    Padrão Load Balance, funcionando? Como saber?
    Olá pessoal, usei essas regras abaixo d um amigo q postou aqui para o Load balance:
    / ip address
    add address=192.168.10.1/24 network=192.168.10.0 broadcast=192.168.10.255 interface=ether1 comment="" \
    disabled=no
    add address=192.168.100.20/24 network=192.168.100.0 broadcast=192.168.100.255 interface=ether2 \
    comment="" disabled=no
    add address=192.168.200.20/24 network=192.168.200.0 broadcast=192.168.200.255 interface=ether3 \
    / ip firewall mangle
    add chain=prerouting in-interface=ether1 connection-state=new nth=1,1,0 \
    action=mark-connection new-connection-mark=odd passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=odd action=mark-routing \
    new-routing-mark=odd passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=ether1 connection-state=new nth=1,1,1 \
    action=mark-connection new-connection-mark=even passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=even action=mark-routing \
    new-routing-mark=even passthrough=no comment="" disabled=no
    / ip firewall nat
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=192.168.100.20 \
    to-ports=0-65535 comment="" disabled=no
    add chain=srcnat connection-mark=even action=src-nat to-addresses=192.168.200.20 \
    / ip route
    add dst-address=0.0.0.0/0 gateway=192.168.100.1 scope=255 target-scope=10 routing-mark=odd \
    add dst-address=0.0.0.0/0 gateway=192.168.200.254 scope=255 target-scope=10 routing-mark=even \
    add dst-address=0.0.0.0/0 gateway=192.168.200.254 scope=255 target-scope=10 comment="" \
    disabled=no
    Fiz um mascaramento e um hostpot e como só tenho um pc aqui, gostaria de saber se o funcionamento tá blz, tem como saber? Segue um print das configurações abaixo:
    http://img262.imageshack.us/img262/1917/mk2px7.th.jpg
    Eu conecto meu pc e navega normal pelo link2 ou seja, a ether3, como funcionaria esse balanceamento? Seria o primeiro pc conectado joga pra um link, o segundo pc conectado joja para o outro link e assim sussecivamente?
    Última edição por faieppi; 10-08-2007 às 10:43.
    Exatamente assim, caro colega !
    Toda vez que se conecta, ou que se faz uma requisição, o load requisita um link, por isso mesmo é que vc terá problemas com sites de bancos. Faça um teste ae abrindo o site do Bradesco.
    Vc sumiu ! Nunca mais falei com vc pelo msn..... me excluiu ? heheheh
    Aparece ae pra trocarmos mais idéias a respeito do load
    Falow
    Citação Postado originalmente por rps67 Ver Post
    Falow
    diga kara, estou com outro msn, [email protected], valeu...
    RicardoDouglas
    Smile Estou feliz em fazer parte ...
    Boa Tarde Galera, para não ficar feio e até mesmo mal educado gostaria de expressar em palavras que tá sendo um prazer fazer parte deste fórum sou um novato com muita vontade de trocar idéias e soluções e assim somar conhecimento e fazer amigos e podendo ajudar em qualquer coisa vou estar a disposição.... : ).
    E isse ai galera pouco papo e mais conhecimento e prazer em conhecer geral ....
    Citação Postado originalmente por faieppi Ver Post
    / ip address
    disabled=no
    disabled=no
    disabled=no
    / ip firewall nat
    / ip route
    disabled=no
    Sabe me dizer se isso vai funcionar se eu colocar ip manual no cliente? ou tem que estar como dhcp?
    Vai funcionar com IP manual sem problema.
    Inclusive é uma boa opção, pois caso algum cliente dê algum problema (ou vários que você não queira que passem pelo balanceamento) , você coloca os ips deles numa Address List, e depois nega essa Address nas regras do Mangle.
