  1. Ola,
    /etc/mail/spamassassin/local.cf:
    Código :
    # These values can be overridden by editing ~/.spamassassin/user_prefs.cf
    # (see spamassassin(1) for details)
    # These should be safe assumptions and allow for simple visual sifting
    # without risking lost emails.
    required_hits 5
    report_safe 0
    rewrite_header Subject [SPAM]
  2. Tenta da forma que segue abaixo pra ver se melhora provavelmente se acaso aparecerem erros nos seus logs quando voce reiniciar o serviço e so descomentar algumas linhas dentro dos arquivos init.pre v310 e v312 que são linhas referentes as regras aplicadas.
    # This is the right place to customize your installation of SpamAssassin.
    # See 'perldoc Mail::SpamAssassin::Conf' for details of what can be
    # tweaked.
    # Only a small subset of options are listed below
    # Add *****SPAM***** to the Subject header of spam e-mails
    # rewrite_header Subject *****SPAM*****
    # Save spam messages as a message/rfc822 MIME attachment instead of
    # modifying the original message (0: off, 2: use text/plain instead)
    report_safe 1
    # Set which networks or hosts are considered 'trusted' by your mail
    # server (i.e. not spammers)
    # trusted_networks 212.17.35.
    # Set file-locking method (flock is not safe over NFS, but is faster)
    # lock_method flock
    # Set the threshold at which a message is considered spam (default: 5.0)
    required_score 4.0
    # Use Bayesian classifier (default: 1)
    use_bayes 1
    # Bayesian classifier auto-learning (default: 1)
    bayes_auto_learn 1
    # Enable or disable network checks
    skip_rbl_checks 0
    use_razor2 1
    use_dcc 1
    use_pyzor 1
    # Mail using languages used in these country codes will not be marked
    # as being possibly spam in a foreign language.
    ok_languages all
    # Mail using locales used in these country codes will not be marked
    ok_locales all
    # Set headers which may provide inappropriate cues to the Bayesian
    # classifier
    # bayes_ignore_header X-Bogosity
    # bayes_ignore_header X-Spam-Flag
    # bayes_ignore_header X-Spam-Status
    Abração
  3. Bixo,
    o meu local.cf era bem suscinto, que nem o seu. Com o tempo fui modificando e ajustando cfe o meu ambiente, vja:
    # cat /etc/mail/spamassassin/local.cf
    # tweaked.
    # report_safe 1
    # lock_method flock
    required_hits 6.2
    rewrite_header Subject [POSSIVEL SPAM]
    report_safe 0
    use_bayes 1
    use_bayes_rules 1
    bayes_auto_learn 1
    skip_rbl_checks 0
    use_razor2 1
    use_dcc 1
    dcc_path /usr/bin/dccproc
    dcc_home /var/dcc
    add_header all DCC _DCCB_: _DCCR_
    dcc_add_header 1
    dcc_dccifd_path /usr/sbin/dccifd
    use_pyzor 1
    pyzor_path /usr/bin/pyzor
    pyzor_add_header 1
    ok_languages all
    ok_locales all
    auto_whitelist_path /var/spool/spamassassin/auto-whitelist
    auto_whitelist_file_mode 0666
    #dcc_home /var/lib/dcc
    Tbm uso este script para atualizar as regras do SA, vja:
    # cat /etc/rc.d/init.d/rc.sa-rules.update
    #!/bin/bash
    #Script para atualizações de regras para o Spamassassin
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...ct_pre3.0.0.cf -O 71_sare_redirect_pre3.0.0.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._poison_nxm.cf -O 70_sare_bayes_poison_nxm.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html.cf -O 70_sare_html.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html4.cf -O 70_sare_html4.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html_arc.cf -O 70_sare_html_arc.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html_eng.cf -O 70_sare_html_eng.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html_x31.cf -O 70_sare_html_x31.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...t_post3.0.0.cf -O 72_sare_redirect_post3.0.0.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_html_x30.cf -O 70_sare_html_x30.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sc_top200.cf -O 70_sc_top200.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_evilnum0.cf -O 70_sare_evilnum0.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_evilnum1.cf -O 70_sare_evilnum1.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_evilnum2.cf -O 70_sare_evilnum2.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_header0.cf -O 70_sare_header0.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._header_eng.cf -O 70_sare_header_eng.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...er_x264_x30.cf -O 70_sare_header_x264_x30.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._header_x31.cf -O 70_sare_header_x31.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._header_arc.cf -O 70_sare_header_arc.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_highrisk.cf -O 70_sare_highrisk.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_obfu.cf -O 70_sare_obfu.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_stocks.cf -O 70_sare_stocks.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_header3.cf -O 70_sare_header3.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._header_x30.cf -O 70_sare_header_x30.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_specific.cf -O 70_sare_specific.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_adult.cf -O 70_sare_adult.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...bml_post25x.cf -O 72_sare_bml_post25x.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7..._bml_pre25x.cf -O 71_sare_bml_pre25x.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/9...aud_post25x.cf -O 99_sare_fraud_post25x.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/9...raud_pre25x.cf -O 99_sare_fraud_pre25x.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_spoof.cf -O 70_sare_spoof.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_random.cf -O 70_sare_random.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_oem.cf -O 70_sare_oem.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_genlsubj0.cf -O 70_sare_genlsubj0.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_genlsubj3.cf -O 70_sare_genlsubj3.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...enlsubj_x30.cf -O 70_sare_genlsubj_x30.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_genlsubj4.cf -O 70_sare_genlsubj4.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...enlsubj_eng.cf -O 70_sare_genlsubj_eng.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_unsub.cf -O 70_sare_unsub.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_uri.cf -O 70_sare_uri.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://mywebpages.comcast.net/mkettler/sa/antidrug.cf -O antidrug.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.yackley.org/sa-rules/evilnumbers.cf -O evilnumbers.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.stearns.org/sa-blacklist/random.current.cf -O random.current.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/88_FVGT_body.cf -O 88_FVGT_body.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/88_FVGT_rawbody.cf -O 88_FVGT_rawbody.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/88_FVGT_subject.cf -O 88_FVGT_subject.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/88_FVGT_headers.cf -O 88_FVGT_headers.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/88_FVGT_uri.cf -O 88_FVGT_uri.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/9...omainDigits.cf -O 99_FVGT_DomainDigits.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/99_FVGT_Tripwire.cf -O 99_FVGT_Tripwire.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/99_FVGT_meta.cf -O 99_FVGT_meta.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/70_sare_whitelist.cf -O 70_sare_whitelist.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...itelist_spf.cf -O 70_sare_whitelist_spf.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/rules/7...elist_pre30.cf -O 70_sare_whitelist_pre30.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.nospamtoday.com/download/mime_validate.cf -O mime_validate.cf
    cd /etc/mail/spamassassin/ &> /dev/null && /usr/bin/wget http://www.rulesemporium.com/plugins/imageinfo.cf -O imageinfo.cf
    exit 0
    Att,
    Cldn
  4. Eu rodei seu script aqui e ele baixou varios arquivos .cf. Pelo que observei sao arquivos de regras para ajudar o SpamAssassin.
