  1. Derrepente meu servidor de domínio (samba) ficou lento, andei analisando os logs e olha o que tinha lá no /var/log/messages :
    Código :
    Jul 10 13:14:13 ruette smbd[3548]: [2006/07/10 13:14:13, 0] lib/util_sock.c:send_smb(647)
    Jul 10 13:14:13 ruette smbd[3548]:  Error writing 4 bytes to client. -1. (Connection reset by peer)
    Jul 10 13:15:10 ruette smbd[3552]: [2006/07/10 13:15:10, 0] lib/util_sock.c:get_peer_addr(1000)
    Jul 10 13:15:10 ruette smbd[3552]:  getpeername failed. Error was Transport endpoint is not connected
    Jul 10 13:15:10 ruette smbd[3552]: [2006/07/10 13:15:10, 0] lib/util_sock.c:write_socket_data(430)
    Jul 10 13:15:10 ruette smbd[3552]:  write_socket_data: write failure. Error = Connection reset by peer
    Jul 10 13:15:10 ruette smbd[3552]: [2006/07/10 13:15:10, 0] lib/util_sock.c:write_socket(455)
    Jul 10 13:15:10 ruette smbd[3552]:  write_socket: Error writing 4 bytes to socket 5: ERRNO = Connection reset by peer
    Jul 10 13:15:10 ruette smbd[3552]: [2006/07/10 13:15:10, 0] lib/util_sock.c:send_smb(647)
    Jul 10 13:15:10 ruette smbd[3552]:  Error writing 4 bytes to client. -1. (Connection reset by peer)
    Jul 10 13:15:46 ruette smbd[3281]: [2006/07/10 13:15:46, 0] smbd/oplock.c:oplock_break(839)
    Jul 10 13:15:46 ruette smbd[3281]:  oplock_break: receive_smb timed out after 30 seconds.
    Jul 10 13:15:46 ruette smbd[3281]:  oplock_break failed for file tnsnames.ora (dev = 812, inode = 768601, file_id = 140).
    Jul 10 13:15:46 ruette smbd[3281]: [2006/07/10 13:15:46, 0] smbd/oplock.c:oplock_break(911)
    Jul 10 13:15:46 ruette smbd[3281]:  oplock_break: client failure in oplock break in file tnsnames.ora
    Jul 10 13:20:35 ruette smbd[3565]: [2006/07/10 13:20:35, 0] lib/util_sock.c:write_socket_data(430)
    Jul 10 13:20:35 ruette smbd[3565]:  write_socket_data: write failure. Error = Connection reset by peer
    Jul 10 13:20:35 ruette smbd[3565]: [2006/07/10 13:20:35, 0] lib/util_sock.c:write_socket(455)
    Jul 10 13:20:35 ruette smbd[3565]:  write_socket: Error writing 4 bytes to socket 27: ERRNO = Connection reset by peer
    Jul 10 13:20:35 ruette smbd[3565]: [2006/07/10 13:20:35, 0] lib/util_sock.c:send_smb(647)
    Jul 10 13:20:35 ruette smbd[3565]:  Error writing 4 bytes to client. -1. (Connection reset by peer)
    Jul 10 13:20:40 ruette smbd[3566]: [2006/07/10 13:20:40, 0] smbd/service.c:set_current_service(51)
    Jul 10 13:20:41 ruette smbd[3566]:  chdir (/home/eabreu) failed
    Jul 10 13:22:09 ruette smbd[3569]: [2006/07/10 13:22:09, 0] lib/util_sock.c:write_socket_data(430)
    Jul 10 13:22:09 ruette smbd[3569]:  write_socket_data: write failure. Error = Connection reset by peer
    Jul 10 13:22:09 ruette smbd[3569]: [2006/07/10 13:22:09, 0] lib/util_sock.c:write_socket(455)
    Jul 10 13:22:09 ruette smbd[3569]:  write_socket: Error writing 4 bytes to socket 5: ERRNO = Connection reset by peer
    Jul 10 13:22:09 ruette smbd[3569]: [2006/07/10 13:22:09, 0] lib/util_sock.c:send_smb(647)
    Jul 10 13:22:09 ruette smbd[3569]:  Error writing 4 bytes to client. -1. (Connection reset by peer)
    Alguém sabe o que é isso?
    Principalmente o erro :
    Código :
    Valeu.
  2. Bem, eu já trombei este erro, mas ele era inofensivo na minha época e não me causou dor de cabeça alguma. Entretanto, quando li sua pergunta, fiquei intrigado e resolvi fazer um pouco de lição de casa. O quê eu descobri foi que máquinas rodando Microsoft Windows XP tentam uma conexão pelas portas 139 e 445. A que responder primeiro vai ser a porta utilizada para comunicação.
    Uma solução que foi encontrada e comentada está disponível neste link. http://lists.samba.org/archive/samba...il/084048.html
    Como solução (Um bocado ortodoxa, na minha opinião) foi bloquear as portas 445/UDP e 445/TCP por IPTables, da seguinte maneira:
    Código :
    # iptables -A INPUT -p TCP --dport 445 -j DROP
    iptables -A INPUT -p UDP --dport 445 -j DROP
    Eu realmente não sei se funciona e eu não testei isso na minha rede (Mesmo porque eu não tive este problema), mas pelo o quê o amigo da thread na lista comentou, parece ser uma solução válida.
    Dê uma lidinha lá e não se baseie unicamente pelo meu post.
    Um abraço!
  3. Entendi legal, li o texto lá.
    Mas agora eu tenho outra pergunta!
    Até ontem estava funcionando normal, derrepente começou aparecer esta mensagem em meu /bar/log/messages.
    -Eu queria saber especificamente quais as utilidades das portas 139 e 445. Então há uma eleição!? Estranho, porque são portas distantes.!
    -Se eu barrar a porta 445 e deixar somente a 139 não vai me causar um pico muito alto nela?
    Obrigado amigos.
  4. Bem, teoricamente há uma eleição, mas como eu disse, eu não testei os procedimentos ali descritos.
    Respondendo a sua pergunta... no seu caso acho que não, porque o que vai contar é o número de requisições feitas para o servidor no geral, e não especificamente para portas.
    Um abraço.
  5. Tenho outra pergunta, como eu faço para barrar a porta 445 no meu servidor samba sendo que ele não possui o IPTABLES ?! :|
    Para incluir o módulo, terei que compilar o kernel, correto?
    Há outra solução para bloquear a porta 445?
  1. Erro no samba..
    Por STEEV no fórum Servidores de Rede
    Último Post: 02-10-2003, 11:04
  2. Erro no Samba
    Último Post: 30-06-2003, 08:33
  3. Erro no samba
    Último Post: 14-04-2003, 12:22
  4. Erro no samba
    Último Post: 10-04-2003, 09:54
  5. smb_get_length(mgs erros no Samba)?????
    Por PedroNasc no fórum Servidores de Rede
    Último Post: 26-11-2002, 12:42
