    Digital_man
    Padrão Servidor DNS naum funciona
    Bom amigos segui um artigo indicado aqui no forum quando estarto o named ele da ok mais o servidor naum roda
    Uso um link da telemar e um servidor com o conectiva 10 compartilhando a net e nele que quero por o servidor de nomes.
    Aqui vai minhas configurações pra vcs me ajudarem.
    ARQUIVO NAMED.CONF
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    # memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 200.223.252.243/32; };
    allow-transfer { 200.223.252.244; };
    transfer-format many-answers;
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "252.223.200.in-addr.arpa" {
    type master;
    file "200.223.252.rev";
    zone "accesspower.com.br" {
    type master;
    file "accesspower.com.br";
    ARQUIVO 200.223.252.REV
    $TTL 600
    @ IN SOA accesspower.com.br. root.accesspower.com.br. (
    2005051000
    3600
    900
    1209600
    43200 )
    @ IN NS accesspower.com.br.
    243 IN PTR accesspower.com.br.
    244 IN PTR accesspower.com.br.
    ARQUIVO ACCESSPOWER.COM.BR
    $TTL 600
    2005062000 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ) ; default_ttl
    @ IN NS ns1.accesspower.com.br.
    @ IN NS ns2.accesspower.com.br.
    @ IN MX 5 ns2.accesspower.com.br.
    ns1.accesspower.com.br. IN A 200.223.252.243
    ns2.accesspower.com.br IN A 200.223.252.244
    www IN CNAME ns1.accesspower.com.br.
    ftp IN CNAME ns1.accesspower.com.br.
    pop IN CNAME ns2.accesspower.com.br.
    smtp IN CNAME ns2.accesspower.com.br.
    ARQUIVO RESOLV.CONF
    domain accesspower.com.br
    nameserver 200.223.252.243
    ARQUIVO HOSTS
    127.0.0.1 localhost.localdomain localhost
    200.223.252.243 cascata.accesspower.com.br cascata
    Esta e minha configuração ele sobe legal mais quando dou um nslookup ela da SERVFAIL.
    mininumal
    deve ter algum erro ao subir o server
    qual sua distribuicao de linux ? e cole o erro gerado por ele no syslog.
    suspeito q vc deva estar com problemas de privilegio de usuario .... normal ter este erro
    Padrão DNS
    Citação Postado originalmente por mininumal
    Uso Conectiva 10
    So naum achei o Syslog??/
    psybox
    #cat /var/log/syslog >> ~/syslog.log
    Abra com seu editor preferido o ~/syslog.log e procure pelos erros.
    Tudo bem... Vou dar um palpite (É palpite porque implementei um servidor Bind aqui, nunca havia usado este servidor DNS, com auxilio do WEBMIN para saber quais eram os arquivos que ele usava, e onde gravava, e instalei numa boa - Tá funcionando que é uma beleza!)
    Como eu num sei muito Linux, vou pelo mais simples e vou complicando, testo, se funciona, eu continuo, senão, eu desfaço e tento novamente. Mas o Bind é super simples, gostei dele: Acho uns dos servidores mais legais do Linux.
    Minha distro é Conectiva 10, tbém: Se vc quiser tentar pelo be-a-ba como eu fiz:
    Instalei via Synaptic o Bind que estava na distro:
    rodei o Webmin e defini a minha zona, coloquei os registros que precisava.
    Certifiquei os caminhos dos arquivos criados se tudo estava apontado direitinho:
    Iniciei o servico
    E agora ele é um Servidor DNS apontado na Fapesp Funcionando, leve, é muito bom!
    Adiós!
    eae
    vo fazer uma pergunta boba...mas nunca se sabe neh...
    esse teu dominio ae jah eh registrado (to sem ponto de interrogacao)...
    pq se num tiver registrado...num vai dar mto certo naum....
    []s
    Padrão SYSlog naum tem
    Citação Postado originalmente por psybox
    Naum achei syslog naum mandei ate localizar no HD inteiro e nada mais usei o comando
    named -g e deu isso aqui ho
    Jul 21 11:50:23.245 starting BIND 9.2.3 -g
    Jul 21 11:50:23.245 using 1 CPU
    Jul 21 11:50:23.251 loading configuration from '/etc/named.conf'
    Jul 21 11:50:23.265 no IPv6 interfaces found
    Jul 21 11:50:23.265 listening on IPv4 interface eth0, 200.223.252.243#53
    Jul 21 11:50:23.266 binding TCP socket: address in use
    Jul 21 11:50:23.271 couldn't add command channel 127.0.0.1#953: address in use
    Jul 21 11:50:23.272 ignoring config file logging statement due to -g option
    Jul 21 11:50:23.272 couldn't open pid file '/var/run/named/named.pid': File exists
    Jul 21 11:50:23.272 exiting (due to early fatal error)
    Padrão Re: SYSlog naum tem
    Voce viu se a estrutura de diretorio /var/run/named existe?
    Voce viu se o arquivo está lá? Ce ja tentou fazer um teste: Ele diz que o arquivo PID existe. Isso informa ao serviço que o NAMED já está supostamente carregado. Tente renomear o arquivo para xxx e tente carregar o named...
    Será que fununcia? :?
    Se num funcionar volte o arquivo PID orinalmente e peça socorro aki.
    felipeasc
    Digite o seguinte comando:
    rndc reload
    se der algum erro, tire o '@' das linhas :
    depois digite: rndc reload
    se der a mensagem:
    server reload successful
    O bind tá rodando direitinho.......você conseguiu cadastrar esses DNS (primário e secundário) no site www.registro.br ???
    Padrão RNDC
    Citação Postado originalmente por felipeasc
    rndc reload
    se der a mensagem:
    Ai amigo fiz isso ele deu a seguinte mensagem
    rndc: Connection failed: connection refused.
    Desculpe....não olhei direito seu arquivo de configuração....faça o seguinte:
    zone "accesspower.com.br" IN {
    type master;
    Faltou o IN.......coloque o IN e digite rndc reload......agora deve funcionar!
    Abraço