    Duvidas:
    1) Como voce descobriu estas regras? No site do SpamAssassin nao tem nada especifico falando sobre isso. Alias, de vez em quando aparece algum arquivo .cf perdido no meio de uma documentacao, mas sem uma explicacao bem definida. Entao, gostaria de saber como posso ficar "atualizado" com estes arquivos de regras.
    Alguns arquivos deram erro no maillog:
    Código :
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_SPEC_PROLEO_M2a has dependency 'MIME_QP_LONG_LINE' with a zero score
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_HEAD_SUBJ_RAND has undefined dependency 'SARE_XMAIL_SUSP2'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_HEAD_SUBJ_RAND has dependency 'X_AUTH_WARN_FAKED' with a zero score
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_HEAD_8BIT_NOSPM has undefined dependency '__SARE_HEAD_8BIT_DATE'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_HEAD_8BIT_NOSPM has undefined dependency '__SARE_HEAD_8BIT_RECV'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_MULT_RATW_03 has undefined dependency '__SARE_MULT_RATW_03E'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_HEAD_XORIP_NOTIP has undefined dependency 'X_ORIG_IPNOT_IPV4'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_RD_SAFE has undefined dependency 'SARE_RD_SAFE_MKSHRT'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_RD_SAFE has undefined dependency 'SARE_RD_SAFE_GT'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_RD_SAFE has undefined dependency 'SARE_RD_SAFE_TINY'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_SUB_FREE has undefined dependency 'SUB_FREE_CAP'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_SUB_FREE has undefined dependency 'SUB_FREE_INSTANT'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_SUB_FREE has dependency 'SUB_FREE_OFFER' with a zero score
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_MSGID_LONG45 has undefined dependency '__SARE_MSGID_LONG50'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_MSGID_LONG45 has undefined dependency '__SARE_MSGID_LONG55'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_MSGID_LONG45 has undefined dependency '__SARE_MSGID_LONG65'
    Dec 17 15:51:51 serv spamd[14058]: rules: meta test SARE_MSGID_LONG45 has undefined dependency '__SARE_MSGID_LONG75'
    2) Eu criei um email chamado spam@dominio e outro ham@dominio. Para depois rodar o sa-learn nos 2 maildirs, na pasta new. O que estou fazendo é pedir para todo mundo encaminhar os spams que estao passando pelo SpamAssassin para o email spam@dominio. Contudo, nos manuais é dito para tambem processar o ham@dominio constantemente. Eu tenho que falar para meus usuarios encaminharem todas as mensagens "boas" que receberem para este email tambem? Por que o pessoal provavelmente nao vai gostar muito da ideia.
    3) Olhei meu arquivo v310.pre e ja esta ativado o uso dos modulos Pyzor e Razor2, como modulos Perl, e nao da maneira citada acima onde foi dito para colocar no local.cf. Quando coloquei no local.cf o maillog avisou que nao era para colocar la, e sim que havia mudado para um modulo Perl. O modulo DCC esta comentado por questoes de licenciamento opensource. Creio que os modulos Pyzor e Razor2 ja estao funcionando. Como eu descubro isso?
    Meu arquivo v310.pre:
    Código :
    loadplugin Mail::SpamAssassin::Plugin::Pyzor
    loadplugin Mail::SpamAssassin::Plugin::Razor2
    loadplugin Mail::SpamAssassin::Plugin::SpamCop
    loadplugin Mail::SpamAssassin::Plugin::AWL
    loadplugin Mail::SpamAssassin::Plugin::AutoLearnThreshold
    loadplugin Mail::SpamAssassin::Plugin::WhiteListSubject
    loadplugin Mail::SpamAssassin::Plugin::MIMEHeader
    loadplugin Mail::SpamAssassin::Plugin::ReplaceTags
  1. Como melhorar o sinal do WOM 5000
    Por Suporte Intelbras no fórum Intelbras
    Respostas: 13
    Último Post: 15-11-2013, 21:30
  2. Como melhorar o sinal do WOM 5000
    Último Post: 14-06-2013, 10:02
  3. Como melhorar o sinal do WOM 5000
    Último Post: 14-06-2013, 09:59
  4. Respostas: 10
    Último Post: 02-12-2007, 16:06
  5. Como melhorar o desempenho do squid?
    Por Good_speed no fórum Servidores de Rede
    Último Post: 23-03-2005, 09:42
