    ok...vamo as confs :
    conf do ponto 1 (em cima do provedor) DWL AG530
    [[email protected]_Portal] > interface wireless print
    name="PTP Portal" mtu=1500 mac-address=XX:XX:XX:XX:XX:XX arp=enabled disable-running-check=no
    interface-type=Atheros AR5413 radio-name="PTP Portal" mode=bridge ssid="ptp_torre" area=""
    frequency-mode=superchannel country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default
    rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
    max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
    periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a
    wds-mode=dynamic wds-default-bridge=Bridge wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
    update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
    default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default
    disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
    conf bridge ponto 1
    [[email protected]_Portal] > interface bridge print
    name="Bridge" mtu=1500 arp=enabled mac-address=XXXXXXXXXXX protocol-mode=none priority=0x8000 auto-mac=yes
    admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
    [[email protected]_Portal] > interface bridge port print
    0 Rede Bridge 0x80 10
    1 D wds1 Bridge 0x80 61
    conf ponto 2 (torre de retransmissão do sinal , chega na ag 530 e vai pra uma g510 em modo ap)
    [[email protected] Dourados] > interface wireless print
    name="PTP Torre" mtu=1500 mac-address=XXXXXXXXXXXXX arp=enabled disable-running-check=no
    interface-type=Atheros AR5413 radio-name="PTP Torre" mode=station-wds ssid="ptp_torre" area=""
    wds-mode=dynamic wds-default-bridge=Bridge_Torre wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
    conf bridge ponto 2
    [[email protected] Dourados] > interface bridge print
    name="Bridge_Torre" mtu=1500 arp=enabled mac-address=XXXXXXXXXXX protocol-mode=none priority=0x8000
    auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
    [[email protected] Dourados] > interface bridge port print
    0 Rede Bridge_Torre 0x80 10
    1 AP Bridge_Torre 0x80 10
    2 PTP Torre Bridge_Torre 0x80 10
    3 AP Bloco1 Bridge_Torre 0x80 10
    4 AP Bloco2 Bridge_Torre 0x80 10
    é isso ae...qq coisa posta ae...t+
  2. #8
  3. #9
    só pra avisar o pessoal, peguei ontem as minhas AG530 eu ja esperava placas com o cabo soldado, mas pra minha surpresa vieram todas com conector pro pigtail assim nao precisor fazer nenhum tipo de adaptacao, sao REV A7 e ja tao rodando linda e maravilhosamente no mikrotik
    boa sorte com as de vcs
  4. #10
    Se for a dlink AG530, posso atestar que funciona sim, pq dia 21/04 vai fazer um ano que tenho 4 delas rodando sem stress. Inclusive já cheguei a 72 usuários online simultâneos, com velocidade de 128 k em cada um...
    Tenho aqui e funciona perfeitamente. Faça o seguinte teste e posta o resultado... Muda elas para o modo "B" (2.4) e coloca em AP Bridge e verifica se funciona.... Posta o resultado para novas instruções....
  5. #11
    Citação Postado originalmente por Mr_Dom Ver Post
    tmb posso atestar q funga na boa...tenho dois ptp com g530 em 5.8...em média 70 a 80 clientes com 2 a 3 mb de tráfego...os ping fica em 0 1 a 3 milisegundos...fiz testaes de tráfego entre elas..guentou 11mbs e com ping estável tanto no tx quato no rx...
    já vai fazer 1 ano q tenho elas...a unica coisa q é ruim de se fazer é alinhas as antenas...principalmente se for as da zirok...mas fungam na boa depois de alinhado...
    segue abaixo fotos dos testes...
    http://servidor.medianeira.com.br/ma...velocidade.JPG
    até mais..espero ajudar..qq coisa poste ae..fuisssssss
    Gostaria de saber o tamanho do seu link, pois o trafego realmente é alto.
  6. #12
    Citação Postado originalmente por claudemirnetlink Ver Post
    nosso link é de apenas 4MB, essa img foi de um teste q rodei entre o ptp com as ag530..pra ver quanto de tráfego ela guenta sem cair..ou sem travar...
    ok..t+
