    Padrão Re: Balanceamento de ADSL
    pro2 porque voce não posta a solução, assim todos aprendem velho! abralços.
  2. #20
    Eu fiz assim:
    No ip / firewall / mangle:
    add chain=prerouting in-interface=interfacedosclientes connection-state=new nth=2,1,0 action=mark-connection new-connection-mark=odd passthrough=yes
    add dst-address=0.0.0.0/0 gateway=201.18.52.161 scope=255 target-scope=10 routing-mark=odd comment="" disabled=no
    add chain=prerouting in-interface=interfacedosclientes connection-state=new nth=2,1,1 action=mark-connection new-connection-mark=even passthrough=yes
    add dst-address=0.0.0.0/0 gateway=192.168.20.1 scope=255 target-scope=10 routing-mark=even comment="" disabled=no
    add chain=prerouting in-interface=interfacedosclientes connection-state=new nth=2,1,2 action=mark-connection new-connection-mark=odd1 passthrough=yes
    add dst-address=0.0.0.0/0 gateway=201.18.52.161 scope=255 target-scope=10 routing-mark=odd1 comment="" disabled=no
    No ip / route:
    add gateway=201.18.52.161 dst-address=0.0.0.0/0 routing-mark=odd
    add gateway=192.168.20.1 dst-address=0.0.0.0/0 routing-mark=even
    add gateway=201.18.52.161 dst-address=0.0.0.0/0 routing-mark=odd1
    Sendo que este último seria o gateway padrão...
    Dessa forma, a primeira conexão nova irá para o gateway 201.18.52.161, a segunda para o 192.168.20.1 e a terceira para o 201.18.52.161 novamente... Assim, a proporção do link principal seria de 2 para 1 do link secundário... Como o teu link principal é 4 vezes maior que o secundário, é só criar mais 2 regras com outro nome de marcação e direcionar para o mesmo gateway...
  3. #21
    / ip firewall mangle
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,0 \
    action=mark-connection new-connection-mark=odd passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=Local connection-mark=odd action=mark-routing \
    new-routing-mark=odd passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,1 \
    action=mark-connection new-connection-mark=even passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=Local connection-mark=even action=mark-routing \
    new-routing-mark=even passthrough=no comment="" disabled=no
    / ip firewall nat
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=201.18.52.160\
    to-ports=0-65535 comment="" disabled=no
    add chain=srcnat connection-mark=even action=src-nat to-addresses=192.168.20.10 \
    / ip route
    add dst-address=0.0.0.0/0 gateway=201.18.52.165 scope=255 target-scope=10 routing-mark=odd \
    add dst-address=0.0.0.0/0 gateway=192.168.20.1 scope=255 target-scope=10 routing-mark=even \
    add dst-address=0.0.0.0/0 gateway=201.18.52.165 scope=255 target-scope=10 comment="" \
    disabled=no
    Caro colega _AGM_, nesse exmplo acima a proporção do link principal ( 201.18.52.165) tbm seria de 2 para 1 do link secundário (192.168.20.1) ?
    Thanks ...
  4. #22
    Não... Dessa forma ele vai rotear uma conexão para cada gateway... A rota default é usada somente para conexões internas dele mesmo...
  5. #23
    _AGM_, valeu pela resposta.
    Mas me diga uma coisa. Nessa configuração sua não usa NAT ? O proxy funciona junto ?
    Falow...
  6. #24
    Pessoal, como faria para fazer este mesmo balaceamento via winbox?
