    vamos la, mais um passo para frente...
    Segue meu main.cf
    Código :
    command_directory = /usr/sbin
    daemon_directory = /usr/lib/postfix
    default_privs = nobody
    myhostname = frigoking
    mydomain = brturbo.com
    myorigin = $mydomain
    inet_interfaces = all
    mydestination = $myhostname, localhost.$mydomain, $mydomain,mail.$mydomain,www.$mydomain,ftp.$mydomain
    #mynetworks = 168.100.189.0/28, 127.0.0.0/8
    relay_domains = $mydomain
    relayhost = smtp.brturbo.com
    #relay_recipient_maps = hash:/etc/postfix/relay_recipients
    alias_maps = hash:/etc/postfix/aliases
    alias_database = hash:/etc/postfix/aliases
    #mail_spool_directory = /var/mail
    mailbox_command = /usr/bin/procmail
    #luser_relay = $user@other.host
    smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
    debug_peer_level = 2
    #debug_peer_list = 127.0.0.1
    debugger_command =
    PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
            xxgdb $daemon_directory/$process_name $process_id & sleep 5
    sendmail_path = /usr/sbin/sendmail
    newaliases_path = /usr/bin/newaliases
    mailq_path = /usr/bin/mailq
    setgid_group = postdrop
    manpage_directory = /usr/share/man
    sample_directory = /etc/postfix/sample
    readme_directory = no
    append_dot_mydomain = no
    ###########################autenticação############################
    smtp_sasl_auth_enable = yes
    smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
    smtp_sasl_security_options = noanonymous
    Agora ele envia com o smtp do provider, mas nao está fazendo autentificacao.
    Posso colocar qualquer senha, ou mesmo sem senha, que fica assim o log.
    Código :
    Sep  2 10:26:24 firewall postfix/smtpd[912]: connect from unknown[192.168.254.4]
    Sep  2 10:26:24 firewall postfix/smtpd[912]: 20FC52D402D: client=unknown[192.168.254.4]
    Sep  2 10:26:24 firewall postfix/cleanup[915]: 20FC52D402D: message-id=<008101c5afc2$22c1a740$04fea8c0@precious>
    Sep  2 10:26:24 firewall postfix/qmgr[910]: 20FC52D402D: from=<quemenvia@brturbo.com>, size=1323, nrcpt=1 (queue active)
    Sep  2 10:26:24 firewall postfix/smtpd[912]: disconnect from unknown[192.168.254.4]
    Sep  2 10:26:35 firewall postfix/smtp[916]: 20FC52D402D: to=<quemrecebe@providedor.com.br>, relay=smtp.brturbo.com[200.199.201.162], delay=11, status=sent (250 Ok: queued as D3F893887)
    Sep  2 10:26:35 firewall postfix/qmgr[910]: 20FC52D402D: removed
    tem vezes que da o log, no /log/mail/errors de access denied no relay, as vezes da as vezes nao que merda !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    uhuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuhuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuhuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu :good: :good: :clap: :clap: 6) 6) uhuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu''
    FUNCIONOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    o lance é o pacote cyrus-plain, o artigo do site, n mostra a conf, do sasl, e o pacote cyrus-plain!
    Agora funcionou!!!!!!!!!!
    depois de 2 dias :?
    silmar
    Então faz assim um favor pra nós pode mandar o seu main.cf e o ue vc mecheu pra nós e ainda mais de quebra mim ..
    desde j obr...
    Qual seu msn, a noite volto para casa e colo o main.cf aqui.
    Tive que instalar mais 1 pacote para funcionar, e outra coisa...
    Ainda fiquei na dúvida quanto ao e-mail enviado.
    Porque qualquer usuário cadastrado no servidor pode enviar e-mail com outro usuário cadastrado no mesmo servidor.
    Porque ele vai verificar o arquivo sasl_passwd n importa o usuário, mas isso deve ter uma solução.
    valeu
  1. Problemas com Relay
    Por SonkY no fórum Servidores de Rede
    Último Post: 15-03-2007, 20:49
  2. Sendmail problema com relay
    Por realmode no fórum Servidores de Rede
    Último Post: 23-06-2005, 10:51
  3. problema com qmail + relay em provedores
    Por flanandorj no fórum Servidores de Rede
    Último Post: 23-11-2004, 14:58
  4. Problemas com RELAY (Sendmail)
    Por César Menezes no fórum Servidores de Rede
    Último Post: 29-06-2004, 07:15
  5. problema com o relay-domains do sendmail
    Por mcclaudio no fórum Servidores de Rede
    Último Post: 02-01-2004, 10:12
