado originalmente por vonlinkerstain
    1) o teclado funciona perfeitamente em outros programas.
    2)Eu fui no menu >ferramentas >opções>configurações de idiomas>idiomas e esta configurado para para português (brasil).
    Abraços!
    Eu aqui, no slackware 10.1 e openoffice 1.1.3, a acentuação funciona perfeitamente.
    Você instalou o openoffice localizado? Se não, você instalou o pacote de idioma?
    superh
    Citação Postado originalmente por flaviomlopes
    Eu instalei o OpenOffice no diretorio Raiz /
    Eu pacote de idioma?
    Eu peguei o OpenOffice PT-BR não entendi?
    Abraços!
    Este open office pt-BR é isto que o colega acima falou...
    Estranho este seu caso, pois deveria funcionar perfeitamente..
    Em qual ambiente você está usando ele? KDE/gnome/etc
    Eu estou usando o kde
