    fabriciolf
    hey drginfo...
    quando estava tentando configurar o Samba como PDC.. segui alguns tutoriais , e devo ter perdido a logica de como deve funcioar o PDC.
    vamos fazer o seguinte, para que serve o parametro:
    logon path = \\%L\Profiles\%U
    e os arquivos *.bat do netlogon, nao sao mais necessarios/utilizados!?!
  2. #12
    drginfo
    Geralmente eu uso assim:
    [global]
    workgroup = FIREWALL
    server string = Servidor - Drginfo.Firewall
    os level = 100
    preferred master = yes
    domain master = yes
    local master = yes
    domain logons = yes
    hosts allow = 192.168.0.0/24
    remote announce = 192.168.0.0/24
    logon script = %U.bat
    printcap name = cups
    load printers = yes
    printing = cups
    log file = /var/log/samba/%m.log
    max log size = 50
    debug level = 1
    security = user
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    username map = /etc/samba/smbusers
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    add machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine" -d /dev/null -s /bin/false %u
    # see the smb.conf(5) manpage for other important backends, such as tdbsam and ldap
    passdb backend = smbpasswd
    #============================ Share Definitions ==============================
    idmap uid = 16777216-33554431
    idmap gid = 16777216-33554431
    template shell = /bin/false
    winbind use default domain = no
    [homes]
    path = /home/%U
    comment = Home Directories
    browseable = no
    writable = yes
    # Un-comment the following and create the netlogon directory for Domain Logons
    [netlogon]
    comment = Scripts de Logon da Rede
    path = /home/netlogon
    browseable = yes
    public = yes
    read only = yes
    [publico]
    path = /publico
    writeable = yes
    browseable = yes
    force directory mode = 0777
    force create mode = 0777
    # Un-comment the following to provide a specific roving profile share
    # the default is to use the user's home directory
    [Profiles]
    path = /home/%U/profile
    browseable = no
    guest ok = yes
    # automatic printer driver download support
    [print$]
    path = /var/lib/samba/drivers
    guest ok = yes
    browseable = yes
    read only = yes
    ; since this share is configured as read only, then we need
    ; a 'write list'. Check the file system permissions to make
    ; sure this account can copy files to the share. If this
    ; is setup to a non-root account, then it should also exist
    ; as a 'printer admin'
    write list = root
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    # Set public = yes to allow user 'guest account' to print
    guest ok = no
    writable = no
    printable = yes
    printer admin = root
    Este é o meu smb.conf, como vc pode ver não uso o parâmetro logon path = \\%L\Profiles\%U , pelo menos comigo dava problemas e assim como está configurado acima não tenho problemas. Espero que te ajude, qualquer coisa posta aí, valeu.
  3. #13
    fabriciolf
    blx..
    comparando com o meu aqui, esta tranquilo...
    vc tem as fontes que voce se baseou para implantar o PDC...
    como tutorial, manual....
    quero dar uma olhada nisso tb pra ver algumas coisas...
    se tiver, pode ate mandar pro meu e-mail...
    valeu velim!
  4. #14
    drginfo
    cara na realidade eu estou pretendendo escrever um tuto, pois realmente tem muita coisa que em alguns tuto não funcionam e eu tb ralei pra caramba pra deixar funcionando, acredito que estou na mesma situação que vc , um tuto aqui outro ali, um pedaço de um funciona outro não e assim vamos vivendo, mas se vc tiver dúvidas posta aí ou me mand aum e-mail pra gente trocar idéias valeu.
    Assim que tiver disposição e tempo vou escrever um tuto só sobre samba.
  5. #15
    fabriciolf
    eh isso mesmo meu amigo....eheheh
    estou nessa situacao...
    mas, vamos tentar tiras as duvidas eheheheh
    ...seguinte, uma etapa q eu nao entedi (e so consegui fazer uma vez) eh de como fazer o comp. win2k logar no dominio...
    quais as etapas q vc seguiu para as credenciais serem efetivas!?!??!
  1. Autenticar Squid Com Samba Como PDC
    Por fomezero no fórum Servidores de Rede
    Último Post: 08-09-2011, 21:35
  2. Problemas Samba como PDC
    Por gamstalden no fórum Servidores de Rede
    Último Post: 16-05-2006, 20:33
  3. Samba como PDC com varias interfaces e windows 98
    Por Trevão no fórum Servidores de Rede
    Último Post: 21-06-2005, 15:10
  4. Respostas: 2
    Último Post: 16-06-2004, 21:20
  5. Respostas: 0
    Último Post: 26-08-2002, 17:42
