- NTP server
NTP server
pessoal usei o seguinte arquivo de configuracao do ntp.conf
# ntpd
# server (stratum 1)
server ntps1.pads.ufrj.br # (UFRJ), Rio de Janeiro, Brazil
server ntp1.rnp.br # Rede Nacional de Pesquisa (RNP)
server clock.via.net # ViaNet Communications, Palo Alto, CA, USA
# server (stratum 2)
server ntp.pads.ufrj.br # UFRJ, Rio de Janeiro, Brazil (PADS)
server ntp2.pads.ufrj.br # UFRJ, Rio de Janeiro, Brazil (PADS)
server ntp.pop-mg.rnp.br # POP-ES (RNP)
server ntp.pop-es.rnp.br # POP-MG (RNP)
server 192.168.0.2
fudge 192.168.0.2 stratum 13
restrict default kod notrap nomodify nopeer noquery
restrict 127.0.0.1 nomodify
#broadcast 192.168.255.255
logfile /var/log/ntp/ntp.log
driftfile /var/lib/ntp/ntp.drift
disable auth
broadcastclient
e no log apos iniciar o daemon aparece o seguinte
[root@srv01 ntp]# cat ntp.log
13 Jul 11:44:48 ntpd[18824]: ntpd exiting on signal 15
13 Jul 11:44:48 ntpd[18854]: running as uid(38)/gid(38) euid(38)/egid(38).
mas quando vou nos clientes linux ntpdate ntp.meudominio
erro:
13 Jul 11:45:07 ntpdate[16507]: no server suitable for synchronization found
You have new mail in /var/mail/root
o que signifca ?
server 192.168.0.2
fudge 192.168.0.2 stratum 13 (aqui esta o ip do meu servidor)
Re: NTP server
Caso todos os servidores na internet falharem o seu servidor assume como stratum 13
