bom galera to penando aqui com um mikrotik de station, eu to testando na bancada e ele tah recebendo sinal de um dlink 900 ap, a config do cartao eh essa
R name="wlan1" mtu=1500 mac-address=00:15:E9:3F:A7:2A arp=enabled
disable-running-check=no interface-type=Atheros AR5212
radio-name="0015E93FA72A" mode=station ssid="provcasa" area=""
frequency-mode=superchannel country=no_country_set antenna-gain=0
frequency=2462 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=enabled periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=pre-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
eu jah tentei de tudo um poco, e oque acontece eh que nao consigo pinga no dlink
e nem navega com a plaquinha recebendo e eu conectado pela placa de rede
as interfaces estao em bridge certinho
Citação
