    Padrão QMAILTOASTER de acoro com o artigo aqui da underlinux
    o endereco do artigo e esse https://under-linux.org/noticia5277.html
    to fazendo a instalacao no fedora 4 na instalacao ocorre tudo bem nenhuma falha!!
    porem quando executo o http://www.meudominio.com.br/admin-toaster/ ele abre so que tem tres funcoes que nao funicona corretamente a:
    1 -troca de senha (update passwd)
    2 - Add and edit Virtual domains (vqadmin-2.3.4)
    3 - Edit Users, mailing lists, forwarders (qmailadmin-1.2.8)
    segue os erros:
    1. troca de senha
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined index: file in /usr/share/toaster/include/admin.inc.php on line 5, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: PHP_SELF in /usr/share/toaster/htdocs/admin/index.php on line 55, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: oldpasswd in /usr/share/toaster/htdocs/admin/index.php on line 81, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: newpasswd in /usr/share/toaster/htdocs/admin/index.php on line 81, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: newpasswd2 in /usr/share/toaster/htdocs/admin/index.php on line 81, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Use of undefined constant r - assumed 'r' in /usr/share/toaster/include/admin.inc.php on line 10, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: html in /usr/share/toaster/include/admin.inc.php on line 93, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Use of undefined constant r - assumed 'r' in /usr/share/toaster/include/admin.inc.php on line 137, referer: http://www.meudominio.com.br/admin-toaster/
    [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: html in /usr/share/toaster/include/admin.inc.php on line 138, referer: http://www.meudominio.com.br/admin-toaster/
    2 - erro - add dominios
    [Wed Sep 07 19:04:36 2005] [error] [client xxx.xxx.xxx.xxx] (13)Permission denied: exec of '/usr/share/toaster/cgi-bin/vqadmin/toaster.vqadmin' failed, referer: http://www.meudominio.com.br/admin-toaster/
    [Wed Sep 07 19:04:36 2005] [error] [client xxx.xxx.xxx.xxx] Premature end of script headers: toaster.vqadmin, referer: http://www.meudominio.com.br/admin-toaster/
    3 - erro - edicao de usuarios
    [Wed Sep 07 19:06:26 2005] [error] [client xxx.xxx.xxx.xxx] (13)Permission denied: exec of '/usr/share/qmailadmin/index.cgi' failed, referer: http://www.meudominio.com.br/admin-toaster/
    [Wed Sep 07 19:06:26 2005] [error] [client xxx.xxx.xxx.xxx] Premature end of script headers: index.cgi, referer: http://www.meudominio.com.br/admin-toaster/
    alguem tem uma luz??? ja fiz de tudo!!! ja dei ate permisao 777
    thiagog
    se vc realmente seguiu o howto disponivel aqui no site atente-se para a opcao SELINUX em /etc/sysconfig/selinux
    mude para selinux=disabled
    qual distro vc utilizou ?
    ate mais,
    www.qmailtoaster.com [ eu usei o .txt do proprio site ]
    fedora 4
    rabbarros
    Primeiro, vc desabilitou o selinux?
    se nao, desabilite.
    Segundo, vc tem que mudar algumas coisas no /etc/php.ini
    <--- php.ini --->
    >>safe_mode = Off
    sefor usar como "on" especificar o diretorio
    >>error_reporting = E_ALL & ~E_NOTICE
    vc deve estar usando "error_reporting = E_ALL"
    >>register_globals = On
    vc deve estar usando "off", por isso aparece o erro "PHP_SELF"
    <--- php.ini --->
    realize esta modificacoes e qq coisa me escreve novamante.
    Funcionou Blz!! ta redondinho!!
    rabbarros
    blz, o problema qdo vc seta o "safe_mode = On" vc tem que especificar qual diretorio sera permitido o apache executar algo...
    Eu tive o mesmo problema e vi o seu topico pq estava procurando algo na net e nao achei nada tb, ai e dei um duro danado pra resolver, e nao custava nada ajudar....
    QQ coisa estamos ai..
    pablito
    Fiz as alterações no php.ini, estou com SELINUX desabilitado e utilizo FC3.
    Tudo funciona bem, a n ser a troca de senha do admin. O log de erro está gerando esta saída:
    pablito
    alguém saberia qual o problema ?
    rabbarros
    Padrão qmailtoaster
    voce pode mudar no codigo fonte q em vez de deixar r voce colocar entre aspas simples 'r' nas linhas q estao apresentando erro, e para desaparecer os demais erros vc deve setar no php.ini
    rabbarros
    Padrão Re: qmailtoaster
    Citação Postado originalmente por rabbarros
    de uma olhada nas mensagens e realize as alteracoes que eu postei ai...
    pablito
    valeu, funcionou aqui !!
