    Bom pessoal!
    To entrando no mundo aqui!
    Estou seguindo um tutorial del Postfix+MySql,
    mas quando vou criar as GrantTables dá o seguinte erro...
    # su mysql
    $ mysql_install_db
    Installing all prepared tables
    Fill help tables
    To start mysqld at boot time you have to copy support-files/mysql.server
    to the right place for your system
    PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
    To do so, start the server, then issue the following commands:
    /usr/bin/mysqladmin -u root password 'new-password'
    /usr/bin/mysqladmin -u root -h mail password 'new-password'
    See the manual for more instructions.
    NOTE: If you are upgrading from a MySQL <= 3.22.10 you should run
    the /usr/bin/mysql_fix_privilege_tables. Otherwise you will not be
    able to use the new GRANT command!
    You can start the MySQL daemon with:
    cd /usr ; /usr/bin/mysqld_safe &
    You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
    cd sql-bench ; perl run-all-tests
    Please report any problems with the /usr/bin/mysqlbug script!
    The latest information about MySQL is available on the web at
    http://www.mysql.com
    Support MySQL by buying support/licenses at https://order.mysql.com
    em vez de aparecer..
    Preparing db table
    Preparing host table
    Preparing user table
    Praparing func table
    Praparing tables_priv table
    Praparing columns_priv table
    040625 12:23:26 /usr/libexec/mysqld: Shutdown Complete . . .
    Resultado do Log
    cat /var/log/mysql/mysqld.log
    /usr/libexec/mysqld, Version: 4.1.14-log. started with:
    Tcp port: 0 Unix socket: /var/run/mysql/mysql.sock
    Time Id Command Argument
  2. não houve erro algum, faça um teste, acesse o banco, de um use test e depois describe tables. Se funcionar seu banco de dados está funcionando corretamente.
    []'s
  1. Respostas: 40
    Último Post: 29-08-2008, 10:56
  2. Problema para criar contas novas no msn.
    Por Minasnet no fórum Redes
    Último Post: 26-08-2008, 21:26
  3. Problemas para criar GrantTables no Mysql 4.1
    Último Post: 23-11-2005, 12:00
  4. Problemas para criar boot remoto no conectiva 10
    Por kondor no fórum Servidores de Rede
    Último Post: 25-04-2005, 18:56
  5. criar usuario no mysql ???
    Último Post: 07-05-2003, 18:19
