  1. Pessoal uso as seguinte regra no meu MK, Web-Proxy + Hotspot, para q possa funcionar a Radio UOL, Conectiva Social, etc, so que essa regra não bloqueia os sites q coloco na aba Access em Web-Proxy, oq pode estar errado nela, ou tem outra forma de fazer funcionar?
    Dêem mais uma força ai pessoal!
    Minhas regras atuais:
    / ip firewall nat
    add chain=srcnat out-interface=LINK action=masquerade comment="NAT" \
    disabled=no
    add chain=srcnat src-address=192.168.2.0/25 action=masquerade \
    comment="masquerade hotspot network" disabled=no
    add chain=srcnat src-address=192.168.4.0/25 action=masquerade \
    add chain=pre-hotspot in-interface=Bridge-Wireless \
    dst-address=200.201.160.0/25 protocol=tcp dst-port=80 hotspot=auth \
    action=accept comment="Conectividade Social" disabled=no
    dst-address=200.201.166.0/25 protocol=tcp dst-port=80 hotspot=auth \
    action=accept comment="" disabled=no
    dst-address=200.201.173.0/25 protocol=tcp dst-port=80 hotspot=auth \
    dst-address=200.201.174.0/25 protocol=tcp dst-port=80 hotspot=auth \
    add chain=pre-hotspot in-interface=Bridge-Wireless dst-address=200.221.0.0/16 \
    protocol=tcp dst-port=80 hotspot=auth action=accept comment="Radio UOL" \
    disabled=no
    dst-address=200.234.199.0/24 protocol=tcp dst-port=80 hotspot=auth \
    action=accept comment="Radio Interativa" disabled=no
    add chain=pre-hotspot in-interface=Bridge-Wireless dst-address=209.85.106.0/24 \
    protocol=tcp dst-port=80 hotspot=auth action=accept comment="Radio \
    Sucesso" disabled=no
    add chain=pre-hotspot in-interface=Bridge-Wireless dst-address=200.154.0.0/16 \
    protocol=tcp dst-port=80 hotspot=auth action=accept comment="Radio TERRA" \
    disabled=no
    add chain=pre-hotspot in-interface=Bridge-Wireless dst-address=72.36.130.0/24 \
    protocol=tcp dst-port=80 hotspot=auth action=accept comment="" disabled=no
    add chain=pre-hotspot in-interface=Bridge-Wireless dst-address=66.135.32.0/24 \
    add chain=pre-hotspot dst-address=192.168.2.100 protocol=tcp dst-port=80 \
    hotspot=auth action=redirect to-ports=64873 comment="Paginas de status do \
    hotspot" disabled=no
    add chain=pre-hotspot in-interface=Bridge-Wireless protocol=tcp dst-port=80 \
    hotspot=auth action=redirect to-ports=8080 comment="Redirecionamento \
    Proxy" disabled=no
    add chain=dstnat in-interface=LOCAL protocol=tcp dst-port=80 action=redirect \
    to-ports=8080 comment="Web-Proxy Local" disabled=no
    add chain=dstnat protocol=tcp dst-port=5901 action=dst-nat \
    to-addresses=10.1.5.3 to-ports=5901 comment="REDIRECIONAMENTO VNC ADM" \
    disabled=no
    add chain=dstnat protocol=tcp dst-port=4899 action=dst-nat \
    to-addresses=10.1.5.4 to-ports=4899 comment="" disabled=no
    add chain=dstnat protocol=tcp dst-port=5900 action=dst-nat \
    to-addresses=192.168.2.6 to-ports=5900 comment="REDIRECIONAMENTO VNC AR" \
    disabled=no
    add chain=dstnat protocol=tcp dst-port=4662 action=dst-nat \
    to-addresses=192.168.4.42 to-ports=4662 comment="Redirecionamento Emule \
    TCP" disabled=no
    add chain=dstnat protocol=udp dst-port=4672 action=dst-nat \
    to-addresses=192.168.4.42 to-ports=4672 comment="Redirecionamento Emule \
    UPD" disabled=no
    ip web-proxy> pr
    enabled: yes
    src-address: 0.0.0.0
    port: 8080
    hostname: "proxy"
    transparent-proxy: yes
    parent-proxy: 0.0.0.0:0
    cache-administrator: "webmaster"
    max-object-size: 10240KiB
    cache-drive: system
    max-cache-size: 35156250KiB
    max-ram-cache-size: unlimited
    status: running
    reserved-for-cache: 22160384KiB
    reserved-for-ram-cache: 2048KiB
    Tenho centenas de paginas cadastradas no bloqueio so q não bloqueia nenuma com essas regra q estou usando!
    Última edição por rogeriodj; 23-11-2007 às 07:20.
  1. Respostas: 3
    Último Post: 19-05-2011, 09:13
  2. Alguem sabe me dizer oq pode ser este erro...
    Por cleciorodrigo no fórum Servidores de Rede
    Último Post: 09-12-2005, 07:33
  3. Squid: "A URL solicitada não pôde ser recuperada"
    Por hsalbano no fórum Servidores de Rede
    Último Post: 21-01-2004, 09:57
  4. O que pode ser isso???
    Por dboom no fórum Servidores de Rede
    Último Post: 11-12-2002, 10:30
  5. Hackear pode ser considerado legal?
    Por _r00tz no fórum Segurança
    Respostas: 5
    Último Post: 27-09-2002, 08:42
