    Padrão DNS Correto Mais Reverso da Erro
    Gente configurei o DNS daqui e ta funcionando quando chamo www.accesspower.com.br ele acessa o apache normal, da tentei criar um servidor de email e descobri que meu reverso naum ta normal quando testo ele no www.terra.com.br/postmaster da o seguinte erro
    ERRO
    $ host 200.223.252.243
    Host 243.252.223.200.in-addr.arpa not found: 3(NXDOMAIN)
    Segue abaixo meus arquivos de acordo com oque a telemar mandou preciso muito de ajuda.
    named.conf
    options {
    directory "/var/named";
    allow-transfer{
    200.223.252.243;
    listen-on{
    200.223.252.243;
    127.0.0.1;
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    */ version "[EF DNS SERVER]";
    query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    // a shared secret for the rndc tool
    // this key must be the same one that is in the
    // /etc/rndc.conf file
    key key_rndc{
    algorithm "hmac-md5";
    secret "kZpfpfxdUYkuHRKHkd5n4g==";
    // a control channel for the new rndc tool
    controls{
    inet 127.0.0.1 allow{
    localhost;
    } keys{
    key_rndc;
    zone "." {
    type hint;
    file "named.ca";
    zone "accesspower.com.br" {
    type master;
    file "accesspower.com.br.db";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "240-247.252.223.200.IN-ADDR.ARPA" {
    type master;
    file "accesspower.com.br.rev";
    Meu accesspower.com.br.db
    accesspower.com.br. IN SOA ns1.accesspower.com.br. root.ns1.accesspower.com.br. (
    2006031001 ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    accesspower.com.br. IN A 200.223.252.243
    accesspower.com.br. IN NS ns1.accesspower.com.br.
    accesspower.com.br. IN MX 5 mx.accesspower.com.br.
    www IN A 200.223.252.243
    ftp IN A 200.223.252.243
    mx IN A 200.223.252.243
    ns1 IN A 200.223.252.243
    Meu accesspower.com.br.rev
    @ORIGIN 240-247.252.223.200.in-addr.arpa.
    @ IN SOA www.accesspower.com.br. suporte.accesspower.com.br (
    200605107u ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    IN NS ns4.telemar.net.br.
    IN NS ns2.telemar.net.br.
    243 IN PTR HYPERLINK "http://ns1.accesspower.com.br/
    "ns1.accesspower.com.br
    Meu named.local
    @ IN SOA localhost. root.localhost. (
    2006050812 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    Padrão Re: DNS Correto Mais Reverso da Erro
    Faltou o setup de um PTR record apontando de volta:
    243.240-247.252.223.200.in-addr.arpa. in PTR accesspower.com.br
    Citação Postado originalmente por cybersank
    200605107u ; serial
    1D ; refresh
    1H ; retry
    1000H ; expire
    1H ; default_ttl
    ;coloquei a alteração aqui abaixo
    Agora na consulta de IP reverso da o seguinte erro.
    $ host 243.252.223.200
    Host 200.223.252.243.in-addr.arpa not found: 3(NXDOMAIN)
    Amigo, o DNS reverso, tem que ser cadastrado também pelo provedor do seu link.
    Mesmo que vc consiga resolver na sua maquina linux no local, a consulta no terra vai retornar dns reverso incorreto.
    att
    Luiz
    Citação Postado originalmente por cunhajr
    att
    Luiz
    Sim mais foi a telemar que mandou eu testar lá, ha telemar me pessou as informações do reverso e mandou testar lá, agora naum intendi.?
    A telemar pediu para vc testar no terra. Mais ela é que tem que cadastrar nos servidores DNS dela o seu reverso, ou permitir que vc atualize nos servidores dela.....
    Olha o que retorna qdo faço uma pesquisa aqui:
    [[email protected] luizjr]#
    [[email protected] luizjr]# host accesspower.com.br
    accesspower.com.br has address 200.223.252.243
    [[email protected] luizjr]# host 200.223.252.243
    Host 243.252.223.200.in-addr.arpa not found: 2(SERVFAIL)
    [[email protected] luizjr]# host procontec.com.br
    procontec.com.br has address 200.164.237.60
    [[email protected] luizjr]# host 200.164.237.60
    60.237.164.200.in-addr.arpa domain name pointer one.procontec.com.br.
    Falta o reverso que é o provedor do LINK que tem que fazer !!
    Att
    Luiz
    Ta tudo certin.
    O problema ta na sua config mesmo:
    Asking ns4.telemar.net.BR. for 243.252.223.200.in-addr.arpa PTR record: Got CNAME referral to 243.240-247.252.223.200.in-addr.arpa. at server ns1.accesspower.com.br. (zone 240-247.252.223.200.in-addr.arpa.) [from 200.222.0.35]
    Asking ns1.accesspower.com.br. for 243.240-247.252.223.200.in-addr.arpa. PTR record: Error: ns1.accesspower.com.br [200.223.252.243] reports a SERVER FAILURE.
    Faz o seguinte:
    Testa aqui: www.dnsreports.com.
    Tu vai ter uma "geral" do que acontece no teu dns.
    Ta tudo certin.
    Vc pode me dar uma dica de como configurar o que esta errado?
    Fica bem dificil sem o DNS estar funcionando, seu servidor nem mesmo responde aos lookups...
    Como ele pode naum estar funcionando se chamo de qualquer lugar www.accesspower.com.br e a pagina entra?.
    É isso ai, sou eu que não pus o IP certo:
    ; <<>> DiG 9.2.1 <<>> www.accesspower.com.br @200.223.252.243
    ;; global options: printcmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 33315
    ;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 1
    ;; QUESTION SECTION:
    ;www.accesspower.com.br. IN A
    ;; ANSWER SECTION:
    www.accesspower.com.br. 3600 IN A 200.223.252.243
    ;; AUTHORITY SECTION:
    accesspower.com.br. 3600 IN NS ns1.accesspower.com.br.
    ;; ADDITIONAL SECTION:
    ns1.accesspower.com.br. 3600 IN A 200.223.252.243
    ;; Query time: 188 msec
    ;; SERVER: 200.223.252.243#53(200.223.252.243)
    ;; WHEN: Wed May 10 08:58:22 2006
    ;; MSG SIZE rcvd: 90
    Vc precisa criar uma nova zona:
    e nela criar um PTR
    243.240-247.252.223.200.in-addr.arpa. in PTR ns1.accesspower.com.br
